06-12-2015, 10:24 PM | #1 |
Rep 700
Coding Sport Display on HU_ENTRY?
I found where you can turn on the sport display, was able to get it to show up on the screen but it didn't do anything after that. Is there anything else I need to code to get the full display? I just has the base iDrive with office.
06-13-2015, 12:10 AM | #2 |
Rep 3,225
Only works with Pro Nav.
You can actually code them to show on the older head units but they don't move. Gimmicky waste of time anyway so I wouldn't lose any sleep over it! |
03-03-2017, 12:13 AM | #6 | |
Rep 116
Drives: F36 420da
If you have Sport Mode NBT > EFF_DYN_SPORT_CID > aktiv NBT > EFF_DYN_SPORT_UNIT > aktiv Works with Diesel and Gasoline Engine 2014 and onwards |
04-21-2017, 06:30 AM | #7 |
Rep 451
Drives: 2017 X5 & 2020 X5
Sport displays do work on the HU_CHAMP2 I have them activated on my 2012 320d
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
04-21-2017, 04:25 PM | #8 | |
Rep 5
I've done that two changes below but got only the gauges and they don't move. EFF_DYN_SPORT_CID > aktiv EFF_DYN_SPORT_UNIT > aktiv My Car is a 2012 318d with Champ2 |
04-22-2017, 02:57 PM | #9 |
Rep 451
I did exactly as you have done but I suspect there may be additional coding done of associated modules (FEM and KOMBI) that send the signal to the CHAMP2_HU or ENTRY_HU for the gauges to move when all the vehicle ECU's are VO coded at the factory I was thinking maybe 2TB or 7AC? PM me your chassis # and I can compare my FA against yours using bmwvindecoder.com
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 04-24-2017 at 03:56 PM.. |
06-20-2017, 03:19 PM | #10 |
Rep 5
I am pretty sure it's the engine that sends the singnals to Champ2.
BTW, thanks for your VIN Bambazonke. The difference to my car is: your car is a 320d (TYPE: 3D36) my car is a 318d, (3K11). Your car has a 2TB, my car a 205 Gearbox. Both have have SA 7AC (Sport Line) But the fact that your car is from 2012 and my from 2013-09 makes me believe that the smaller 318d engine is the main problem, which is not sending the signals which are needed for the Champ2 ECU. Nevertheless, I will try to VO Code SA-2TB, but I gess flashing the DDE to a newer I-Step would be the more promising way to go. |
08-04-2017, 08:04 PM | #11 |
Rep 401
Tried coding my early 2014 330d business Nav with Carly and the display is there but it doesn't work, any way I can get this to work?
Coded the live tyre temps too but yet again they don't work! |
12-06-2017, 07:43 AM | #13 |
Rep 149
Drives: M3 E92 with AA Stage 3 SC
How to change the unit from KW to HP?
12-07-2017, 05:16 PM | #14 |
Rep 2,271
In Vehicle Settings, change the unit under the power option. There's a few units you can change here like Miles to Km etc...
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
02-06-2018, 06:43 PM | #17 |
Rep 177
I'm also facing the same issue. Any new findings?
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?" |
02-07-2018, 02:21 AM | #18 |
Rep 83
Same problem, i have HU_ENTRY 318d F31, doesn't move.
I think, if possible, it needs an extra signal from KOMBI maybe. Maybe if SPA_SPORT_ENABLE set to activ? Cant find anything else in KOMBI for EFF, DYN, SPORT, CID or UNIT.. |
05-18-2018, 11:47 AM | #20 |
Rep 283
Can anyone comment on if the sports displays on a base 328i with hu_entry can be coded to have the sports displays WORK?
2014 F32 435i /// M Sport Brakes /// Vorsteiner VFF103 /// Resonator Delete /// MP Carbon Front Spoiler /// MP Carbon Mirror Caps /// MP Carbon Rear Spoiler
@slowf32 on instagram |
05-18-2018, 01:34 PM | #21 |
Rep 765
05-21-2018, 11:52 AM | #22 | |
Rep 283
