      12-19-2012, 02:23 PM   #1453
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Originally Posted by BMWs
So since I don't have switch, I still won't be able to select it Well, I can by disabling DSC. My goal is to find the code to only stiffen the steering (default sport).
Thats the holy grail of coding. Many coders have died trying to find it
      12-19-2012, 03:11 PM   #1454
demge01
demge01's Avatar
Drives: F30 320ed
You don't have a drive mode select switch?
I thought all F30s had this.
      12-19-2012, 03:44 PM   #1455
clarence
Drives: F30 328i M-Sport
It's a F25.
      12-19-2012, 07:12 PM   #1456
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Originally Posted by tractorman View Post
Great info and thread Shawn.
Can you post me a link to the the 48.1 data.
Thank you in advance!
Posting of links is not allowed, and you have too few Posts to receive PM's.
So, post your email, and I can send you the information you need.
He can now receive PMs.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      12-19-2012, 07:15 PM   #1457
shawnsheridan
shawnsheridan's Avatar
Indeed. PM sent.
      12-19-2012, 07:47 PM   #1458
kon
Singapore
Drives: F30 310i > G20 310i
Originally Posted by clarence View Post
Did u get BT data transfer working?
Mine was working since day 1 as I have Internet function came pre-loaded.
      12-19-2012, 10:45 PM   #1459
henryeeex
Drives: 2013 335i
Indeed. PM sent.
Hey Shawn,
New to the forums and interested in coding my car. Mind posting the link of the data to laih88 at gmail dot com?
much appreciated!
      12-19-2012, 11:11 PM   #1460
clarence
U mind using bmwvin.com & PM me ur option codes?
      12-19-2012, 11:12 PM   #1461
clarence
U got voice control?
      12-20-2012, 12:06 AM   #1462
awhk
Drives: 2023 iX M60 SBM
Have found the following info from the F25 X3 forum regarding disable cold/warm light check for certain bulbs. Useful for replacing the standard incandescent bulbs with LED replacements.
http://x3.xbimmers.com/forums/showpo...2&postcount=18
Originally Posted by pacecapt View Post
I am attaching an Excel Spreadsheet with the coding fixes for LED Bulb Errors, using this fix you can install any LED bulb that fits the socket. Coding was done using BMW E-Sys Software and Cable that I purchased from April1. I started coding about 2 months ago after discovering that this was an option to personalize my F10 and F25 BMW’s. This posting is not about “how to code” but will give those coders the directions to fix the bulb errors. This sheet only contains the codes I changed, I was able to figure out the nomenclature for some of the bulbs and I will list those below.
NSW: Front Fog Lights
NSL: Rear Fog Lights
RFS: Reverse Lights
BL: Brake Lights
FRA_HL or HR: Rear Turn Signals (Left or Right)
FRA_VL or VR: Front Turn Signals (Left or Right)
WBL: I am uncertain but believe this is the Rear LED Brake Strips on HID equipped F25’s.
Since the F30 does not have FRM module, I've ran a search and found something similar to the F25.
In the Frmbody module > 3061 LceLciOutputChannels, 67
TFL_L or R: front LED corona rings L or R
NSW_L or R: front fog lights
FRA_V_L or R: front turn signals
Here are other names in that channels that need to be checked:
AL_L or R: brake lights?
POL_L or R: are LEDs according to the settings, maybe the parking light strips on the tail lights.
FL_L or R: not LED
SML_L or R: not LED
FRA_Z_L or R: most likely mirror turn signals as the setting is set to LED as default
BIX_L or R: name looks like Bi-xenon?
LCI_0: LED
LCI_1: LED
LCI_2: not LED
LCI_3: LED
LCI_4: LED
LCI_5: LED
LCI_6: LED
LCI_7: LED
LCI_8: LED
Settings are similar as well
WARMUEBERWACHUNG - Warm Check
KALTUEBERWACHUNG - Cold Check
IS_LED - Indicate the bulb is LED
      12-20-2012, 04:08 AM   #1463
kon
Singapore
yes
      12-20-2012, 05:58 AM   #1464
shawnsheridan
Originally Posted by HenryX View Post
Hey Shawn,
much appreciated!
PM sent.
      12-20-2012, 12:58 PM   #1465
SuperTee
Blubb.
Switzerland
Drives: X6M (F86)
I finally managed to get everything ready. Mine is built on 10th Octobre.
What I tried:
- the two settings for the turn signal in hud
- the hud_nbt (I think it was there) entertainment list
well, both don't work, but for the entertainment list there is at least a checkbox in the hud settings: entertainment/telephone. Unfortunately I can't check it..
Will need to read first, I guess, and see what's possible with the new ones..
      12-20-2012, 01:00 PM   #1466
shawnsheridan
What I tried:
Look in your KOMBI, not your CIC (NBT) module.
      12-20-2012, 01:10 PM   #1467
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
I've been told it does not work at all in the f30 (the HUD turn signals that is) I cannot test for myself since I don't have the HUD.
But the golden rule of this forum is; always listen to Shawn
      12-20-2012, 01:50 PM   #1468
SuperTee
Blubb.
Switzerland
Drives: X6M (F86)
I've found the hud_entertainmentlist, just don't know where it was.. Do I need to activate two settings for that?
      12-20-2012, 03:03 PM   #1469
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
This is where it is in the F25:
To display entertainment information in your HUD (only shows when you scroll with the steering wheel roller switch)
KOMBI/3000/HUD_ENTERTAINNMENT_ENABLE--->Aktiv
To display incoming phone information on the HUD:
KOMBI/3000/HUD_TELEFONANRUF_ENABLE--->Aktiv
To display previous phone list on the HUD (activated by the telephone button on the steering wheel):
KOMBI/3000/HUD_TELEFONBUNCH_ENABLE--->Aktiv
To display the voice commands on the HUD (activated when you press the voice command button on the steering wheel):
KOMBI/3000/HUD_SPRACHEINGABE_ENABLE--->Enable
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      12-20-2012, 11:53 PM   #1470
YXY
Japan
Drives: F31 320d touring mineral white
Shawn,
I'm trying to code my F31
Please post the link of the newest data to sugamoto at hotmail dot com?
very appreciated!
      12-20-2012, 11:56 PM   #1471
kon
Singapore
This might sound stupid, but how do you unplug the enet cable when you're done coding? It's super easy to plug in, but I have to use considerable amount of force to unplug it to a point I'm afraid I might break something
Is there a easy/easier way to do this?
      12-21-2012, 01:07 AM   #1472
Frogman
Drives: 2012 F30 328i
I assume you're talking about the OBD-II plug into the car, right?
There is just a small clip on the connector that holds it in place because it could fall out otherwise.
Just grab it and pull it down, rocking it a bit.
I've coded a dozen cars and I've never run into a sticky or hard to remove connector. It's pretty well made.
      12-21-2012, 01:12 AM   #1473
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
I'm with kon, it requires a considerable effort to yank it out. (all cars i used it on)
however, never any problems or broke parts yet, so I wouldn't worry about it too much.
      12-21-2012, 01:13 AM   #1474
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
Btw Clarence, any luck on coding voice yet? (I believe it was you searching for it right?)
