01-10-2013, 09:55 PM | #1 |
Rep 9
Car wash
Wanted to have suggestions for car washes in the winter. I usually hand wash in the summer. Was looking at the petro Canada season pass but the one close to me (don mills) is soft cloth. Probably not a good idea? (Although the vehicle is leased...). Thoughts?
01-10-2013, 11:09 PM | #3 |
Rep 22
Hand wash or Touch less from Esso on the days I feel lazy.
2013 328i BSM xDrive Sport/ Black Dakota Leather/ Brushed Aluminum/ Prem Pkg/ Exec Pkg/ 8 spd
01-11-2013, 09:59 AM | #4 |
Rep 1,976
Drives: 2020 G20 320i M Sport
I find that the Esso ones never dry your car properly and you'll end up with lots of water marks in the end.
Best way to wash your car is by hand. Sometimes if it's too cold, I'll just wash it in the garage. |
01-11-2013, 06:11 PM | #5 |
Rep 2,101
I generally hand wash in the warmer months, but in the winter usually use touchless carwashes. I've found Esso and Canadian Tire generally have pretty good touchless washes (at least the locations I frequent in North York and Scarborough)
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
01-11-2013, 09:13 PM | #6 |
Rep 72
Drives: 335i msport;135i m convertible
I go to coin operated hand spray washes but I don't use the soap or the brush. I just put it on rinse mode to blast away the muck. After I blast all the muck off, I wash it at home in my garage with Optimim No Rinse car wash. Here is a thread about this:
http://www.f30post.com/forums/showthread.php?t=786764 And here is where you can order it as well as other detailing supplies: http://www.eshine.ca/ |
01-11-2013, 09:48 PM | #7 |
Rep 1,065
Drives: 2012 F30, 2013 E70
THIS!!!
2012 F30 | IBM | SB | M-Sport Conversion | OEM 437M Wheels | MPE ++
2013 E70 | SBM | NB | Coming soon |
01-13-2013, 10:47 PM | #9 |
Rep 26
The Esso touch less washes aren't bad. Gets pricey though, especially if you have a white car. You're better off getting a seasons pass if you're the type to always want it clean.
01-14-2013, 07:04 AM | #10 |
Rep 9
i know what you're saying wonder woman! it does get pricey at 11.99 a pop! i really want to get a seasons pass, but the close ones we have here are all soft cloth!
01-14-2013, 07:55 AM | #11 | |
Rep 1,111
The other option if you want the whole treatment is to go to a true touchless place wherer you don't even put a wheel in the track....the ones where you just drive in and stop. The only danger with those is that they recycle the water. It is filtered, but still... If you want to avoid swirl marks, never apply a product to the car if it isn't totally clean. So don't use any quick detailer in the garage. And in all cases, avoid scrubbing to get things off, and avoid circular motions. |
02-08-2013, 01:51 PM | #12 |
Rep 3,606
02-08-2013, 01:54 PM | #13 | |
Rep 3,606
02-08-2013, 06:47 PM | #14 |
Rep 551
I ordered some Optimum No Rinse for myself for Christmas and used it twice and have decided to go back to just use the regular water wash with Meguiars Gold Class car wash. I found that the amount of time and effort required to spray down, soak, and wipe off the ONR was just too much compared to using a hose and regular car wash. With the ONR it took about 40 minutes and with the regular water wash it takes about 30 minutes.
Also if the car is really dirty if you are going to rinse it off before you use the ONR you are half way through the amount of work required to do a regular water wash anyways. I also found with the ONR that unless I really soaked my black car down there would be some spots of residual hazing. Keep in mind I am in Vancouver and it rarely gets below freezing so if I was in Toronto or Edmonton I would think using the ONR would be a greater advantage..... One last thing, I ordered 2 grit guards for a 2 bucket wash system with the ONR. These are a must have for any kind of car wash product to help prevent scratching your paint job..... http://www.eshine.ca/grit_guard_buck...xmas.php?cat=9 Anyone from Vancouver that wants a nearly full 32oz bottle of ONR for cheap let me know........ Last edited by SPACEMANRICK; 02-08-2013 at 11:28 PM.. |
02-09-2013, 12:54 AM | #15 | |
Rep 1,397
If not I usually drive straight home so I can microfiber cloth it dry and detail it straight after |
02-09-2013, 06:45 AM | #16 |
Rep 1,075
Yeah, I find this a lot. Especially on the f30 rear. It just looks horrible if pass through the dryer and drive away.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
