10-06-2019, 11:39 PM | #45 | |
Rep 39
F30 grounding issue bypass, with pictures
https://forum.e46fanatics.com/showpo...&postcount=334 |
10-22-2019, 12:14 PM | #46 |
Rep 8
Hello
Same issue on my F.30 2012. First I have problems with parking lights,first left,bulb looks good but I change it...few days later right parking light,change it...and again and again.I noticed before that my left tail light is not light as right.I put it out and I see that housing around third pin is melted.I will take my car to car electrician to change connector.I hope that I will solve problems with that. |
10-22-2019, 12:58 PM | #47 |
Rep 16,082
Changing the connector is a temporary fix, if it burned out once it will burn out again. The only permanent solution is to either perform the previously explained fix of the ground so it will handle the current of the original bulbs or changing to LED bulbs to reduce the current.
Cs770.00 |
11-09-2019, 11:46 PM | #48 |
Enthusiast
Rep 1
YouTube Tutorial On Fixing This Issue
This is my first time posting in this forum even though I have always found great answers to most of my car related issues on here. I did this repair on my 2013 BMW 335i yesterday and decided to just film it to hopefully help others who were in the same boat as me. I am by no means an expert so if I did anything wrong or inefficiently, I don't mind constructive criticism. Hope this helps at least a few people
I am also planning on doing a very in depth write up about the issue when I have a little more time but for now, all I have is the video. If you are very familiar with removing the brake light assembly, know which parts to purchase, and know for a fact that your connector is melted, skip to 6:10 to avoid unnecessary talking and get straight to the repair. Thanks guys! |
11-25-2019, 01:06 AM | #49 | |
Rep 39
Looking at how you did it (and how I did it), you don't really need to buy a NEW bulb socket or socket repair kit. You can use your existing socket/housing and just buy only the female quick disconnect and 14 gauge wire. Simply expose the brown (ground wire), and connect that ground to the white wire that you bought and run it like you did in the rest of the video, connecting the white cable to the metal tab you pried up. The part at 17:38 where you pried up the metal piece, that is the male connector that would have otherwise connected to your newly made brown/ground connection. So pulling that metal tab up makes the earlier socket repair/repinning process pointless unless when the pin got burned and melted that it damaged the adjacent pins. You would save yourself some money and extra steps. Cheers! Last edited by theothernguyen; 12-15-2019 at 03:03 PM.. |
12-07-2019, 09:46 PM | #50 |
Rep 268
Did this repair today with the old connector and bulb socket. Worked like a charm. I ordered a new socket and connector yesterday but it looks like I can return them now. Definitely was going to leave the car parked until I got this fixed so I appreciate this thread.
12-08-2019, 06:44 AM | #51 |
Rep 36
So I took my '13 F30 to my mechanic yesterday for some minor maintenance work. While there I had him check out my malfunctioning rear tail light only to find out that my connector had a melted pin as well. I've been looking at buying a new tail light as well as connector, but hopefully I can save some $ by trying this fix. Also can anybody recommend a good way to seal the bulb holder?? I saw some condensation forming on it when I removed the bulbs. Thanks!
12-10-2019, 02:39 PM | #52 | |
Rep 268
Use some dielectric grease on your bulbs and connectors. May not prevent condensation but will prevent moisture from damaging your electronics |
12-10-2019, 03:24 PM | #53 |
Rep 16,082
That's SOP. The trouble is that if corrosion was the problem then it would be happening with the hot pins as well. It only happens with the ground pin because it handles current to both bulbs and it's not up to the job.
12-21-2019, 09:12 PM | #54 |
Rep 36
Thanks! Got the bad connector replaced a few days ago and tmrw I'll be switching over to all LEDs in the rear Hopefully that'll reduce the load on the ground wire.
12-21-2019, 09:33 PM | #55 |
Rep 16,082
It should prevent the problem, LEDs draw maybe 1/10 the current that incandescent do. Reading about these blown sockets in part convinced me to go all LED.
12-23-2019, 05:56 PM | #56 |
Rep 36
I completed the switch to full LEDs in the rear yesterday and Im very happy with the outcome. In addition to minimizing problems with the harness melting again, it just makes the car look alot more Up To-Date than those old school halogens!
12-25-2019, 12:20 PM | #57 |
Rep 16,082
The safer too, because they light far faster than incandescent. Regular bulbs have to heat the filaments to produce light, which takes time. LEDs don't have lag time. The sooner the guy behind you sees your brake or turn signal lights the sooner he can react to them.
305f3022.50 |
01-25-2020, 03:40 PM | #58 |
Rep 1
The fix that theothernguyen works perfectly and is inexpensive. Thanks for the post! My 2013 320i had this exact problem. I attached two pictures, sorry they might not be the best angles. in the picture with all the tools the bulb piece can be seen in the bottom right.
Side notes for F30: You will need to break of the metal plating on the bulb side to connect to it. I actually used a soldering iron carefully and briefly to melt the plastic that held the metal down. I cut the brown cable completely, Ive seen some people just strip the wire and connect the new wire to it. There is conveniently a soft lighter colored piece of plastic that you will need to cut a whole in. This will be used to thread the new wire from on side to the other. This can be seen in the picture that shows the unit connected. The red cable is the new cable and you can see the piece of plastic I am talking about. Update: Excuse the language in the quote in the picture, I was a little frustrated with this design flaw. |
theothernguyen1.50 |
01-26-2020, 07:29 AM | #59 | |
Rep 870
01-26-2020, 09:07 PM | #60 | ||
Rep 268
Your bulb socket is probably loose. Check the socket and pull the metal tab up that the bulb sits on. Maybe even place some rubber underneath. Just need to make that connection tighter..... That's probably your issue. |
02-22-2020, 11:56 AM | #61 | |
Rep 1
Hi
Do you mind sharing pics of how you did this? I am having the same issue. I am new to this site. Thanks Quote:
02-22-2020, 12:06 PM | #62 |
Rep 39
02-26-2020, 12:49 PM | #64 | |
Rep 2
even later to the party
03-02-2020, 01:51 PM | #65 |
Rep 138
It’s fucking criminal that this issue, which was recalled on their E46 cars, still exists on cars over a decade later. How is that ok?? Majority of people will go to the dealer, pay for a new connector, and have the problem all over again.
Thanks for the fixes all |
03-08-2020, 10:59 AM | #66 |
Rep 1
So grateful for this site and all of your helpful suggestions. I purchased my '14 428i two weeks ago and just last weekend I began having the rear tail light issues described here. I did the usual bulb swaps and when that failed I turned to this site and boy am I glad I did. Thanks for the help and saving me $$$ since this is pretty much a fifth grade science assignment I can pull off on my own.
