BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Anyone try these color changing footwell lights?
      07-07-2015, 05:36 AM   #1
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
http://www.amazon.com/Wind-Fire-C002...X6J848JE2YYRPR
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      07-12-2015, 10:27 AM   #2
ahero4eternity
Drives: bmw
I installed these last night. Took about 30 seconds each.
      07-12-2015, 02:29 PM   #3
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Impressions?
      07-12-2015, 11:37 PM   #4
ahero4eternity
Drives: bmw
Like I said, install is easy and straight forward. It's easy to change the colors with the included magnet. I'm using red but thinking about switching to orange to match the rest of the amber lighting inside...but the orange is a tad too light. Maybe I'll just stick with red.
Not throwing any codes with these. *knock on wood*
      07-13-2015, 01:59 PM   #5
Fronzdan
Drives: '24 M240 xDrive
Hey that's interesting....thanks for the link. I'm going to try these.
      07-13-2015, 05:31 PM   #6
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Keep us posted! I want to see the difference between the Amber/Red/White before getting them for myself.
      07-13-2015, 10:58 PM   #7
ahero4eternity
Drives: bmw
Looks just like the pictures in the ad...
      07-17-2015, 07:45 PM   #8
Fronzdan
Installed these yesterday. Use a straight blade screw driver, pry the edge closest to the seat, pull it out, pull out the connector, plug it into the new one and pop it in. Took me longer to type that than do the install.
Brightness is better than stock, but it's not super bright..at least not with the black interior. Blue, Amber and white look good. Green and magenta are too weird for my taste. They slowly dim after the door closes, like stock.
What I can't remember is, does the stock version stay lit with the interior lighting package? I can't recall if the footwell stayed lit. These ones don't.
      07-17-2015, 09:48 PM   #9
ahero4eternity
Drives: bmw
Mine didn't.
      07-18-2015, 01:55 AM   #10
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
While driving there was some amber/white light in the footwell area with my F32.
      07-18-2015, 11:15 AM   #11
Fronzdan
I suppose I could confirm by swapping one back out...just lazy at the moment
      07-19-2018, 02:48 PM   #12
Zermatt
Zermatt's Avatar
87
Drives: M3
Mine didn't.
Depends if you have the Ambient Light Package. Footwell lights will be either a 2, 3 or 4 pin. I have the ambient light package so my footwell LED light module has 4 SMD LEDs and a 4 pin connector. Brightness and color adjusts based on settings and instrument dimmer knob. My door LED light modules have the exact same enclosure but have only two pins and one SMD LED. These are turned on when doors are opened. Brightness can be changed through coding.
FYI: I bought the BMS footwell light upgrade kit and while they had 4pins, they did not support ambient light ie they did not output a dim light while driving at night. The lights were certainly whiter and brighter (awesome) but what I really wanted was to have a brighter ambient light at night. I kept the kit and a modification for ambient is on my project list.
