12-26-2012, 04:39 PM | #1519 |
Rep 41,159
Yes, but just your Combox coding.
12-26-2012, 05:48 PM | #1520 |
Rep 52
12-26-2012, 06:45 PM | #1521 |
Rep 1,892
12-26-2012, 07:30 PM | #1522 |
Rep 52
Thanks frogman
Same by my german f30 model. This solution with the 2nd phone is so stupid! When the 1st phone isn't available the 2nd can only receive calls Otherwise you hve to change in the settings... Do i need more investigation on this, could you doublecheck this feature is correct? |
12-26-2012, 08:00 PM | #1523 |
Rep 227
Thank you awhk!! Not sure if I have an older version, but my module was REM_01 (instead of REF_01). I was able to turn the cold/warm check off for my rear turn signals and now am pretty sure that they do not flicker at all! This made my week. Excellent work!
12-26-2012, 09:01 PM | #1524 | |
Rep 204
BTW, do you mind sharing which LED bulbs you are using? How are they performing against stock bulbs? |
12-26-2012, 09:32 PM | #1525 |
Rep 72
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
Garage List 2021 BMW X6 M50 [0.00]
2018 Porsche 911 GT3 [0.00] 2015 BMW i8 [0.00] 2008 BMW M Coupe [0.00] 2017 Porsche 911 Tu ... [0.00] 1986 Porsche 911 Sl ... [0.00] 2021 BMW Alpina XB7 [0.00] |
I have a 2010 750Li which I know that this will work for, but what about a 2013 X5...does that require the E series process since it hasn't been updated yet to "F" status?
12-26-2012, 09:42 PM | #1526 |
Rep 41,159
The concepts are the same, but different tools are needed. Your E70 X5 requires a K+DCAN USB Interface Cable, and NCS expert Software to Code instead of an ENET Interface Cable and E-Sys Software.
12-28-2012, 09:36 AM | #1527 |
Rep 52
Hi,
Can I get rid of the Y-cable (Iphone) during coding? I there any hardware dependency? Do I have to change the USB/Aux plug? What hard/software requirements are necessary to use the normal Apple usb cable? Why: I'd like to enable the coverart music from my iphone - This all I want. After reading in several forum and sites I recognized, displaying coverart by Y-Cable is not possible, isn't it I have in my f30 only Navi Prof, with the base BT. I have NOT the extendet Bluetooth I have CIC and I have the combox. (i think so) I was able to code: BT Musik streaming 2nd Handsfree phone Coverart when using an USB Stick. When connecting the iphone by Y-Cable I have only the "Placeholder" for the cover. Music playing is everything great. (no connection possible with the white Apple cable) please help me, and hopefully this is not to bad english ;-) Last edited by dos1973; 12-28-2012 at 09:48 AM.. |
12-28-2012, 10:20 AM | #1528 | |
Rep 1,544
Can u PM me ur option codes using www.bmwvin.com? |
12-28-2012, 10:29 AM | #1529 | |
Rep 41,159
12-28-2012, 10:38 AM | #1530 |
Rep 52
@clarence
This is my vin:edited @shawn, i have documented all values in an xls file. Maybe not everything is necessary ;-) But still works. Whats your mailadress, i'll send you the file Last edited by dos1973; 12-28-2012 at 12:13 PM.. |
12-28-2012, 10:59 AM | #1531 |
Rep 41,159
Thanks. I PM'd you it.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 12-28-2012 at 12:22 PM.. Reason: VIN Removed |
12-28-2012, 11:42 AM | #1533 |
Rep 41,159
Interesting. According to your VIN, you have Basic BT, 6NH, but you also have 609 Nav Pro. I thought for 609 Nav Pro, you had to have BT Enhanced, 6NK/6NL.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 12-28-2012 at 12:21 PM.. Reason: VIN Removed |
12-28-2012, 11:46 AM | #1534 |
Rep 1,892
12-28-2012, 11:49 AM | #1535 | |
Rep 1,892
I agree that the whole way BMW handles BT and phones is a bit screwy and arcane. |
12-28-2012, 12:12 PM | #1536 |
Rep 52
12-28-2012, 12:21 PM | #1537 | ||
Rep 52
This could be so easy... |
12-28-2012, 12:25 PM | #1538 |
Rep 1,892
12-28-2012, 12:28 PM | #1539 |
Rep 41,159
Yes, and it seems [HU_CICHB] has built in Combox, as he has [Combox_Media] in his SVT.
The question remains how to enable BT Audio with 6NH and No 609 Nav. For someone with 6NH and no 609 NAV, what is the name of your CIC Module? Is it also [HU_CICHB], or is it something else?
12-28-2012, 12:31 PM | #1540 |
Rep 41,159
He has Combox built into his Head Unit with 6NH only, because of having 609 it seems.
