04-05-2018, 12:47 PM | #1 |
Rep 5,997
JB+ vs MPPSK for B58
So for $199 you can have more power than MPPSK which costs $3200. If you throw in an exhaust such as MPE for around $950 that's still less than half the cost. You can remove it in a minute, what is your guys' experience for those that have it on the B58, any issues with check engine lights or drivability, drivetrain malfunction, etc.?
04-05-2018, 01:23 PM | #2 | |
Rep 484
Drives: 440 xi MPPSK JB4
Location: Socialist People's State of NY - Long Island, NY
Check Engine, yes some times, Driveability, poor most times, drivetrain malfunction, probably not..
These quick boosters are quick fixes - you cant expect the same level of all above compared to MPPSK or even the JB4. And the MPE is a waste of money on this car... unless you remove the resonator.. then MPE plus that is great.. If I were to do it all over again coming from a MPPSK with a JB4 - the most expensive option I would get JB4 plus new mid pipe plus new muffler - this is the best option honestly Quote:
bimmer4562960.50 |
04-05-2018, 01:33 PM | #3 | ||
Rep 5,997
04-05-2018, 01:35 PM | #4 | ||
Rep 5,997
04-05-2018, 05:14 PM | #5 |
Rep 190,804
MPPSK is a waste of money.
For that kind of money you can go FBO and make a ton more power. You cannot go wring with a JB+ on a stock car. We offer 14 days money back guarantee if you wish to give it a try
04-05-2018, 05:49 PM | #6 |
Rep 1,772
jb+ has poor drivability. Low speed gear changes were atrocious and barely increased peak power. My personal opinion but do a search and there are others who say the same.
I've had all sorts of tunes and a proper ECU tune is always smoother and safer. It's more expensive but I wouldn't say a waste of money. |
04-05-2018, 06:49 PM | #7 | |
Rep 115,980
For the price its hard to beat, but you are correct a proper full tune like the JB4 is always advisable! Mike |
04-07-2018, 09:54 AM | #8 |
Rep 189
Until B58 flash tuning is available, MPPSK and JB4 is the best way to safely get the most out of the car, currently. There is a slightly higher fuel ceiling with the MPPSK and the JB4 allows you to run as safely as possible (as long as you configure it properly and datalog a lot to verify). Without datalogging, you have no idea how safe or unsafe your piggyback is running, no getting around that fact.
If you have the money, MPPSK and JB4 is the safest and smartest way to go. Otherwise, dilute it however you like. |
bradsm87594.50 |
04-07-2018, 10:16 AM | #9 | |
Rep 231
04-07-2018, 10:23 AM | #10 | |
Rep 189
I switch to Map 4/0 a lot just to see how the stock tuning reacts to current fuel and conditions. I rarely run meth on the street. Comfort vs. Sport makes no difference to me in regards to JB4 map. I have Sport set up to only stiffen the suspension. I go to Sport+ only when I want the exhaust to be obnoxious. I basically run Map 6 with an E25 mix, and Map 4/0 when only 91 octane is available. The additive/non-adjustable maps do not run well with the MPPSK since they are both trying to increase boost at the same time. This creates conflict and the power is not smooth at all. |
04-25-2018, 10:28 AM | #11 | ||
Rep 126
2017 340i xDrive
MPPSK More to come |
04-26-2018, 08:49 AM | #12 | ||
Rep 2,495
What sort of power are you getting with the JB4 and MPPSK??
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
04-26-2018, 09:48 AM | #13 | |
Rep 484
Dont even think to compare the two -
you get a sloppy power boost with JB+ MPPSK is smooth and linear plus the exhaust with flap control (from stock to very loud) If you want smoother acceleration get JB4 plus exhaust - that is most compared to MPPSK - but dont care about warranty JB+ many complain on shifts, smoothness, check engines (rare albeit), etc. Now if you dont care about drivability and the potential of check engine - then JB+ is for you. MPE is useless without the resonators removed... get a full catback exhaut OR just remove the resonators (dinan makes a mid pipe). Quote:
04-26-2018, 07:49 PM | #15 |
Rep 638
Had the jb + initially. Then went MPPSK. Not even close drivability wise. I haven't used jb4 since my 335is but a factory flash tune monitoring all engine parameters (not just afr and timing). No contest. It's expensive but no hassle. The exhaust sounds ridiculous if you do sport + with the crackles. It all comes down to cost. People will always advocate cheaper tunes but I've had every piggy/flash on Audi's and bmws. Stick to the flash + warranty for sure.
bimmer4562960.50 |
04-27-2018, 07:39 AM | #16 |
Rep 484
05-01-2018, 03:08 AM | #17 |
Rep 40
Can i just check, is MPE being mentioned simply the 'silencer' part of the M-Power exhsust system. Just seen a few videos of the full MPPSK and I'd certainly like the pops and bangs, but can't justify £2k on an exhaust system
Edit; Also, JB4 is what, an ECU remap? |
05-01-2018, 05:11 AM | #18 |
Rep 1,801
JB4 is a piggyback unit that tricks the car into producing more power. It give a decent chunk of power but it can result in driveability issues and you might need to tweak it.
The MPPSK is a full exhaust system with a BMW remap. BMW are the only people who can currently remap the B58s in these cars and the work doesn't impact warranty. The full MPPSK can be had for £1650->£1700 if you call around and it transforms the car. |
05-01-2018, 06:27 AM | #19 | |
Rep 5,997
05-01-2018, 06:33 AM | #20 |
Rep 40
thanks for the replies gents I've been looking at the MPPSK this morning. I am so damn tempted, especially because as a person I'd want it to be done by BMW and be covered etc. by them
Concerned it'd be far too loud on a motorway though. I've found a brand new set for £1500 on ebay with just a very quick look, though I'd want to go for the carbon tips. What's the sort of going rate for fitting of the entire system? |
05-01-2018, 08:24 AM | #21 |
Rep 1,801
£1650 is the going rate at Cooper Reading and one in Warwick.
Ask around and ask them to price match. The noise on the motorway is next to non existent if you put it in comfort. Put it in sport/sport+ and you'll hear it for sure! |
05-01-2018, 08:26 AM | #22 |
Rep 1,801
