02-18-2015, 01:58 PM | #23 | |
Rep 32,881
02-18-2015, 02:15 PM | #24 | ||
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
02-18-2015, 04:48 PM | #25 | |
Rep 3,089
P (watts) = I x V V = I x R so P = I^2 x R LEDs have high resistance right? Higher than bulbs so to get the same wattage less current is actually used. Did I do that right?? Amazed if I did. There is a reason why I did mechanical engineering instead of electrical.
02-18-2015, 04:49 PM | #26 |
Rep 3,089
Already ordered it! Arriving Sat. Looking forward to installing.
02-18-2015, 06:07 PM | #27 | |
BMW Fanatic
331
Rep 1,076
02-19-2015, 09:56 AM | #28 | ||
Fool
1857
Rep 3,542
LEDs have very little resistance which is why you need a resistor in series with one most of the time to reduce the current which could kill it. The current is then dissipated as heat. The higher the wattage of the LED, the smaller the value of the resistor. I would imagine anything higher than the 21W load the car expects to see would have a tiny resistor whereas the lower wattages would have a higher value At a given voltage (e.g. 12V) the amount of current is the same for a given wattage of LED or Halogen. I assume the wattage value of LED bulbs we buy is the value of the LEDs only, so the actual value the car sees will be slightly higher, how much so, I'm not sure, but a 21W LED bulb is likely to pull more current than a 21W Halogen bulb. Probably not enough to worry about mind. It's the high wattages like 30, 50 etc that I would be concerned about. A 16W LED is already going to be a lot brighter than a 21W Halogen so I can't see the need to go higher. |
02-21-2015, 02:19 PM | #29 |
Rep 1,961
Its really not. Scott helped my put in my LEDs today. The 25W LED is virtually identical to the 21W Halogen. No extra brightness. Now the 50W turn signals, they're brighter.
02-21-2015, 02:28 PM | #30 |
Rep 3,089
02-21-2015, 02:29 PM | #31 |
Fool
1857
Rep 3,542
02-21-2015, 03:53 PM | #32 |
Rep 1,961
02-21-2015, 05:16 PM | #34 |
Rep 5,316
Drives: G80 M3 6MT
Could possibly also be the design of the F34 tails, as the bulb is pretty far back since the tails are sort of "deep" if I am remembering right, does that make sense? The turn signals are awesome tho.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-21-2015, 08:11 PM | #36 |
Rep 3,089
Waiting for Zain on these as well.
Found some on ebay which I may get if Zain cant pull through soon.
02-21-2015, 08:15 PM | #37 |
Rep 1,961
02-21-2015, 08:21 PM | #38 |
Rep 3,089
Unfortunately, I do not have this option for the F32/F36 as Weisslicht does not offer a red BAY9s bulb.
02-21-2015, 09:19 PM | #39 | |
Rep 1,961
Whoops, nevermind. Same bulb. H21W is BAY9S. Last edited by Mike_L; 02-21-2015 at 09:29 PM.. |
02-22-2015, 09:15 AM | #40 |
Fool
1857
Rep 3,542
If a 23W residential CCFL is as bright as a 100W incandescent, and a 12W LED is just as bright (if not brighter), then does it not strike you as being a bit odd that a 25W LED is as bright as a 21W incandesent? a 25W LED should be blinding compared to the 21W incandescent. It should be roughly twice as bright as a residential 100W bulb!
02-22-2015, 10:48 AM | #41 | |
Rep 1,961
02-22-2015, 11:22 AM | #42 | |
Fool
1857
Rep 3,542
For example, they may have a 30W LED and say that it is 30W equivalent to 30W incandescent (which should mean the actual wattage of the "bulb" is around 4W and would then pull 0.33A instead of the 2.5A a real 30W bulb would pull), but then state that it has x number of 1W LEDs and x number of 3W LEDs, which oddly, adds up to the same number as the "equivalent" wattage. It's all very misleading. |
02-22-2015, 11:49 AM | #43 |
BMW Fanatic
331
Rep 1,076
Check HorizonLed's now, I can't seem to find any 50W's anymore, they got replaced with a new one (25W only).
02-22-2015, 12:50 PM | #44 |
Rep 3,089
