03-08-2014, 09:08 PM | #23 | |
6579
Rep 5,304
03-09-2014, 05:04 AM | #24 |
Rep 648
Hi,
I'm in Sardinia, Italy working and will be for 2-4 weeks. You'll have to wait. On http://www.f30post.com/forums/showthread.php?t=954392 Fazerfahrer's 330d is lowered on AC Schnitzer springs, approx. 30mm. This is very close to the mine. ...Will have the boobie take one later today :-) /Krelle |
03-09-2014, 12:47 PM | #25 | |
Rep 648
/Krelle |
03-10-2014, 12:03 AM | #26 |
6579
Rep 5,304
Thanks Krelle. This helps out a great deal in setting up my rear. The 25mm drop for the rear looks right on the mark with the H&R Sport Springs; which is what I want. However, the front looks a bit higher. Thankfully, the front is 100 times easier to adjust than the rear.
03-10-2014, 08:02 PM | #27 |
Rep 558
EX O,
You wanted to see this? 1 finger gap both front and back. I'm already scraping the front lip going into driveways straight on. This picture was before the m-sport bumper install and the additional 3mm drop. Last edited by _bdiddyb_; 03-11-2014 at 08:23 AM.. |
03-11-2014, 04:20 AM | #28 |
6579
Rep 5,304
Well dayum! Thank you for taking the time to take these photos. i really really appreciate it. Was the OEM spring cup required for installation? It seems like you can't really turn the perch that much because the OEM cup lip is in the way.
03-11-2014, 08:22 AM | #29 |
Rep 558
The cup can be removed if pried out, but the instructions from Bilstein was not to remove it. If I loosen the spring perch up into the cup, the wheel lip will be inside the wheel well. Not digging the low-rider look.
03-11-2014, 09:29 AM | #30 | |
Rep 1,556
Interesting I don't have that cup on my 2012 328. Wonder if this is a 335 thing or 2013 thing? Diddy, hows the ride? Any noises on the front end when you crank the wheel like a spring loading and popping? |
03-11-2014, 11:55 AM | #31 | |
Rep 558
http://www.realoem.com/bmw/partgrp.d...13&hg=33&fg=45 Ex O. I take it back, it can be removed; but the instructions from Bilstein was not to remove it. I'm on 20's and 35front/30rear tire profile. Initial ride was rough, I could hear and felt every road cracks. It's been 3 months now. I changed the tire pressure to 35psi front - 40psi back and dialed in stiffness of 5. Springs and shocks have worn in; ride is much more comfortable. Definitely more stiffer on the rebound from before (18's square on 45 profile tires with "sport" suspension). I regards to the popping/cranking sound when steering wheel is turned and driving over a dip. Some of you have experienced this, I have not noticed it on my install. |
03-11-2014, 12:38 PM | #32 |
Rep 558
Would you mind taking a picture of your rear spring? Your car does have the spring pocket. Someone installed the suspension for you?
03-11-2014, 04:57 PM | #34 | |
6579
Rep 5,304
Here's a pic from an E90. |
03-11-2014, 07:03 PM | #35 |
Rep 558
When I installed mine, it felt as if the spring cup needed to be there for a more secure fit, and protection for that thin rubber ring. I see your point though, removing the cup allows for another 3/4 inch of perch movement.
03-11-2014, 11:35 PM | #36 |
Rep 1,556
Yes mine is gone. I have no idea if it was there before as I had a shop do it for me.
Mine does make that noise after the car has been sitting for a bit like overnight and it gets to unload. Once I drive it and it loads the spring and strut it doesn't make the noise. I also have it lowered well beyond the "recommended" by H&R. I have 7/8" of thread left on the front and I can spin the spring with my hand. Not a lot of tension on the spring. If I raise it up say another half inch the noise goes away, but I like it at this height and seems to be even more planted and rail like. Drive is still very good, but if you are on a rough road you know it.. Tucking about 3/4" of the tire. Last edited by Dippydo; 03-11-2014 at 11:41 PM.. |
03-12-2014, 02:38 AM | #37 |
Rep 648
Spring on F30 335.
The original spring holder are not to be used as the threaded piece replaces this and the "spring anti noise thingy". Picture show correct mounting according to Bilstein. (As you might have noticed, the OE spring holder and the Bilstein threaded piece look almost identical at the top). /Krelle |
03-12-2014, 10:08 PM | #38 | |
6579
Rep 5,304
03-13-2014, 01:22 PM | #40 | |
Rep 648
I allready asked Bilstein and this is what they supply for the 335 F30. /Krelle |
03-13-2014, 02:49 PM | #41 |
6579
Rep 5,304
Interesting how they answered; they just avoided your question. I think they just wanted to keep their cost down. Although the locking nut isn't really needed for the rear, I think it would've been nice to have.
03-13-2014, 05:00 PM | #42 | |
Rep 648
I'll try to get an explanation on why there is a difference though, (E90-->F30) Will let you know how they reply. /Krelle |
03-17-2014, 08:30 AM | #43 |
Rep 648
Here is the reason why Bdiddyb should have his cup holder removed. I got a swift reply from the Product Management, Bilstein, Germany. They explained that due to the fact that no side forces has effect on the springs on the F30, the locking nut is not needed. On the E90 you need an adjusting ring/locking nut due to the fact that side forces can course twisting of the spring plate… Everything is o.k.! /Krelle |
03-28-2014, 02:24 PM | #44 |
6579
Rep 5,304
I finally got around to installing these yesterday and so far I love them. They can go a lot higher than I thought. I think you can get them to stock height (Sport Line). Initially, I was riding high. After adjusting the height, I think I'm a little too low now. I'll fine tune it this weekend. The great thing about these coilovers is that you can actually turn the spring perches on the rear without taking it all apart.
Also, I have no noise so far. |
