07-24-2016, 12:31 AM | #1 |
Rep 641
Help JB4 which map?
Hi guys, I recently installed my JB4 on my N20 328i EWG.
Right now I only have an Injen Cold air intake and chargepipes. which map should I run? Right now im on map 2. But I don't feel the car as fast as it should be. Which means I should be having around 260-270HP at the crank I believe. I don't know if throwing a downpipe it would make much difference with the map, but I am looking for a downpipe to put. So MAP 1 or MAP 2 for CAI and Chargepipes? |
07-24-2016, 04:33 PM | #4 | |
Rep 2,957
07-24-2016, 04:48 PM | #5 |
Rep 5,776
I have DP and use E85 on a regular basis and normally just keep it on Map 5 regardless of ethanol.
Last car: 2011 335i Msport. JB4. Vrsf CP |
07-24-2016, 06:29 PM | #6 |
Rep 641
Thanks for the reply guys! So is better for me to keep it on map 1 unless I get my DP. I didnt feel the car much different than stock with map 2. im going to play and see with map 1 and 5. Once I put my DP ill go back to map 2
07-24-2016, 07:28 PM | #7 |
Rep 641
I just changed my car to MAP 1. I also have a doubt about the OBD menu(speedometer menu).
'OBDII In Dash Menu '*************************************** '0 map menu, map shown on tach '1 Active Sound MUTE (not relevant for most N55 models) '2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. '3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. '4 OBDII Diagnostic Code Delete '5 1st gear boost limiter '6 2nd gear boost limiter '7 3rd gear boost limiter Menu 5/6/7 are they suppose to be on 0 or 1? I have menu 5 on 1 that means it has the limiter right? |
07-25-2016, 06:27 AM | #8 |
Rep 20
07-25-2016, 10:53 AM | #9 |
Rep 641
07-25-2016, 04:46 PM | #10 |
Rep 190,778
If you want more power get catless downpipe, dont run JB4 map 2 on stock DP
07-25-2016, 07:19 PM | #11 | |
Rep 52
