08-11-2017, 12:04 AM | #89 |
Rep 33
Great info, now if i could only find silver 437s
F30_SixSpeed1170.50 |
08-11-2017, 08:21 AM | #90 | |
Rep 969
Springs will not achieve the look or drop the KWs get. The only spring that will get remotely close would be the H & R super sport springs TBH.
08-11-2017, 05:25 PM | #91 |
Rep 463
Thats what i am debating, the super sport. I am wondering how close they will get.
08-29-2017, 11:48 PM | #92 | |
Rep 98
08-30-2017, 01:57 PM | #93 |
Rep 969
No link... but I messaged you my contact for them.
08-30-2017, 02:02 PM | #94 |
Rep 969
M Performance Big Brake is in
Absolutely love how they look. Rotors are huge and almost completely fill up the whole wheel well. Cannot comment on the performance aspect of them yet... have not had much seat time with them (just got them in yesterday.) Just finished bedding in the brakes and need to code for them... planning on getting that done this week. Also - absolutely no noise from them. UPDATE 9/11/17 - Got the brakes coded over the weekend. Definitely recommend this if you pick up a BBK. Initial pedal feel and firmness has improved about 25% and brakes seem more responsive. I've had some seat time with the car with many high speed braking. Overall, day to day driving their isn't a huge improvement over the stock brembos... pedal feel is about the same. There may be slightly less initial bite but that could be the more aggressive pads I'm running. It's barely noticeable once you've driven a few days with them. Once the brakes get a little heat in them, the stopping power is great. Where these brakes really shine is the high speed braking. The feeling is very linear and when the brakes are applied hard it will stop you in a hurry... absolutely no fade or performance decrease after multiple stops... which is a problem I experienced with my stock brakes (they started to fade and stopping power was reduced until they cooled back down.) Overall they are definitely an upgrade and I am happy I went through with them. Unless you are tracking the car or doing high speed braking, they probably aren't a huge improvement (for the price) over the stock brembos... but when you take into account high speed braking and track days, these are a lot better then the stock setup. They look badass too. These are the complete details of the kit I'm running.
09-04-2017, 11:00 AM | #98 |
Rep 969
Some Moar Pics :D
09-11-2017, 07:35 AM | #100 |
Rep 969
09-11-2017, 07:50 AM | #101 |
Rep 969
M Performance Big Brake Kit Review
Got the brakes coded over the weekend. Definitely recommend this if you pick up a BBK. Initial pedal feel and firmness has improved about 25% and brakes seem more responsive with the coded embedded. I've had some seat time with the car with many high speed braking. Overall, day to day driving their isn't a huge improvement over the stock brembos... pedal feel is about the same. There may be slightly less initial bite but that could be the more aggressive pads I'm running. It's barely noticeable once you've driven a few days with them. Once the brakes get a little heat in them, the stopping power is great. Where these brakes really shine is the high speed braking. The feeling is very linear and when the brakes are applied hard it will stop you in a hurry... absolutely no fade or performance decrease after multiple stops... which is a problem I experienced with my stock brakes (they started to fade and stopping power was reduced until they cooled back down.) Overall they are definitely an upgrade and I am happy I went through with them. Unless you are tracking the car or doing high speed braking, they probably aren't a huge improvement (for the price) over the stock brembos for daily driving... but when you take into account high speed braking and track days, these are a lot better then the stock setup. They look badass too.
kern4174449.50 peopleschoice135.00 |
09-11-2017, 08:17 AM | #102 |
Cheapskate
4450
Rep 4,993
that's crazy that you can code the brakes. i guess theres an electronic control between the pedal and the master cylinder?
09-14-2017, 09:56 AM | #104 |
Rep 969
Night Shot
Drifter2090909.50 F36GC_NYC159.50 |
09-14-2017, 03:46 PM | #105 |
Rep 1,876
Literally this should be a factory option. Love how the BBK fits in the wheel well. The grey blends in a bit too much but the red M performance and blue M Sport is nice though
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport |
F30_SixSpeed1170.50 F36GC_NYC159.50 |
09-15-2017, 08:06 AM | #106 |
Rep 969
09-16-2017, 08:30 AM | #108 |
Rep 832
Drives: 2019 G01 X3
Very nice and clean!
Are those max height on the KW V2 coilovers, or do you have some room to raise it up any higher? That clearance is lowww... |
09-16-2017, 09:57 AM | #109 | |
Rep 969
They are dual slate gloss black grills. I like them because they match my gloss black perfectly to my lower lip, side skirts and mirrors so it ties everything together imo. I got them at mod bargains. |
09-16-2017, 10:02 AM | #110 | |
Rep 969
Overall the KWs go pretty low. I heard the original versions... the rears at max height is stills drops about as much as h and r sports... so nearly 1-1.5" lower then stock at their highest setting. I have the revised version, so apparently they are better with height adjustment and fixed the original issue. I don't have any plans to raise them anytime soon though but there is room to go up. Hope that helps. |
dr.roro195.50 |
