BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 335i M Performance Exhaust Install DIY (with Exhaust Clips)
      03-24-2015, 06:04 PM   #45
TriniJots
Driver
Trinidad_and_tobago
Drives: 435i
Is this the same process for the 435i?
      03-24-2015, 06:18 PM   #46
Jadar
Jadar's Avatar
Serbia
1054
Drives: 2013 F30 335i MSport
It's the same muffler no difference. Maybe the length of the tips may be different but I doubt it, but that wouldn't affect the install process.
FBO-PS1 and stuff
      03-24-2015, 06:19 PM   #47
tboooe
tboooe's Avatar
557
Drives: F36 428i GC, E36 M3 - gone :(
Yes same process. I did this with my 428.
      05-20-2015, 11:01 PM   #48
KELVIN7
KELVIN7's Avatar
Drives: F30 335i M Performance Edition
what is the valve plug for?
2016 Mercedes Benz W205 C63S AMG
2014 F30 335i M Performance Edition: 8AT | FBO
2011 E92 335i M-Sport Fully Loaded (Sold)
2011 E92 328i (Sold)
2012 Lancer Evolution X MR (Sold)
      05-31-2015, 01:37 AM   #49
KELVIN7
KELVIN7's Avatar
What about if i just simply unplugged the wire, is the valve still would be opening?
      06-01-2015, 12:05 AM   #50
Jadar
Jadar's Avatar
Serbia
1054
Few have done this when the valve is in the open position. I've heard that there are no issues. Only thing is if you take it in To a dealer and they read diagnostics that will come up.
FBO-PS1 and stuff
      10-03-2015, 01:18 PM   #51
zman1237
zman1237's Avatar
25
Drives: F32 428i M-Sport, M6
I have the 428 and I'm putting a 335 on it. Which clamp do I buy? The 428 or the 335?
      10-03-2015, 02:21 PM   #52
Jadar
Jadar's Avatar
Serbia
1054
Neither clamp will work. You have to have a custom exhaust piece made. Or you can have them weld them together.
FBO-PS1 and stuff
      10-03-2015, 02:25 PM   #53
zman1237
zman1237's Avatar
25
Okay thanks. And this is because I have the f32?
F32 M-Sport
F12 M6 Competition
      10-03-2015, 02:28 PM   #54
Jadar
Jadar's Avatar
Serbia
1054
No not at all, it's because your 428i exhaust is like 2.75" inches and the 335i is about 3.10" I measured it with a caliper. So ultimately and exhaust shop will have to fab up a piece for you that can slide on your 428 exhale and the stock 335 muffler. Then they can either weld them together or use U clams.
In either case it's not hard or expensive don't let them b.s. You!
FBO-PS1 and stuff
      10-03-2015, 02:51 PM   #55
zman1237
zman1237's Avatar
25
Excellent! Thank you for your help. That really cleared things up for me.
F32 M-Sport
F12 M6 Competition
      10-03-2015, 02:58 PM   #56
Jadar
Jadar's Avatar
Serbia
1054
Not a problem.
FBO-PS1 and stuff
      01-10-2017, 02:17 PM   #57
Polo08816
Drives: 2014 335i M Sport
I removed the complete exhaust this past weekend. It's part of my write-up for a dry run of removing and replacing the rear diff.
http://f30.bimmerpost.com/forums/sho...9#post21090999
The write-up has a PDF attachment that includes ISTAD procedures on how to remove the complete exhaust.
Originally Posted by Polo08816 View Post
I drove my sleepy self to the Auto Crafts Shop at a nearby military installation at 7am in the morning. BRRRR! It was 11F. I was the first (and only) person to arrive around 7am. Yes, I know… I’m crazy… or so I’m told.
I had the opportunity to do a more thorough reconnaissance of this rear diff removal/replacement procedure this weekend. This is a partial dry-run for a future diff swap. I’m still deciding between the BMW M Performance Limited Slip Differential (LSD) and another aftermarket clutch based LSD. In the end, I probably see myself going with the BMW M Performance LSD. I will probably keep the original final drive in case I would like to use it as a core unit for aftermarket clutch based LSD in the future.
Swapping out brake pads (equipped with M Sport Brake Option)
I began by swapping out F80/82 M3/M4 brake pads (OEM - Textar) for my original M Sport Brake Pads (OEM - Jurid). It’s been getting colder and I prefer to have a bit less brake dust in the months when I’m can’t wash the car outside as often. Brake fluid remains the same with Castrol SRF.
I’ll miss the better feel of the M3/M4 brake pads. It feels more linear and provides greater braking force at higher speeds, but they’ll be back in action sometime in the spring in anticipation of more AutoX and HPDEs. I always use Permatex Ceramic Extreme Lubricant and never have an issue with noise with hotter/more abrasive pads if applied properly.
Now we begin to remove components to get better eyes on the entire propeller shaft… I simply followed the procedures in the PDF I have attached with this post.
Removing center chassis reinforcement plate.
Removing the complete exhaust. I’m not a fan of cutting the exhaust so I decided to remove the complete exhaust. You’ll need another person to help you (my GF who has a 2016 X3 35i). You’ll also want to have 2 jack stands to support the exhaust.
Slackening (and then eventually removing) center exhaust mount. Requires E10 socket (Inverted Torx bit)
Slackening (and then eventually removing) mounting brackets at axle back (muffler) section.
Loosening the V-band that mates/seals the downpipe to the catalytic converter section of the complete exhaust system. This takes a bit of effort as the bolt and nut are heavily rusted. This is normal. I was able to do it with a standard 3/8” drive ratchet. You cannot re-use this part. It’s one time use which means you better seat it properly when you are re-installing the exhaust.
Exhaust removed.
Once you remove the exhaust, remove the heat shields. You can probably do the LSD removal/install by removing the heat shield furthest to the rear, but I removed both heat shields because I wanted to get a good look at the transmission, transmission mounts, flexible disc, and forward portion of propeller shaft as well.
      03-16-2017, 06:00 PM   #58
slief
Drives: 2014 335i
Originally Posted by Dejan_ View Post
As I said here is my DIY for the M performance exhaust. Not very difficult. The dealerships charge hundreds of dollars to do this and its so easy. It took me about 1h and 15m because I took photos and stopped a couple times.
I paid $900 for the exhaust shipped to my door and $0 for installation.
Please do this at your own risk. Iam not responsible if you mess something up. If you feel like you cant, dont attempt it. Take it to someone.
Tools:
Exhaust cutting tool, I rented one at Autozone for $50
Ratched
17MM socket
Wire (golf tee mod)
Wire cutter
Pry bar or screwdriver.
Car ramps or jack stands.
If you guys have any questions just ask. Hope this helps, and Enjoy the exhaust.
Sorry for the few typos I was typing fast trying to get done so I can go watch the Bears game.
EDIT: Fixed Typos.
Attachment 783577
Attachment 783578
Attachment 783579
Attachment 783580
Attachment 783581
Attachment 783582
Attachment 783583
Attachment 783584
Attachment 783585
Attachment 783586
Attachment 783587
Attachment 783588
Attachment 783589
Attachment 783590
Attachment 783591
Attachment 783592
Attachment 783593
Attachment 783594
Thanks for the great write up! I will be getting my M Exhaust hopefully end of next week and plan on tackling this myself as soon is it arrives. Your DIY just convinced me not to bother taking it to the exhaust shop and will be very helpful. Now to call my local Autozone to see if they have the exhaust cutting tool. Thanks again for the very informative post!
Jadar1054
      03-22-2017, 05:51 PM   #59
slief
Drives: 2014 335i
Just wanted to thank the OP again for taking the time to document the install. I got my CPO 14 335i about a month ago and immediately added the CF Mirrors and CF Spoiler. Also on my list was exhaust and some others items which have yet to be purchased.
My M Performance exhaust arrived today. I stopped by AutoZone on the way home to borrow their exhaust cutter. I can't believe they don't charge a rental fee. Just the refundable deposit. I got home and jacked the car up and put it on jack stands and dove right in. The exhaust cutter cut the exhaust like butter. I was done with the whole swap within an hour including some adjustments. It definitely sounds more agressive. I wasn't after something too loud but instead more subtle and I think I got just that. Take a ride back to AutoZone to return the cutters and get my deposit back and enjoyed the new exhaust sound. Very different sounding for sure. Looking forward to breaking this thing in but this now has be seriously thinking about the MPPK next.
If any of you are thinking about taking this project on yourself, I would encourage you to do so. It's really easy and I am very glad I didn't pay somebody to do it for me. Granted, I am long time DIY'er but this was really simple even for somebody who hasn't much experience working on cars and it is very self gratifying.
Here are some pictures. I need to black the lower part of the rear bumper out so it looks like a diffuser. That or get the M Sport bumpers which is on my list of things to do. Vinyl wrap may have to do in the meantime which is be another project I will take on myself.
The old exhaust removed.
Cut pipe before cleaning up and removing the dent.
Clamps in place.
Exhaust in before carbon fiber tip install.
Carbon fiber tip in place for final adjustments.
All buttoned up.
Jadar1054
      03-22-2017, 06:43 PM   #60
Jadar
Jadar's Avatar
Serbia
1054
Clamps in place.
All buttoned up.
Great job, those CF tips look so sweet. The satisfaction of doing it yourself and enjoying the fruits of your labor nothing like it.
The exhaust will get louder give it about 1,000 miles that packing will settle and you'll love it.
Congrats.
FBO-PS1 and stuff
      08-04-2017, 09:42 PM   #61
moorty
moorty's Avatar
Drives: 2014 328i
Tools:
Ratched
17MM socket
Wire (golf tee mod)
Wire cutter
EDIT: Fixed Typos.
Attachment 783577
Attachment 783578
Attachment 783579
Attachment 783580
Attachment 783581
Attachment 783582
Attachment 783583
Attachment 783584
Attachment 783585
Attachment 783586
Attachment 783587
Attachment 783588
Attachment 783589
Attachment 783590
Attachment 783591
Attachment 783592
Attachment 783593
Attachment 783594
VIDEOS:
Took some videos before and after I bolted on the M Performance. I used my Iphone5 so hope it came out ok. I pointed the speaker towards the exhaust for better sound.
EDIT: Here is the video after 1000 miles. Its "borken in". I think it sounds deeper, and it did get louder. I expected this reading up on past threads. I think its the perfect amount of exhaust noise and its not intrusive at all. If you get a killer deal on it I suggest get it.
Its a warm start, revs are up to 4k, golf tee mod done flap fully open. I started in comfort mode and switched to sport in the end of the video.
Very nicely done, thanks so much for the write up. Did you use replacement hangers or just what came with the car? I can't get the tips to stay high, no matter how I tighten the clamp the tips sit too low. Any suggestions?
      08-05-2017, 07:39 AM   #62
Jadar
Jadar's Avatar
Serbia
1054
Tools:
Ratched
17MM socket
Wire (golf tee mod)
Wire cutter
EDIT: Fixed Typos.
Attachment 783577
Attachment 783578
Attachment 783579
Attachment 783580
Attachment 783581
Attachment 783582
Attachment 783583
Attachment 783584
Attachment 783585
Attachment 783586
Attachment 783587
Attachment 783588
Attachment 783589
Attachment 783590
Attachment 783591
Attachment 783592
Attachment 783593
Attachment 783594
VIDEOS:
No need to replace the hangers. Try to tighten the clamp a bit more and adjust. That's the way it gets set. Not really any other way.
FBO-PS1 and stuff
      08-08-2017, 06:58 AM   #63
B328iboy
Drives: BMW 328i F30
very nice !
      08-09-2017, 11:07 PM   #64
daMANiack
daMANiack's Avatar
Drives: BMW F26 X4 35d
Hi,
Did you notice you had condensation dripping from the extension on the last 2 videos, just a comment?
Cheerz
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
