05-29-2014, 02:08 PM | #133 | |
Rep 32,881
I have never heard of coding affecting warranty, and the general opinion is that it won't, but i wouldn't want to tell you that's 100% guaranteed. |
06-02-2014, 05:54 AM | #135 |
Rep 564
Hoping @teaston can assist....
F30 328i M Sport +
Twitter: @3qtrsamericano |
06-02-2014, 06:19 AM | #136 |
Rep 40,786
What PSdZdata version are you using?
06-02-2014, 07:30 AM | #137 |
Rep 34
06-02-2014, 09:15 AM | #138 | |
Rep 40,786
And your PSdZData is not 4.7.0. This is what is displayed under E-Sys => Help => About, and it has nothing to do with the actual PSdZData version your are using. This has to do with the version of PSdZ binaries used in E-Sys version. In any event, the [C012] Missing CAFD error means you need new PSdZData. PM sent.
06-02-2014, 12:33 PM | #140 | |
Rep 34
Hi Shawn, Just wanted to check - I've downloaded the latest PSdZData files. I've already got E-SYS 3.23.4 installed, but obviously with the wrong version PSdZData. Do I just delete everything in \psdzdata\ and copy the 7 folders from the new PSdZData download? Thx. |
06-02-2014, 12:44 PM | #141 |
Rep 40,786
Delete current psdzdata folder and replace with the new one.
06-08-2014, 05:08 AM | #142 | |
Rep 19
EBT working great!
Big thanks to Shawn and Teaston!
The guide is great & I got EBT up and running in minutes on my 2013 F30 Bus' Media I had an initial issue with no 'Dist' folder so model was not showing up but sorted it and followed the guide to the letter. Quote:
06-08-2014, 07:38 AM | #143 |
Rep 40,786
06-11-2014, 11:17 PM | #144 | |
Rep 179
06-11-2014, 11:37 PM | #145 |
Rep 40,786
It should be 6NK. 6NS is for NBT Head Units >=0713.
06-12-2014, 04:41 AM | #147 |
Rep 19
I used 6NS (2014 wk14 build) - no problems at all
F31 330D M Sport Plus - Mineral Grey
06-12-2014, 06:30 AM | #148 |
Rep 40,786
OK. Good to know. Beginning 07/13 also?
06-12-2014, 10:43 AM | #149 |
Rep 32,881
06-12-2014, 03:22 PM | #151 | |
Rep 32,881
You can only add full voice by changing the head unit for one with a voice control activation code in it apparently. |
06-12-2014, 04:05 PM | #152 |
Rep 1,858
I’m trying my fist attempt at connection in advance f coding experiments, so haven’t got a token yet.
i’m having some problems connecting to the car - the “connection via VIN” is greyed out so i can’t select it. any ideas? the default is “connection via Gateway URL” and when i press connect, i get a successful connection message, bit when i try and “read Vehicle order” i get a “PDsZ error” error which says “Read FA Failed - possibly there is no FA stored in the VCR(CO60) any ideas whats up? thanks Gerry |
06-12-2014, 04:07 PM | #153 | |
Rep 32,881
In the meantime check you have installed the psdzdata correctly? |
06-12-2014, 04:12 PM | #154 |
Rep 179
I did a non nav F20 for a friend the other day and I coded '6NS' and it seemed to be ok, but he was in a rush and never really got to fully test it, so reason I asked was to see if he will end up having issues because I did 6NS instead of 6NK.
