05-15-2016, 11:37 AM | #23 |
Rep 168
ya you should replace the caliper bolts once they've been removed as stated above. Also yes if there are no leaks you should be fine. The brake line fitting also shouldn't be tightened using a normal wrench you should use a flare fitting wrench as brake fitting are different then standard
05-16-2016, 11:32 AM | #24 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
He might not show a fluid leak right away if there is a lot of air in the line at the connection point from the fluid leaking out of the hose.
Expect he might have just unhooked the hose & let it hang down.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
