12-29-2023, 08:18 PM | #1 |
Rep 92
n55 f30 335i mod help
So I知 interested in going stage 2 with turbo upgrade for 400-500whp. I知 fairly new to the platform and my understanding is I値l need intake,dp,fmic,hpfp,turbo. Not sure if I should do pure turbo stage 2 or CTS boss kit based off the GTX3582R. There痴 lots of stuff about the pure turbo but requires a core exchange unlike the CTS turbo.
12-29-2023, 09:11 PM | #2 | |
Rep 316
read the thread below this one too |
12-30-2023, 06:18 PM | #4 |
Rep 92
So if I go with the pure500 would that be able to make the 4-500whp range? If so what would I need- intake,cp,ip,fmic,dp,hpfp?
Also what about Vargas gc? They claim 500-700hp(on gc+) |
12-31-2023, 12:59 PM | #5 |
Rep 7,624
You dont need an intake. You need CP, IC, DP bare minimum. With a turbo upgrade you also want turbo inlet, DV, and probably TIC. Then HPFP assuming you go DI for fueling.
12-31-2023, 01:05 PM | #6 |
Rep 92
12-31-2023, 02:11 PM | #7 | |
Rep 7,624
If you're just running something like a pure500 you might be able to use stock DV at those power levels if yours is in good working order, but labor wise it would make sense to replace it at the same time Then you decide what fuel you are going to run and what fuel system upgrade you want to do - e.g., hpfp |
12-31-2023, 02:13 PM | #8 | |
Rep 92
01-02-2024, 01:50 PM | #9 |
Rep 7,624
01-02-2024, 10:43 PM | #10 |
Rep 92
01-03-2024, 01:28 AM | #11 |
Rep 7,624
01-04-2024, 03:37 PM | #14 |
Rep 87
I had high hops for the boss kit from CTS but it seems to have the same issues from the mk7 platform. I had the kit on my 15 GTI and cracked the manifold within 1200 miles. makes me a tad sad because i love garrett turbos.
2015 335i M Sport EBII
M Perf Exhaust / M Perf Brakes / M Perf LSD / CTS FMIC / CTS Intake / CTS DP / CTS CP / BM3 / KWV3 / Vorshlag Camber Plates / 19" VMR V710FF / XHP stage 3 / Snow Perf stage 3 meth |
01-04-2024, 04:59 PM | #15 |
Rep 92
01-04-2024, 05:18 PM | #17 |
Rep 87
honestly a downpipe, intercooler, intake, hpfp and e30 with a custom tune would get you 420-440whp stock turbo... our ewg turbos are capable of 450whp according to several tuners I have spoken too
F30PJ0.00 |
01-04-2024, 05:39 PM | #18 | ||
Rep 7,624
450whp on stock turbo isnt really realistic. 420 is achievable but beyond that is truly pushing the stock turbo far out of its efficiency range and if you can make it on an optimistic dyno its not really sustainable or something you will consistently experience on the street. As i said above if you want to go max HP/$, get IC, CP, DP, turbo inlet, HPFP, and just run the stage 2+ BM3 E30 or flex fuel map with E50 fuel in the tank. No custom tune needed. |
01-04-2024, 06:00 PM | #19 |
Rep 92
01-05-2024, 07:11 AM | #20 | |
Rep 87
01-05-2024, 01:58 PM | #21 | |
Rep 7,624
And you should get a turbo inlet, even if you already have CTS intake. FYI i did test CTS (all testing done with an inlet, see my thread and the link to inlet thread in there). https://f30.bimmerpost.com/forums/sh....php?t=1765289 |
01-05-2024, 09:24 PM | #22 | |
Rep 87
