09-26-2015, 10:10 AM | #45 |
Rep 9,004
So serious question what are you guys using to season your steaks, and how long do you let it marinate for? I don't have a grill...because I'm a sad sad man, I might have to use a forman.
09-26-2015, 12:58 PM | #46 |
is probably out riding.
6058
Rep 2,292
I use a dry rub. Press it into the top, bottom and sides of the meat. Usually do that about 30 min before going on the grill.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
09-26-2015, 01:28 PM | #47 |
Rep 9,004
09-26-2015, 01:44 PM | #48 |
Rep 700
Wife asked for a fancy meal last night so I made this.
Dry aged NY Strip (whole foods) wild mushroom risotto, and some roasted asparagus. Creme brûlée for dessert. Sorry forgot to take a picture of the inside. They were prepared med-rare. |
09-26-2015, 03:12 PM | #50 | |
Smiling Politely
1381
Rep 29,118
Last nights dinner.
09-26-2015, 08:59 PM | #51 |
6058
Rep 2,292
I use a "proprietary blend", but this stuff is damn good.
09-26-2015, 09:03 PM | #52 |
6058
Rep 2,292
I'm glad i came in here after dinner! ^^ ALL that looks good!
Whipped this pie up tonight. Sausage is from a hog i killed and had processed. The processor i took it to has won awards for his Italian sausage. It's the best tasting and leanest sausage i've ever had.
09-27-2015, 08:53 AM | #54 | |
Rep 1,195
09-27-2015, 08:57 AM | #55 |
Rep 9,004
09-27-2015, 09:35 AM | #56 |
Rep 1,563
This will help you understand. Sous vide cooking on the left, normal grill on the right
Sous vide cooks down to the exact degree that you want and maintains the temperature exactly until the entire piece of protein is cooked evenly. With grill cooking if you want a nice sear on the outside but with a pink center than you will inevitably burn the outer layers of the meat, leading to a chewy and tough texture. Sous vide is perfect. Use it to actually cook that steak to whatever temp you want, and then grill over super high heat for about 30 seconds per side max. This will get you best of both worlds - perfectly cooked meat, plus the maillard reaction for flavor on the outside and a nice look. Pretty much all of the top steak houses in the world now cook this way. It is also called immersion circulator cooking. I have had good results with this sous vide machine. Just keep in mind you will still have to sear the steaks coming out of the sous vide to get a nice color and char flavor. Coming out of the sous vide they do not look appetizing without a sear. http://www.amazon.com/Sous-Vide-Supr...ustomerReviews Last edited by paradoxical3; 09-27-2015 at 09:41 AM.. |
09-27-2015, 10:00 AM | #57 |
Rep 2,011
Very cool, read up some. But not all have that m/c. I use the Traeger wood pellet grill, works well. I also try to buy usda prime steaks only. My local Weis has em.
335i e92 TPC 19Ts
09-27-2015, 10:44 AM | #58 | |
Rep 9,004
Edit: not bad actually! |
09-27-2015, 01:01 PM | #59 | |
6058
Rep 2,292
Thanks.
No, it's a pre-made dough ball from the local grocery store but we toss and stretch it into pizza crust. Making *good* pizza dough in small batches is difficult. Quote:
If the heat is controllable on your grill, you can do a darn good job at having everything cooked evenly. Next time i make a steak i'll post of pic of one of them cut in half. I would say that about 95% of my steaks are cooked to the same doneness. The 2.5% sacrifice on the top and bottom are worth it for the flavor the charcoal delivers.
09-27-2015, 01:19 PM | #60 | |
Rep 1,420
09-27-2015, 09:03 PM | #61 |
Rep 81
09-27-2015, 10:26 PM | #62 | |
Rep 1,420
But none of those in the picture above have any good color on the outside of the meat.
09-29-2015, 11:36 AM | #63 | ||
Rep 4,392
Drives: 2022 F97 X3M Comp LCI
i have gone through many cuts of meat to get it right. take lots and lots of practice. Quote:
if mixed properly, every bite of the pasta will contain the sauce that you made it with. it will taste so much better that way.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
09-29-2015, 11:44 AM | #64 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
I eat my steak medium-well.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
09-29-2015, 12:22 PM | #65 |
6058
Rep 2,292
This should look very appetizing to you.
09-29-2015, 12:45 PM | #66 | |
Long Time Admirer, First Time Owner
17998
Rep 9,378
