BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F32 LED fog lights
      07-13-2014, 06:57 AM   #45
MoneyFor
MoneyFor's Avatar
Belgium
25
These are my coding settings:
FEM_BODY
3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front right
3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front right
3061 NSW_R_IS_LED -> aktiv : LED Foglights front right
3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3061 NSW_R_UE_SPG_SCHUTZ -> dimmed : LED Foglights front right
3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front left
3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front left
3061 NSW_L_IS_LED -> aktiv : LED Foglights front left
3061 NSW_L_UE_SPG_SCHUTZ -> dimmed : LED Foglights front left
3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
3062 MAPPING_abbiegel_L_output -> nsw_l : Foglight when turning
3062 Mapping_abbiegel_R_output -> nsw_r : Foglight when turning
3073 KL_ENABLE_RE -> KL_Ein : Foglight when turning
3066 KL_ENABLE_LI -> KL_Ein : Foglight when turning
3073 C_CLC_ENA -> enable : Foglight when turning
3073 C_BLC_ENA -> enable : Foglight when turning
3063 Mapping Nevelschw L Part of WL soft-on nicht_aktiv : Foglight left as welcome
3063 Mapping Nevelschw R Part of WL soft-on nicht_aktiv : Foglight right as welcome
      12-12-2014, 01:49 AM   #46
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Originally Posted by Fazerfahrer View Post
...yes, we did.
It is plug and play but need some coding
Would you know if the place you purchased from ships internationally?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      12-12-2014, 01:55 AM   #47
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
I have a F32 435i X-Drive, but unfortunately my dealer did not get the adaptive LED-lights, and I am stuck with a halogen fog light, and unfortunately my dealer wouldn't order me the LED's and if he did would charge me $500+. Where can I find the OEM BMW fog lights online, and what model fits? (I've found ones for X3 & X5, but I'm not sure if they fit) Any help would be deeply appreciated.
      12-12-2014, 02:22 PM   #48
ktula
Drives: 2014 F31
This:
http://www.ecstuning.com/BMW-F32-435...hts/ES2711818/
And this:
http://www.ecstuning.com/BMW-F32-435...hts/ES2711497/
      05-05-2015, 02:48 PM   #49
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Quick question,
what do the % options modify?
      05-05-2015, 04:05 PM   #50
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
does anyone know if they are any brighter than halogen ones ?
      05-05-2015, 04:43 PM   #51
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
I have a 528i with them. They are 30~40% brighter than halogen IMO. However, I got a 3200lm H8 kit for my F32 from Horizon in order to help me out in spotting nasty potholes. Cost me 2 tires so far. Plus, the BMW leds are kind of pricy if your on a small budget. Around $400 for 2 lights doesn't seem justified, would rather buy a performance part with that money.
      05-11-2015, 07:52 AM   #52
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
FEM_BODY
Just installed LED's from Horizon as my fogs. Did all of your coding settings but I'm rather worried about the 100% vs 13.7V for the PWM (Pulse Width Modulation). What's the difference in volts between them?
      05-11-2015, 09:20 AM   #53
VadikT
Russian Federation
Drives: BMW 316i (F30)
Hi!
Greetings from St.Pete
here's link to Drive2's guy, who have installed LED fog liights 1 month ago
http://www.drive2.ru/r/bmw/1067795/
      06-29-2015, 10:43 AM   #54
G20 WestMid
Drives: White F30 M Sport
Hi there guys. I was wondering if any one can help.
I have followed the coding instructions and the flickering has stop. But I still have the foglight error on the dash and when I turn the steering the cornering light nothing happens?
It will be great if some one can help me out.
      07-17-2015, 04:26 PM   #55
ktula
Drives: 2014 F31
I just installed the a pair of F32 LED fog lights on my 2014 F31. If i leave the PWM to the default 13.7V, the fog lights will flicker after about a minute. Changing that to 100% stopped the flickering. I don't know the difference in voltage between the two settings.
      07-17-2015, 06:15 PM   #56
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Originally Posted by ktula View Post
I just installed the a pair of F32 LEG fog lights on my 2014 F31. If i leave the PWM to the default 13.7V, the fog lights will flicker after about a minute. Changing that to 100% stopped the flickering. I don't know the difference in voltage between the two settings.
That's weird, I just had some new LEDs installed too, didn't need to code this as well. Did your LEDs come with an LED driver?
      07-19-2015, 01:51 AM   #57
ktula
Drives: 2014 F31
What do you mean by LED driver? The LED fog lights i installed are made by BMW for F32 and they replaced the entire factory fog light housings, so it's not just replacing the incandescent bulbs with LED ones.
      07-19-2015, 10:54 AM   #58
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Oh my bad. Then I guess that explains why they flicker. I just replaced the bulb, and the replacement LED has the driver which regulates the voltage from 12-32V.
      04-25-2016, 11:23 AM   #59
TrickyT
TrickyT's Avatar
Drives: 2015 Alpine White 328i xDrive
I've also seen these in some posts.
NSW_L_DUALSP_aktiv
NSW_R_DUALSP_aktiv
What do they code on/off?
Originally Posted by shag View Post
FYI, from Shawn:
NSW_L_KALTUEBERWACHUNG ğ nicht_aktiv
NSW_L_WARMUEBERWACHUNG ğ nicht_aktiv
NSW_L_KURZSCHLUSS ğ nicht_aktiv
NSW_L_IS_LED ğ aktiv
NSW_R_KALTUEBERWACHUNG ğ nicht_aktiv
NSW_R_WARMUEBERWACHUNG ğ nicht_aktiv
NSW_R_KURZSCHLUSS ğ nicht_aktiv
NSW_R_IS_LED ğ aktiv
      11-07-2016, 05:00 PM   #60
Randall
Randall's Avatar
260
Drives: G01 30i, E91 320dA
Is it possible to code it with Carly??
      03-21-2017, 02:41 PM   #61
bmw_fascinated
bmw_fascinated's Avatar
Drives: F22 228i
I got a pair of F32 LED fog lights that I want to fit into my F22 (some work needed because of M-bumper). Anyway, I just tested them with a laboratory power supply at voltages between 12 and 13.7 volts and they do flicker at all voltages, but least at 12.4V. The lab power supply generates a constant DC voltage level, so there can't be any PWM on the input side.
The flickering is at about 80-120Hz (I guess ... have to get a photo diode for my oscilloscope).
If this is normal, BMW must use a very cheap CC source.
      03-23-2017, 05:49 PM   #62
bmw_fascinated
Drives: F22 228i
And here are my results...
The lights have a 200Hz PWM with some random 30-100Hz peaks that cause some kind of short term flickering
I will contact BMW to find out if this is normal. If so, I will go for some bulb replacements as well or 3D print my own fog lights.
      02-10-2018, 11:45 PM   #63
IK6SPEED
Drives: BMW M3 / AH3
No Update in about a year.
What did you find out?
      03-03-2018, 07:26 AM   #64
bmw_fascinated
Drives: F22 228i
I never was able to reach someone of the engineering department. All email requests ended like: Give us your address so the local dealer can check your car.
After I had driven a Mercedes with LED headlight that appeared to me like stroboscopes, i believe all the manufactures do not bother this issue since only a few people complain and they can save a few bucks on every light...
My solution are the Philips H8 LED fog lights. Had to code it the same way as the original LED lights and with a little cap on top no one ever recognized them as not BMW parts.
      04-13-2018, 04:20 AM   #65
memintaniyan
Drives: f30
mirror side marker
FEM_BODY
Hello there ,
I want to keep the signal lights on the exterior mirror of the F30 constantly on. Can you help with encoding?
:yardım et: :yardım et:
      07-29-2018, 11:49 AM   #66
expl0de
Drives: BMW f30 320d and e92 320i
Hi, I did retrofit OEM LCI led fog lights and was doing some research for the coding. I don't have esys and use bimmercode instead, so I can't code VO for led fog lights.
When looking at the coding for other factory led's in the car (like halo's, rear led strips, third brake light and mirror turn signal), they have some identical coding, that differ from the coding of halogen bulbs.
I think the right coding for factory led fog's should be:
3061 NSW_R_CCM -> vor 7/12 or ab7/12. Mine is set to (before)vor 7/12(month/year) and I think it should be (after)ab 7/12
3061 NSW_R_UE_SPG_SCHUTZ -> nicht aktiv - all current leds are set to nicht aktiv and all incandescent to aktiv. So change to nicht aktiv
3062 MAPPING_ABBIEGEL_R_FIXED_PWM -> fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed
3063 MAPPING_NEBELSCHW_R_FIXED_PWM ->fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed
3061 NSW_L_CCM -> vor 7/12 or ab 7/12. Mine is set to (before)vor 7/12(month/year) and I think it should be (after)ab 7/12
3061 NSW_L_UE_SPG_SCHUTZ -> nicht aktiv -- all current leds are set to nicht activ and all incandescent to aktiv. So change to nicht aktiv
3062 MAPPING_ABBIEGEL_L_FIXED_PWM -> fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed
3063 MAPPING_NEBELSCHW_L_FIXED_PWM ->fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed
kurzschluss - don't change default value (aktiv).
dualsp - don't change default value (nicht aktiv).
