10-10-2022, 11:04 AM | #1 |
Rep 174
Drives: BMW 540ix
Is the inner tail light LED replaceable on F33?
I recently purchased a 2014 435i Convertible and just noticed the other day the Left inner tail light (on the trunk lid) does not light the 3 "tubes".
Is the LED chip replaceable or do I need to find the complete inner light assy to fix this? Odd thing is the is no bulb out warning for this piece so I never though to check to see if all the lights were functioning. |
10-11-2022, 05:51 PM | #3 |
Rep 174
Drives: BMW 540ix
It does not appear to be a separate piece from BMW. Just wondering if anyone found a solution other than replacing the inner light assy.
10-11-2022, 10:33 PM | #4 |
Rep 16,089
If mine went I'd figure out a way to fix it, but I'm an electrical technician. It probably requires disassembling the lamp. I wouldn't have a problem doing that either, but I've got so many tools in my garage that there's hardly any room left for the car.
11-03-2022, 05:37 AM | #5 |
Rep 968
as far as i know the LED itself isn't replaceable. the tail lights also can't be taken apart as easily as headlights, the lenses are ultrasonically welded to the housings so you'll have to cut the lens where it meets the housing, then replace the LED on the board (if it's the LED itself that's burnt out), and reseal the lens
11-03-2022, 11:59 AM | #6 |
Rep 16,089
Removing the lenses is easy, if you have the right tool. This is the right tool:
https://www.amazon.com/Central-Purch.../dp/B072MY649R It's a tool that you very seldom need, but when you do need one they'll do cutting jobs that nothing else will. |
11-03-2022, 06:44 PM | #7 |
Rep 174
Drives: BMW 540ix
I am looking at just buying a used tail light and moving on. Just wish an inop bulb didn't cost so much to replace.
