01-26-2016, 11:10 AM | #200 |
Rep 695
Drives: 2021 M2 Competition
Garage List 2014 Porsche C4S Coupe [0.00]
2019 330ix Sportwagon [0.00] 2014 Jaguar F-Type ... [0.00] 2021 M2 Competition [0.00] |
Did mine on Saturday.
01-26-2016, 11:21 AM | #201 |
Rep 695
Removing the bumper cover seemed crazy to me. Too many things that could go wrong, so I removed the grills by just going through the slats. I used an old PC expansion slot cover to give me leverage especially with the bottom clips. I started with the passenger side working my way from the right side counter clockwise. The top clips are easier to reach than the bottom ones. Only the first one is hard. Getting out the second one took less than 30 seconds.
02-10-2016, 01:53 PM | #202 |
Rep 1,261
Sorry for bringing an old thread back, but I have to tell this to everyone who will listen: I'm not a DIY guy at all, and was able to change both gills in under 10 minutes, without removing the bumper cover or using any tools. And the old grills are perfectly intact.
Finally some benefit of having puny forearms and hands! |
03-04-2016, 09:07 PM | #203 | |
Rep 1,056
Damn it I might just break a few more blades and release the grill with fingers. Who knows this is harder than I was expecting.
03-05-2016, 09:30 AM | #204 |
Rep 1,056
I think because of the cold temperature, ~33F this morning. The plastic is not flexing enough.
Used some brutal force to get that mfkin clip off. Ripped it apart. Straight to the trash.
03-17-2016, 01:15 PM | #206 |
Rep 1,056
OEM is $99 from ebay.
04-04-2016, 05:44 PM | #207 |
Rep 174
Drives: 2020 F39 X2 xDrive28i
I am a girl and have small hands. I was able to do this switch without using other tools other than my hands
04-04-2016, 07:17 PM | #208 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
04-13-2016, 03:06 PM | #209 |
Rep 27
I'm thinking of doing this for my '16 4GC. Was the process much different or fairly similar to the F30 instructions above? Any help specific to the F36 would be appreciated. Thanks!
04-13-2016, 05:10 PM | #210 | |
Rep 778
04-13-2016, 07:39 PM | #212 |
Rep 27
05-12-2016, 11:12 AM | #213 |
Rep 943
Drives: 2012 328i Modern Line
Nice
08-23-2016, 07:49 PM | #215 |
Rep 58
I did this the other day. I tried the way described and it was PITA. I then took wd 40 and squirted it on all the latches. started to pull on it and it came right out. The SA at the dealership said thats how they do it. I was shocked at how well it worked. Kinda scary but it came right out super easy..
10-21-2016, 01:50 AM | #216 | |
Rep 1,986
This was so much easier than I was expecting thanks to your instructions and pictures. I figured 15-20 minutes was going to be needed just to get 1 grille out. Then the entire process actually took last than 10! Many Thanks! Agreed |
12-28-2016, 04:10 PM | #217 |
Rep 238
I was able to loosen up the top and sides of the stock grill with my fingers, but was having no luck with the lower. I read up some more and decided to go with the WD 40 and attempt to pull it out...it worked! Thanks for all the input from other forum members - greatly appreciated!
02-18-2017, 05:43 PM | #218 |
Rep 305
I just did mines on a 2016 328i LCI. There are 2 additional clips on the sides for a total of 8 clips. If you look at the OP's pics, you can actually see there are holes for the 2 clips on the side. After loosening the top clips, you must loosen the side clips in order to loosen the lower clips. Otherwise, you may think it's stuck and try to force the lower piece out and break something. Just a FYI.
03-26-2017, 10:44 PM | #219 |
Rep 128
So glad I found this thread!! I'm going to try the easy wd40 methods others have had success with, sans tools. I'm shopping around for carbon fiber grills for my f36 440ix GC.
Is Anybody here running cf grills? My front splitter is OEM cf so thinking the match may look good. Bummed bmw doesn't make the accessory part. I think I landed on giving RW Carbon's cf grills a shot. Never ordered from them before so we'll see how it goes. |
05-09-2017, 06:52 PM | #220 |
Rep 709
What type of paint and clear coat sprays is everybody using
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
