10-27-2017, 04:42 AM | #1 |
Rep 804
F30 ebay headlights
Anybody bought these before? For halogen headlights thanks
https://m.ebay.com/itm/Black-F32-Sty...257Ciid%253A22 |
10-27-2017, 09:26 AM | #2 | |
Rep 757
2014 Estoril Blue II BMW 328i xdrive ///M-Sport
10-27-2017, 09:59 AM | #3 |
Rep 804
10-27-2017, 10:33 AM | #4 |
Rep 757
they got one somewhere about the older version
10-29-2017, 01:10 PM | #5 |
Rep 2,036
What’s odd is that it appears the horizontal and vertical adjusters are on the backside of the lights. Normally the adjustment points are on the topside.
So after installing, one can make adjustemnets with just the hood of the vehicle open.
10-29-2017, 01:12 PM | #6 |
Rep 2,036
Check these....
http://f30.bimmerpost.com/forums/sho....php?t=1274932 http://f30.bimmerpost.com/forums/sho....php?t=1257101
10-31-2017, 11:23 AM | #7 |
Rep 327
I upgraded from my halogens to USR headlights. They have a weird cutoff pattern but work well especially with HIDs.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
10-31-2017, 03:30 PM | #8 |
Rep 804
11-02-2017, 07:15 AM | #9 |
Rep 44
I literally just purchased these last night. Once I get them and install them, I'll let you know. I was kind of curious about them and figured for the price, I'll roll the dice.
11-02-2017, 12:00 PM | #10 |
Rep 804
nice please update.. if it looks good im deciding if i should go with the black ones or the regular clear
11-17-2017, 02:44 PM | #13 |
Rep 13
Let us know. Im in the market for some lights too but I been looking at USRs lights which replicate the OEM ones. These look a bit out there for me but If you got any install pics I got an open mind!
11-21-2017, 05:14 PM | #14 |
Rep 44
I finally installed these headlights on Saturday and love them. The LED halos are super bright. The only drawback is that I originally purchased LED headlight bulbs with the fans built into the bulbs and this housing does not have as much space as the stock OEM halogen lights do for clearance. I am going to have to return my LED bulbs and go with HID's so I can at least install the ballast in a clean way without having to cut into the back seal cover of the headlights.
Right now I am just using my Philips - Diamond Vision H7 bulbs for the time being, until I decide which HID's to purchase. The projectors do make it 100% better than the OEM headlights as far as driving at night, but I know HID's will be best. I took some photos of the headlights with my phone, so pardon the quality but I know a lot of members here want to see what they look like.. I got the black housing lights, FYI. To those who are wondering if you need to code the car or not with these lights, I am sorry I cannot help because I had coded my car prior to the install when I had LED DRL, park lights and fog lights installed last year. So, I'm not sure if it will throw an error or not. I hope this helps anyone who is curious about these lights. |
scostu1623.00 rmeyer40500.00 |
11-21-2017, 07:13 PM | #15 |
Rep 71
The beam cut off if pretty good. Can you still adjust the headlights when they're installed? In the ebay sales pics, it shows the adjusters on the backside not on top like the factory one.
11-21-2017, 07:38 PM | #16 |
Rep 44
You can adjust the headlights like normal after installation. There is the little dial on each headlight to adjust up/down and left/right with a Phillips screwdriver.
11-24-2017, 11:37 AM | #17 |
Rep 9
Just ordered a set for myself, always hated the halogen headlights.
A few questions: 1. Were these direct plug and play? 2. Did you run into and unexpected problems/ foresee any quality issues? 3. Why have you chosen to go with HID bulbs over LED bulbs as a halogen replacement? Thanks for the post! They look pretty nice on your ride. |
11-24-2017, 03:34 PM | #18 | |
Rep 44
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 As far as quality goes, it was really great quality. Everything fit perfectly, everything lined up on the bumper and grill. The lights are super bright so there is a little light pollution on the inside of the headlight that you may need to either cover/tape off the top of the headlight to be completely dark. You can only see it if you are looking through the space in between where the hood and grill cover meet. It is very unnoticeable, but if I am critiquing, that would be my only thing I can point out aside from the headlight bulb housing space. That is just a design thing because of the space needed for the led halos and projectors, it takes up more space than the OEM halogen housing. |
11-30-2017, 12:32 PM | #19 |
Rep 10
I just installed these from pro tuning labs:
https://www.protuninglab.com/hid-pro...12-drl-bk.html The look like the same as yours, but with HID bulbs. I am experiencing some flickering. PTL is sending me 55w ballasts with cancelors built in at no charge. Once installed, I'll report back on wheather or not the new ballasts fixed the flickering issue. So far, I really like the headlights. In my opinion, the look "meaner" and more modern than the round halo DRL. What I'm cautious about, however, is all the wiring is on the outside of the headlight housing. Probably not an issue, but I'm worried about corrosion or possible "wear through" issues. Do yourself a favor and remove the front wheels and fender liner for the install. It's so much easier than trying to work around the wheel and liner. Last edited by KosmoK; 11-30-2017 at 12:41 PM.. |
11-30-2017, 12:52 PM | #20 | |
Rep 804
thx |
11-30-2017, 01:24 PM | #21 |
Rep 9
Just installed these lights. Purchased from dtmotoring. I went with the black housing. The quality is great. Everything lined up just like the OEM lights. The projectors have a clear cut off and everything was plug and play. Now I just have to buy some Morimoto HIDs to complete the build. I coded out with BimmerCode app.
Highly reccommend them, will post pictures when I figure out how. |
12-01-2017, 02:52 AM | #22 | |
Rep 147
