04-10-2024, 08:10 PM | #1 |
Rep 3
F32 Pure turbo 750 logs low boost
This is a log I have taken while doing a single gear pull, and a multiple gear pull, my tuner is RK Tunes
My mods are pure turbo 750, eu5 injectors, lpfp stage 3 and hpfp stage 2 no port injection, no lift kit, running e50 blend https://bootmod3.net/log?id=6606dd00cf2c9b4d4d4ab2b3 (WOT 1 gear) https://bootmod3.net/log?id=6617267b92299c13f8c1ce95 (WOT 3 gears) I want to get to 600whp, so this is just the start, let me know if anyone has experience with the pure 750 on an n55! |
04-11-2024, 11:30 AM | #3 |
Rep 15
04-11-2024, 12:07 PM | #4 | |
Rep 782
Where as the PS2 with ethanol is close to 600whp on a bunch of setups |
04-12-2024, 09:28 PM | #5 | |
@_sunbish
293
Rep 612
You should venture out into the n55 fb group. Been a handful that have made over 600 recently. As for the PS2, I’d take those 600 numbers with a grain of salt. I bet those are inflated dynos, because actual timed performance numbers are underwhelming for the PS2. You can can skew a dyno number, but I’ve yet to find someone who can skew time.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
harkes1090.00 |
04-13-2024, 09:43 AM | #6 |
1303
Rep 3,552
Yeah there are quite a few now fyi
2017 m240i xDrive 10.67@132.32mph w/bm3
04-20-2024, 02:25 AM | #7 |
Rep 320
your tuner hasn't turned it up yet since you're just starting out...Learn to read logs. You're at 20ish psi and at like 80's%wastegateduty cycle. Your load target is still under 200 as well..Timing isn't above 10deg....Yeah, you're tune is very safe and hasn't been revised much yet. Takes time, be patient.
Im getting towards the finish line with mine. Currently at 25psi on e60 with low 90's wgdc. My load target is around 250 and timing is closer to 15deg...This turbo can do 30psi. I would back your Emix down to e30 to give your fuel system a break until the tuner tells you to add more E. FYI. I'm floating around high 6's 60-130 currently, manually shifting twice and no antilag/brakeboost. We aint done, its got low 6's in it. This is in a M2...Another guy on here hit about the same #'s in a 5 series auto during dead of summer. He was around 650+ wheel. Lookup inhouse performance. Last edited by VGSON; 04-20-2024 at 02:40 AM.. |
dannynonnom0.00 |
04-20-2024, 04:26 AM | #8 | |
Rep 2,379
(A Dane in China) Last edited by harkes; 04-22-2024 at 09:42 PM.. |
dannynonnom0.00 |
