View Poll Results: Did you experience timing chain failure on your N20 engine? | |||
Yes, my timing chain failed or required replacement. | 33 | 14.47% | |
No, I have not experienced timing chain failure. | 187 | 82.02% | |
I replaced my timing chain as a preventative measure. | 8 | 3.51% | |
Voters: 228. You may not vote on this poll |
06-27-2019, 09:53 AM | #67 | |
Rep 21
06-27-2019, 11:59 AM | #68 |
Rep 68
Here's a diagnosis method I've posted before that some of you will find useful:
You can check your oil filter for metal shavings or bits of plastic by cutting the filter media open. In most engines, oil flows from the inside of the filter to the outside, so the shavings will be in the folds of the filter media when you cut it away from the center of the filter with a razor. Ferrous shavings will be shiny and stick to a magnet (cranks, rods), babbitt will be metallic but non magnetic you can also crush it with a hammer (bearing material), and plastic will crush but not be shiny (timing chain guide). You should do this every time you check your oil, it's easy and free. You can google "aircraft oil filter inspection" for videos. Thankfully we don't have to cut our filter housings like most other cars, that's a pain and the tool dulls quickly and is hard to sharpen. |
06-28-2019, 01:11 PM | #69 |
Rep 17
Model: 2013 328i Sport RWD
Mileage: 46k miles Timing Chain Status: No problems Oil Changes: every 5k miles since 46k, not sure about PO Stop/Start Coded Status: Coded off by me. not sure about PO Additional Details: None |
06-28-2019, 04:09 PM | #70 |
Rep 5
Model: 320i 2012-Sept-12
Mileage: 60k miles, mostly motorway miles Timing Chain Status: No problems. Checked today at dealers Oil Changes: As per on board computer indicates. Stop/Start Coded Status: Not coded but always off since 17k miles, not sure about PO. |
06-28-2019, 08:25 PM | #71 |
Rep 33
Model: 328i xDrive 2013 Prod. date 2/2013
Mileage: 71k miles, mostly motorway miles Timing Chain Status: Faint sound and recommended to replace by local mechanic. Oil Changes: Every 6-10k varying Stop/Start Coded Status: Coded off at 11k. Not sure about PO Plans: Trade in the car and forget about the issue. |
07-01-2019, 11:23 AM | #72 |
Rep 212
I dropped my car off for timing chain and guides, and oil pump chain replacement today. I can't change my vote in the poll, but I do plan to keep the car a long time. I like road trips, and don't want to be in the middle of nowhere far from home when the high-pitched whine shows up.
This should restore peace of mind and dependability. |
RMachuca3d724.50 |
07-01-2019, 12:55 PM | #73 | |
Rep 943
Drives: F30 328i Msport
sspade2468.50 |
07-01-2019, 04:10 PM | #74 | |
Rep 212
I priced trading up to a post-2015 model, but that would cost $8,000 minimum. My car looks pretty new and is still comfortable, so this is the most cost-effective option. Update: See post 78 for complete and accurate breakdown after I picked it up. Last edited by jsouth; 07-04-2019 at 09:43 AM.. |
RMachuca3d724.50 |
07-02-2019, 09:24 AM | #76 |
Rep 106
Model: 2012 328i Sport RWD
Mileage: 107k km Timing Chain Status: No problems Oil Changes: ~every 5-10k km Stop/Start Coded Status: Coded off by me Additional Details: I tried using small borescope, it's 5mm diameter and i was able to stick it pretty much everywhere It can reach both left or right side, all the way down to oil pump chain... here's few images if anyone interested |
07-03-2019, 05:01 PM | #77 |
Rep 21
Model: 2012 328i RWD
Mileage: 65k miles (Bought at 38k, BM3 since 40k) Timing Chain Status: No problems Oil Changes: every 5k-6k miles since I owned it. Stop/Start Coded Status: Coded off when I bought it. Additional Details: Took it in twice to BMW to check the timing chain before my warranty was up due to 7 years. They kept it overnight to hear a cold start that last time. They said no issues. |
07-04-2019, 09:40 AM | #78 | |
Rep 212
The bill was $598.09 US for parts:
And 18 hours labor at $115 US per hour (total of $2070 labor) For a grand total with tax of $2717.43 US |
07-05-2019, 12:12 PM | #79 |
Rep 48
Model: MY 2013 328i xDrive. 11/2012 build date
Mileage: 65k Timing Chain Status: No issues Oil Changes: Carfax shows mostly 6-7k intervals but one of 15k, all at BMW dealership Start/Stop Coded Status: Not coded but I always turn it off immediately Additional Details: Purchased with about 60k with full records privately. Only engine related issue the car has ever had was the thermostat (covered under extended warranty) |
07-09-2019, 04:04 PM | #80 |
Rep 12
This video is interesting, not sure what to make of it.
2014 F30 320iX SE/Luxury: Current daily driver.
2008 E60 520d M-Sport: Retired April 2019 2004 E46 318i Compact SE: Retired June 2012 |
07-10-2019, 02:13 AM | #81 |
Rep 332
Drives: 2014 F32 428I Xdrive (N26)
Model: 2014 428xdrive
Build: December 2013 Mileage: 79k Timing Chain Status: No problems Oil Changes: Every 5k miles since 42k Stop/Start Status: Coded off at 42k
07-10-2019, 01:49 PM | #82 |
Rep 212
07-11-2019, 12:46 AM | #83 |
Rep 943
07-13-2019, 12:29 AM | #84 |
Rep 7
Model: 2014 328i RWD (N26)
Build: Not sure, I will look it up Current Mileage: 92k Timing Chain Status: Replaced short block along with guide and chain at 77k miles. Oil Changes: Every 5k miles since 45k Stop/Start Status: Manually turn it off every time. Additional Details: I took it to dealership for a whining noise and they found metal shavings in oil and said engine needed replacement. Later I found out it was because the timing chain guide broke and caused problems. BMW and extended warranty replaced short block, chains/guide, and turbo under good will and I haven’t had problems since. Last edited by bentheredonethat; 07-18-2019 at 01:24 PM.. |
07-16-2019, 12:16 PM | #85 |
Rep 117
Build: OCT 2012 Mileage: 693xx Kms Timing Chain Status: No problems Oil Changes: Every 10kms, before then not sure what the previous owner did Stop/Start Status: turned off each time from 56k kms no issues just yet but its making me paranoid!! |
07-16-2019, 06:41 PM | #87 |
Rep 5,458
Drives: F30
07-16-2019, 06:42 PM | #88 |
Rep 202
Do not, I repeat DO NOT tune them. They can't handle it, also not all timing chain and guides were affected. Only a handful. But don't tune it... numerous shops warned me, if you do, then do the chain and guides.
