04-16-2014, 07:46 AM | #23 |
Rep 312
For the record, you CAN go from drive to neutral and vice-versa while moving by simply moving the shifter. You DO NOT have to push the brake to do so. This is a safety feature that has been around for years on automatics. Tested yesterday on the highway - pushed the gearshift into neutral than back to drive. Reverse and park are electronically locked out to keep from accidentally destroying your transmission.
04-16-2014, 07:54 AM | #24 |
Rep 2,802
04-16-2014, 12:00 PM | #25 |
Zooombie attaaack!!
136
Rep 1,179
First of all, why the hell would you do that? Secondly I can't recall if you have to have brake when stopped to go from N > D, but you might. All I know is that you do NOT need to brake (much less come to a complete stop) to go from N > D when you're at speed.
04-16-2014, 05:20 PM | #26 |
Rep 814
Alright. Just got a phone call from SA.
They couldn't find any fault code, couldn't replicate problem. So he has to let it go. This is the worst outcome I could hope for. I feel like I am now a guinea pig. So wait and see if it happens again? |
04-16-2014, 06:22 PM | #28 | |
Rep 365
04-16-2014, 09:31 PM | #29 | |
Rep 7,047
Do yourself a favor and leave the trans in D so you can move quickly if/when you need to. |
04-17-2014, 02:07 PM | #30 | |
Rep 2,802
04-17-2014, 04:34 PM | #31 |
Rep 814
I am trying to find the exactly error message I received on the dash. I was something similar to "Transmission not in drive"
Is there a list of all error messages? I can't find it in the owner's manual. |
04-18-2014, 01:50 PM | #33 |
Rep 312
04-18-2014, 07:04 PM | #35 |
demoted
453
Rep 1,172
Yup...
My E92 M3 coupe has been a digital nightmare - radio wouldn't work on cold mornings, CELs, limp homes, weird DCT messages - and we have no lemon laws in Canada. So what do I order? A 435i xDrive 8AT w/ MPPK etc..
04-19-2014, 07:17 AM | #36 |
Rep 292
These cars really are getting entirely too sophisticated... Another reason to keep my n54 e90 forever. Also more reason to have my dealer code the auto start stop on my f30 to never!
2016 M2 Gone
2014 320i Gone 2009 335i Gone 2011 328i Gone 2009 335i Gone |
04-19-2014, 09:56 AM | #37 |
Rep 4,323
This was a fix from the November 12 TSB no?
04-20-2014, 10:10 AM | #38 | |
Rep 11
I always thought that's the correct thing to do! Now you guys make me think... |
04-20-2014, 11:53 AM | #39 |
Rep 254
"The problem's plain to see...too much technology"...Extended Warranty!!!
I love the 8AT, cameras and all, but I got 7 yrs 100k miles because SOMETHING is going to break! |
04-20-2014, 07:18 PM | #40 | |
Rep 7,047
It's not very "sophisticated" when your car becomes uncontrollable because the overly complex computer system decides to take control away from the driver on the most basic yet extremely important controls. Where the f**k are the redundant fail safe protocols? Since the computer knows your car is moving, as it can read the sensors for rolling tires, then it should know NOT to take the trans out of gear or cut throttle control, nor any nonsense where vehicle control is removed from the driver. Put a cable back into the throttle so it can default to mechanical control if/when the computer decides full throttle is what is needed, or no throttle is what is needed when what you need is completely the opposite. This is one reason why I'm dreading manufacturers going to brake-by-wire. At least the electric assist steering still has a mechanical link so we can still steer if the computer or assist system goes bonkers at 90 mph. |
04-20-2014, 08:02 PM | #41 | |
Rep 7,047
Some argue that you should always be in gear so you can move out of the way quicker if you need to. Others argue that leaving the trans in gear while your foot has the clutch pedal in wears the throw out bearing quicker. There seems to be no consensus on this. When I drive an MT I do both but it depends on the situation. If it's a stop sign I'll leave it in gear. On long lights or train stops I'll do neutral. With an AT I see no reason to take it out of gear, just hold the brake pedal lightly. It's your choice, but my opinion is that it's fine to leave it in gear at any length temporary stop. ASS will shut your engine off, but you have to keep holding the brake pedal in. If you take your foot off the brake the engine will start. I think with the MT and ASS, the engine shuts off at a stop and you still have to hold the brake. Once you push in the clutch the engine fires up. With this method you leave the trans in gear, and when you press in the clutch you're already in gear and you can move. So the only reason you go from D to N is because it's too much to hold the brake pedal in? |
04-21-2014, 03:45 PM | #42 | |
Zooombie attaaack!!
136
Rep 1,179
04-21-2014, 04:25 PM | #43 |
Rep 376
FYI once the ASS kicks in (puts car in standby mode) you can put the car in park and it will stay in standby mode, therefore you can take your foot off the pedal. Once you put it back in drive, the car will start again and you can go on..
12-19-2022, 06:56 PM | #44 |
Rep 31
Drives: Bmw 435 GC
This just happened to me today and don’t know where to start
