BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Golf Tee Mod
      11-28-2012, 05:00 PM   #23
340driver
Singapore
Drives: F15 Xdrive35i Pure Experience
It does!
Originally Posted by justinnum1 View Post
anyone else think the PPK would make the performance exhaust sound much better?
It does, go here http://www.bmw.com/com/en/owners/acc...es_sedan.html# click on Drivetrain, 335i PPK, and then image 4 which is a sound clip of the PPK with Exhaust (nice bubbling on the overrun). Image 3 is just PPK, and 5 is stock.
Good comparisons.
      11-29-2012, 06:35 AM   #24
rtgirard
1-5-3-6-2-4
Drives: Awaiting 2013 335xi -
Originally Posted by ric124 View Post
Nice then you dont need to do the mod.
Yea, plus the mod is pointless since there's no change in exhaust note.
Wait, mine does that too.
I even posted a video on here of it...left side closed, right side spewing exhaust on startup. Once it's warmed up, both are open and GTG.
I think this is normal and the flap is only closed on cold start. Has anyone else actually confirmed that it closes again after warmup while you're driving around?
      12-02-2012, 03:53 PM   #25
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
I actually can now hear my exhaust driving around town now. Its not loud but I can now hear it.
      12-04-2012, 01:31 PM   #26
rtgirard
1-5-3-6-2-4
I suppose if the normal function on your car is to shut the flapper while you're out driving, then yea that might make a difference. What you're describing seems to be normal for me. Since delivery I've been impressed with how loud the stock exhaust is... must be because once warm, my flapper remains open by default.
      12-04-2012, 01:55 PM   #27
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
Has anyone confirmed that it closes for eco-pro and comfort modes? Whenever I switch to sport, the exhaust gets noticeably louder.
      12-07-2012, 02:00 PM   #28
utenigma
Anybody interested in an override mod for the actuator? Thinking of intercepting the open/close signal at the harness and wiring it to a 3 position switch you could mess with while driving (open always, normal, closed always)
      12-07-2012, 09:26 PM   #29
MNBart
Drives: '22 X5MC; '97 M3
Anyone have a video? Sorry if this I a dumb question; I came from VW and just got my car
      12-19-2012, 07:01 AM   #30
RASHID007
Drives: 2014 535d X-Drive
Honestly, on cold start my car is quite loud with just the right-side pipe open. When the actuator opens the left-side flap (and the actuator is surprisingly loud), then the whole tone actually quiets down as the car finishes warming up. And furthermore, once the car is warmed up, I've yet to see the left-side pipe close up again... it seems to stay open all the time for me.
What do you mean by "the actuator is surprisingly loud". Do you have this sound which is driving me nuts?
http://www.f30post.com/forums/showthread.php?t=705415
      12-19-2012, 10:12 AM   #31
AWF30MSPORT
AWF30MSPORT's Avatar
Drives: '15 Porsche 981 Cayman GTS
I don't think the screeching sound in your video is from the actuator for the exhaust valve. Here is a video, below, where you can hear the sound of the actuator open after the engine warms up from a cold start. You can here it open at the 1:06 mark...
      12-19-2012, 01:27 PM   #32
RASHID007
Thank you so much. You are right, my sound is not as loud as the screeching in that first video. My sound is EXACTLY like the 1:06 mark of this video. Must be the actuator/flap opening.
So this is normal? It sounds so ghetto as I can hear it sometimes when I let off the gas pedal when driving in city streets.
      12-19-2012, 08:10 PM   #33
rtgirard
1-5-3-6-2-4
Yes... at 1:06 that's the actuator opening the flap. I tend to only drive in sport mode which seems to leave the flap open all the time.
I will say, though, that my wife drives around solely in comfort mode and she hasn't said a single thing about hearing the actuator while driving around town... and she would certainly say something if it was noticeable!
      12-21-2012, 10:46 PM   #34
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
So i did this. And after i did it. Apparently it wasnt tight enough, so there was movement down there. so i went back down to redo it. as i was taking off the wire to re-secure it again, i noticed that the too wouldnt line up if i decided to put the spring back in there. does the motor turn a bit more without the spring then it does with the spring (im guessing spring holds it back from going all the way) since there a grove in inside the exhaust to prevent the flap from going further then allowed.
If i look at the motor side if i were to put the spring on that side it wouldnt go in, the top of the spring wouldnt fit due to the bracket that holds the motor.
Can someone check to see if there is like that too? Has anyone tried to put the spring back?
BTW, does this waste more gas? After the mod i see my miles per tank dropping quickly.
      12-25-2012, 08:30 AM   #35
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
I don't see how it could effect the gas mileage. I guess anything is possible. I do see a difference between sport+ and comfort modes. Plus my driving habits could negatively impact my gas mileage.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      12-25-2012, 11:46 PM   #36
ƒ°
ƒ°'s Avatar
101
Drives: ✚
I had this same problem. I just put the clip in place and pushed it up against the groove and had a friend start up the car. As the actuator moved, the clip popped back into place.
Today I just disconnected the electrical harness and tucked it away. The flap remains open. Errors be damned.
      12-26-2012, 08:51 AM   #37
justinnum1
Drives: 2018 330i Msport 6mt
do you notice any sound difference? if so what?
also, fyi, you might not see a code but the dealer will see one. they probably wont care tho, such a minor mod
      12-26-2012, 10:36 AM   #38
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Yep. I did a test with an OBD reader. Nothing showed up but I'm almost certain the dealer service dept has more comprehensive diagnostic tools. As far as how loud it is... if there is any difference, it's really subtle. I'll let you know later tonight. I have a long distant drive today.
      12-26-2012, 05:23 PM   #39
UhhItsANT
So I take it you clipped the exhaust side in then turned on car then the motor side snapped into place on its on right? Clever!! I didnt think of that. Thanks for the info. My worries are gone now. haha. Didnt know how i was going to put it back on if i had to go into dealer for service.
      12-26-2012, 10:27 PM   #40
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Yup. But I had to be under the car holding the clip in place with pressure so that it would pop back in. Hope it works out for you.
      12-26-2012, 10:43 PM   #41
UhhItsANT
Ok. sounds kinda scary having to be to under the car holding it. Afraid it might pop and fly at me. Did you use any tool to help hold it in place, if so what tool? How fast does it actually turn?
      12-27-2012, 12:00 AM   #42
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Used a needle noise plier. It doesn't turn too quickly. Good luck!
      12-27-2012, 12:32 AM   #43
UhhItsANT
Also when you hold it. What is the best position to put the flap in? Open or close? So that the motor turns and snaps in. I'm afraid of it snapping in at the wrong position and risk of breaking something.
      12-31-2012, 06:51 PM   #44
ƒ°
ƒ°'s Avatar
101
Drives: ✚
So I've been driving around with the Actuator unplugged for the past week. It is definitely louder. There is a drone at highway speeds if you leave the RPM around 3k and above. However, on the highways, I usually try to cruise at 2.5k. So the drone isn't an issue for me. The sound is really pleasant. Try it out for a week.
