10-17-2014, 09:54 AM | #23 |
Rep 1,893
From standing under the car and seeing exactly what was going on, I think the easiest method would be to cut off the entire tail pipe from the side you want to adjust, trim off a few millimeters and weld it back on. This way, it will be closer to the center. My installer wanted to try moving the bracket points on the hangers but I told him to leave it. I'm going to get some 3.5" Cyba tips and just put those on.
10-17-2014, 12:28 PM | #24 |
Rep 44
Check out my thread if you were interested in the AA exhaust for your 428i. It's definately worth all the trouble. The dual exhaust looks sweet and it sounds great. I'll try and get a video up soon.
http://f30.bimmerpost.com/forums/sho...php?p=16681691 |
PrMaX14.00 |
10-18-2014, 12:14 PM | #25 |
Rep 175
I called a muffler shop and they didn't want to work on the BMW because welding would cause the computer to short out they said....
Wouldn't I be able to simply disconnect the negative lead on the battery and then it could be welded with no issues? |
10-20-2014, 02:25 PM | #26 |
Rep 44
Call a muffler shop that has experience working with BMWs. My shop just disconnected the battery like you stated and everything was okay.
11-19-2014, 06:26 PM | #27 | |
Rep 190
11-20-2014, 01:50 PM | #28 | |
Rep 1,893
Labor $75 Performance Diffuser $385 on ebay (you can find the stock diffuser much cheaper) $560 total Not sure what the xdrive setup is like, but I have not heard of any differences.
05-14-2015, 06:04 PM | #29 |
Rep 1,262
Drives: 2014 BMW 435i Coupe Msport 6MT
Just got mine done $350 all in.
Here is my before and after http://i40.photobucket.com/albums/e2...psxeph54ri.jpg
2013 BMW 335is Coupe AW/CR 6MT
2012 BMW 335 coupe ( Sold) 2012 Audi S5 coupe( Sold) 2010 BMW 335i coupe( Sold) 2009 BMW 335i coupe ( Sold) |
06-19-2015, 10:06 PM | #30 | |
Rep 112
06-21-2015, 09:06 AM | #31 |
Rep 1,262
CM Peformance exhaust in Margate. It took less then an hour and he charged me $150.00
06-24-2015, 12:59 PM | #32 |
Rep 112
How did you do the diffuser ? Did you/they remove it for you there or how did you do it ? I want to go this week and get it done.
07-22-2015, 04:01 PM | #33 |
Rep 14
I am thinking about doing the same swap OP mentioned. I would like to change my (428i) single side exhaust to a (435) dual M performance exhaust. I have seen some people swap it to the 435 stock exhaust, but I wanted to confirm that I could also do it with a m-performance one.
Has anyone found video clips of how the swap sounds? Do I just need to purchase a dual rear diffuser and m-performance exhaust then find a muffler shop that will install it? |
10-03-2015, 01:23 PM | #34 |
Rep 247
Do I buy the 435 or the 428 clamp?
And if I bring it to a shop, I don't need to buy a clamp because they will just weld it?
F32 M-Sport
F12 M6 Competition |
10-03-2015, 02:14 PM | #35 |
Rep 340
You will need a 428 clamp. I forgot to purchase one and since the 435 one didn't fit, I just had it welded. Yes you can just weld it if you'd like.
Alpine White M Performance F32 428i - Exhaust conversion + More. Check out my build
10-03-2015, 02:19 PM | #36 | |
Rep 247
F32 M-Sport
10-03-2015, 07:22 PM | #37 | |
Rep 340
10-07-2015, 09:52 PM | #38 | |
Rep 195
10-25-2015, 07:05 PM | #40 |
Rep 3,089
10-25-2015, 09:31 PM | #42 | |
Rep 3,089
While you are at it either cut or move the exhaust tip locating pins. Check out my build thread for more info on what I did.
10-28-2015, 10:55 AM | #43 |
Rep 247
Finally got this done! Thanks for everyones help. Please see my thread for pics.
http://f30.bimmerpost.com/forums/sho....php?t=1189282 |
11-25-2015, 09:23 AM | #44 |
Rep 12
Just wanted to chime in and say thanks to all the folks that went before me with the 428i exhaust conversion. Also, I wanted to add a few notes for anyone looking to use the exhaust from a 435 instead of the 335 on their F32.
I found a 435 exhaust on ebay ($250 shipped) with less than 5k miles on it after the owner swapped it out for the MPE. Based on what I had read online, I was expecting the hanger for the right tailpipe to be off and that the tip itself would be off center. Well, that's not the case with the 435 exhaust. The rods fit right into the hangers and the tip is centered. I used the generic M performance diffuser from Bavauto ($170 shipped). Lastly, because my car is owned, I decided to forego the clamp and had the main pipes welded directly to each other. Labor was another $170 here in Tyson's Corner, VA. So for around $600, I was finally able to restore some symmetry to the rear-end of my car. Immediately I was loving the look. But after they started her up and rolled off of the lift, the louder low rumble planted a big ass grin on my face. |
