BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Halogen to LED Upgrade H7
proTUNING Freaks
      02-19-2017, 11:27 PM   #1
fki2000
Drives: BMW 328i M Sport 2013
Has anyone upgraded their stock halogen lights with LED bulbs. Im talking about just the H7 low/high beam bulbs. If so, which ones did you use and have you had any issues with flickering? I can code out some stuff if someone sends me the codes for the low/high beams.
      02-20-2017, 02:22 AM   #2
hakisalapaki
Drives: BW 2012 F30
yes i did.I replaced with runstreet R3 9600 lm 6500 k.No flikering used with canbus decoder.
      02-20-2017, 02:51 AM   #3
Jchn
Drives: F30 328i
How's visibility now? Is it BRIGHT and light up the road a decent distance? I have Diamond Visions but I plan on upgrading to LEDs
      02-21-2017, 04:49 AM   #4
hakisalapaki
Drives: BW 2012 F30
the 9600 lms are very bright.I you use these you will not go back to halogens.
      02-21-2017, 04:56 AM   #5
hakisalapaki
Drives: BW 2012 F30
here is the picture
fki200030.00
      02-21-2017, 09:30 AM   #6
fki2000
here is the picture
That looks really good. I just ordered LED low beams from xenonhids.com. Pretty expensive but i hope they are worth it. May get high beans later if I like them. Will update when I install them.
      02-24-2017, 08:06 AM   #7
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
Yes i did too. Very satisfied.
Check my post
LED replacement for Halogen lowbeams http://f30.bimmerpost.com/forums/sho....php?t=1349409
      02-27-2017, 04:00 PM   #8
zcspec
zcspec's Avatar
214
Drives: 911/Boxster/Model Y
While LEDs provide better lighting, the main problem you'll have is the extensive glare they produce. It blinds on-coming traffic and the vehicle in front of you. I tried quite a few different variations in my wife's X3, but could never get rid of the glare and ended up going back to halogen bulbs.
      02-27-2017, 04:45 PM   #9
scostu
scostu's Avatar
Drives: 2016 F25
If you have a couple extra $$ laying around .....get projectors and add LED...
http://f30.bimmerpost.com/forums/sho....php?t=1257101
http://f30.bimmerpost.com/forums/sho....php?t=1274932
      02-27-2017, 07:56 PM   #10
ikehigh05
Drives: 2011 328i xdrive
I wanted to originally go with USR halo projectors, but i was a little worried about possible issues and having to take the car bumper off numerous times to correct them. I purchased the "Rigidhorse H7 80W 8000lm 6500K CREE LED Headlight Bulb Conversion Kit, Cool White" from amazon to replace my halogen setup.
Im very impressed with them, mostly because they do not scatter light. They dont produce glare to other drivers, as they were engineered to replicate the location of the filament of a halogen bulb. The light is focused toward the ground and actually have a cut off. Paired with led DRLs, led parking lights, and led front turn signals, and i love my setup.
I did have to code the low beams because they flickered.
scostu1623.00
      02-27-2017, 07:57 PM   #11
fki2000
I would love to do this one day but for now ill just stick with some LEDs
      02-28-2017, 03:28 AM   #12
scostu
scostu's Avatar
Drives: 2016 F25
Looks like a big heat sink.
Did you have to modify the dust/weather caps on back of headlight housing?
I'm guessing you mounted the LED drivers in the engine bay outside of the headlight housing?
      02-28-2017, 06:47 PM   #13
ikehigh05
The heat stink isnt that big. There is still plenty room in the headlight housing after installation. Heck, there is even enough room to fit the led drivers in the housing. I mounted them outside of the headlight housing like you assumed. And actually, the led driver and head stink dont get too hot, even after a hour long drive.
scostu1623.00
      02-23-2018, 01:16 PM   #14
falome2
Drives: 2014 F34 BMW GT
H7 - Halogen to Led
Hi,
I suppose you ordered Low Beam: H7 LED Headlight Kit, Do you need to install warning cancellers?
https://www.xenonhids.com/low-beam-h...t.html?i=0vLDk
Please let me know your review after installation, any error display on dash and glare issues? these days with any H7 halogens I feel beaten as most cars even the basic cars come with white lights and we are affected by visibility due to other cars getting high power lights, we are blinded. I got no other option than replacing bulbs as I own F34. Your response is much appreciated. All other fellow members, please suggest me any option that can fit in my car.
      02-23-2018, 03:02 PM   #15
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Read this:http://f30.bimmerpost.com/forums/sho....php?t=1377259
The price at your link is at least double what you should be paying. Once you go LED on the lows you wan't want to leave halogens in the highs and fogs, the LEDs are that much better.
      02-26-2018, 12:54 PM   #16
falome2
Wow! Thank you. Great work on your GT. The level of work you had put in requires lot of facilities. Unfortunately, I don't have a garage to work on my car neither have a spare car to drive while working on the car. So If I am doing it on my own, I have to stick with swapping out the factory H7 with Led with No coding or I have to find a tech shop that can help me through this. I know you mentioned coding is mandatory, all I know is I am not giving up until I find a solution for my case. If you know any techs that can help please let me know.
      02-26-2018, 02:26 PM   #17
Billfitz
Billfitz's Avatar
The only facility I used was my driveway. There's no such thing as no coding LED, no matter what the ads may claim, because the way that halogens and LEDs produce light is fundamentally different. Cars that don't have sophisticated electronics can swap LED for halogen, but BMW does have sophisticated electronics.
      02-27-2018, 09:12 PM   #18
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Forgive me for jumping in late...
Ive been looking to upgrade my halogens for some time now... other than a compatible, quality bulb - Im hearing that I will need coding as well to complete the upgrade...
Can this be accomplished with BimmerCode? This is the only coding I have done with my vehicle so far...
      02-28-2018, 08:58 AM   #19
roma3
Drives: F30 328i xdrive
Hey, so I just bought some LED h7's - will post a review soon, but initially light output is a bit better and beam pattern is similar to halogen (almost no glare)
LEDs are copycats of the Supernova V.3 (from headlight revolution)
Edit: Review Complete!
https://f30.bimmerpost.com/forums/sh....php?t=1694287
      02-28-2018, 09:55 AM   #20
sspade
sspade's Avatar
Drives: F30
Please do. Pretty much clueless as to which direction to go at this point. Main goals are a whiter / less yellow color and increased down road visibility. Definitely not into a blue, non factory look. Appreciate any tips and info.
What I have determined so far is:
1. H7 is the low beam part number
2. Coding may be necessary?
What are the other bulb/part numbers? I dont need DRL because I have them coded off. Just high beam and fog...
      02-28-2018, 11:18 AM   #21
Billfitz
Billfitz's Avatar
H7 signifies the shape of the bulb base that fits into the lamp socket and the connector. With LED coding is absolutely necessary. Did you read this? I know you said you came late, but it's posted only three posts above your arrival.
      02-28-2018, 12:30 PM   #22
sspade
sspade's Avatar
Drives: F30
SDcgc2lnbmlmaWVzIHRoZSBzaGFwZSBvZiB0aGUgYnVsYiBiYX NlIHRoYXQgZml0cyBpbnRvIHRoZSBsYW1wIHNvY2tldCBhbmQg dGhlIGNvbm5lY3Rvci4gV2l0aCBMRUQgY29kaW5nIGlzIGFic2 9sdXRlbHkgbmVjZXNzYXJ5LiBEaWQgeW91IHJlYWQgdGhpcz8g SSBrbm93IHlvdSBzYWlkIHlvdSBjYW1lIGxhdGUsIGJ1dCBpdC dzIHBvc3RlZCBvbmx5IHRocmVlIHBvc3RzIGFib3ZlIHlvdXIg YXJyaXZhbC4KW3VybF1odHRwOi8vZjMwLmJpbW1lcnBvc3QuY2 9tL2ZvcnVtcy9zaG93dGhyZWFkLnBocD90PTEzNzcyNTlbL3Vy bF0=
Woops. I have to admit... I am occasionally guilty of typing questions before doing a ton of research before hand.
Appreciate the link. Will definitely be looking at your post in detail when I have a minute or two.
My confusion with the coding aspect is now clear... I am now understanding that switching to LED will require coding for sure while switching to brighter Halogen bulbs like a Sylvania, etc. will not.
