10-04-2014, 12:14 PM | #793 |
Rep 286
I had my phone plugged in yesterday and I do see it showing on mine. I still haven't updated mine to 53.5. NBT is still on 53.3. Will try to see after update.
10-05-2014, 11:52 AM | #795 | |
Rep 15
Hello, I've recently upgraded from S606A Navigation system Business to NBT and everything's fully functional.
The "only" issue is that the FM/AM radio is not working at all, same scenario than upgrading from CIC @Aritaurus mentioned this Quote:
Any further info of how to solve this? Aside from the radio (Which I need) traffic info is sent thorugh FM, so no RTI |
10-05-2014, 03:21 PM | #796 |
Rep 40,773
CIC has a "Scan Diversity" antennae, so the aerial amplifier is monitoring all signals and sending the best one to the Head Unit via a single aerial wire. NBT has a "Phase Diversity" antennae, so the aerial amplifier is sending both aerial signals to the NBT head-unit, whereby NBT consolidates them for the best possible signal. With NBT, connect the one signal wire to the FM1 (black connector) for best results.
NBT also supplies power to the aerial amplifier via the antennae wires, which coming from CIC is only one instead of the normal 2, so the aerial amplifier is only getting half power, and may need a separate power wire run from quadlock pin 13 to KL30, same as CIC does.
10-05-2014, 03:41 PM | #797 | |
Rep 15
Thanks for the info Shawn. So, I've already hooked the existing antenna to the FM1/AM black one (in fact I've tried both connectors) but almost no reception at all in the two of them... Just the manual station browsing seems to be able to tune to a very limited number of stations, the auto scan feature that shows all the available ones is not showing any result in any case. So, making from long to short, my only option with my current HW is to use the black connector and to power up the PIN #13 to continuous positive, right? (or to install the diversity antenna --- no way --- just saw the price tag of the damn antenna ) last noob question where is the best location available to power up the 13th to a KL30 source? |
10-05-2014, 03:45 PM | #798 |
Rep 40,773
Yes, you understand correctly. I would add the wire. I am not sure where best to tap KL30, as I have not done my retrofit yet. Hopefully you can determine that and tell me.
10-05-2014, 03:49 PM | #799 | |
Rep 15
will do it mate, will do it as soon as I find a solution I'll post it. I've just had a bad idea.... would turning the single antenna connector into a double one with a "Y" fork connector do the trick? it'll send two identical signals to the NBT and the HU will send the "theoretical" power feedback to the antenna, right? |
10-05-2014, 03:58 PM | #800 |
Rep 40,773
I'm not sure about that. It may half the power on each branch so that the net power at aerial amplifier is still the same. It might make more sense to add wire from FM2 to aerial antennae, but that is probably a lot more work then getting KL30 to Pin 13.
10-07-2014, 02:52 PM | #801 | |
Rep 15
Sorry Shawn... maybe I'm a litlle too cautious but I'm have some concerns of tapping PIN #13 to KL30, as I'm not aware if it may damage the HU in any way. Because you mean to leave the harness in the same way it is right now, right? or should the 13th be detached from the NBT side of the harness and then just tapped to KL30 and not to be connected to the NBT? sorry for being a pain, but the damn HU is kinda expensive and my electronics is 101 I'd rather prefer to have the current OEM antenna, as I'd rather prefer not to install any cheap aftermarket antenna, which is the other option. |
10-07-2014, 04:28 PM | #802 |
Rep 10
Does anyone know the part number for the harness/wire that connects the nbt bluetooth mic and hu_nbt?
According to the wiring diagram the three cables should go to 17, 22 and 33, right? |
10-11-2014, 01:13 AM | #803 |
Rep 162
10-12-2014, 01:52 PM | #805 |
Rep 14
My car is F22 03/14. I'm getting F20 screen, nbt unit and normal controller. Now i have ENTRY. USB&AUX at center box....will old usb cable fit without modi to NBT? Is gps-cable coming from shark-antenna? I ordered gps fakra just to be sure. If i have to use it, can i put it under dash? Behind the screen.
10-13-2014, 10:15 AM | #807 |
Rep 162
10-15-2014, 04:15 PM | #808 |
Rep 14
Just installed nbt and friend done coding online. Damn it looks soooo much better than basic system. And even hear...why's that? And antenna works fine inside dash.
10-16-2014, 06:58 AM | #809 | |
Rep 103
If you mean radio sound, then maybe you have a digital audio broadcasting tuner instead of the FM radio. Correct me if i am wrong. Last edited by BeatB; 10-16-2014 at 09:41 AM.. |
10-17-2014, 02:03 PM | #810 |
Rep 14
Hi All,
First of all, I would like to say a very big "thank you" to those members who contributed to this excellent installation and for this great DIY. The advise, help and knowledge is appreciated and I would have not attempted this install if not for this thread. I will be installing my NBT over the weekend, currently I have an ENET cable and would like to find out which is best version of E-SYS needed for coding. My F30 is a 05/2014 build date. Currently installed in my F30 is HU_ENTRY with USB, AUX and Bluetooth for handsfree. For now I'm going to install NBT directly without emulator. So firstly I would like to get the existing functions working plus Enhanced Bluetooth. Emulator should arrive in the next few weeks and will then work on the Navi, Voice and Apps. Wish me luck. |
10-17-2014, 02:04 PM | #811 | |
Rep 40,773
Good luck.
10-17-2014, 02:37 PM | #813 |
Rep 40,773
No. The only thing you might need off eBay is an ENET Cable if you do not have one.
PM sent.
10-23-2014, 01:57 AM | #814 |
Rep 9
Hi guys! One question. If I have an F30 with radio professional with USB (white connector) and telematics (green connector) i have to rewire for sure the usb connector, but what about green connector?
I've noticed it has different shape... I can modify it with cutter only or I need to rewire it? Thanks! |
