05-31-2017, 02:26 PM | #1 |
Rep 785
Best Place to buy Oil Change kit?
Any recommendations?
Some places vary in type of oil... Some come with a replacement drain plug and some do not.. Kinda confusing... ECS https://www.ecstuning.com/b-genuine-...11427640862kt/ GETBMWPARTS https://www.getbmwparts.com/partloca...catalogid=4462 https://www.getbmwparts.com/partloca...catalogid=4462 OW-30 vs 5w30?? |
05-31-2017, 03:15 PM | #3 |
SQUEAKY
104
Rep 322
I've always got my oil change service kits from ECS for Mercedes and BMW. Been shopping with them for years and they provide OEM parts. Highly recommended.
06-01-2017, 12:50 PM | #4 |
Rep 98
If you have a 4-Cylinder engine, then replacement drain plug should be included with the filter. Those cars have a plastic oil pan and plastic drain plug and the drain plugs are supposed to be for single use. 6-cylinder engine is a metal pan/drain plug and you can re-use the drain plug.
I've bought oil change kits from getbmwparts in the past, but recently switched to using Liqui-Moly 5W30 Special Tech oil (it's BMW LL01 certified) and noticed less "clatter" from my N20 engine (the 4 cylinder "normal" sound is like a diesel engine when first running cold). I bought it through bavauto along with their filter kit (which included a replacement drain plug).
2016 BMW F15 xDrive 35i - Imperial Blue Metallic 2014 Porsche 991- Sapphire Blue Metallic |
06-02-2017, 08:05 PM | #5 |
Rep 2,197
Call it crazy, but FCPEuro has a lifetime replacement on parts & allows you to return your used oil & filter! https://www.fcpeuro.com/BMW-parts/32...13&m=20&e=2122
Here's how you return the used oil: https://www.youtube.com/watch?v=kYsJc5BsPO4
FSociety3812.50 Broadsword79.50 |
06-06-2017, 02:50 PM | #6 | |
Rep 52
I believe this is the kit you need: https://www.fcpeuro.com/products/bmw...-11427640862kt Last edited by CarlosC; 06-06-2017 at 02:58 PM.. |
06-07-2017, 09:56 PM | #7 | |
SQUEAKY
104
Rep 322
06-10-2017, 09:13 AM | #9 |
Rep 864
Amazon
I am using PP EURO 5W-40 and found on Amazon for $7 then purchase 10 Mann Oil Filters at discount as well. Love ECS for their website and Bavauto & Getbmwparts but there are cheaper alternatives if you piece it together yourself.
06-29-2017, 02:26 PM | #10 |
Rep 785
Thanks for the advice guys. Any place you can recommend for me to buy the tool needed to remove the oil filter? Besides that I guess I need an oil pan and then I should be good to go?
06-29-2017, 02:47 PM | #11 |
Rep 52
I use this...works perfectly.
https://www.fcpeuro.com/products/vol...cta-tools-2489 |
07-03-2017, 06:22 PM | #12 |
Stark und Frei
48
Rep 155
07-06-2017, 04:11 AM | #13 | |
No 55mph
1621
Rep 8,476
You're just changing the oil - you need: OIL FILTER
07-06-2017, 10:15 AM | #14 |
Rep 785
07-06-2017, 10:30 AM | #15 |
No 55mph
1621
Rep 8,476
08-05-2017, 05:48 PM | #18 |
Rep 158
09-03-2017, 07:04 AM | #19 | |
Rep 79
Whodathunkit? |
09-03-2017, 07:43 AM | #20 | |||
Rep 466
Took advantage of the 5 qts and filter for 25$ at advance. Castrol edge synthetic stx. |
