03-16-2014, 02:31 PM | #23 |
Rep 209
LED headlights don't generate as much heat as incandescent or xenon arc headlights. Because of this, the internal temperature of the assembly stays below the dew point longer.
In the Midwestof USA, new LED traffic lights are getting obscured with snow. The old incandescent ones got hot enough to prevent snow/ice accumulation. |
03-16-2014, 02:45 PM | #24 |
Rep 15,858
Thread from UK forum.
http://www.f30post.com/forums/showthread.php?t=952900 Note the references to the user manual. HighlandPete |
03-16-2014, 03:49 PM | #25 | |
Rep 2,266
F30 Sapphire Black M-Sport 335i 6MT
03-16-2014, 04:22 PM | #26 | |
Rep 15,858
Same for the F10/11 5-series.
HighlandPete |
03-16-2014, 04:25 PM | #27 |
Rep 557
If it's normal, then I'm fine with it although I think that it shouldn't be showing condensation. I've owned 6 bmws before and I've never seem it on any of my vehicles so this is a first for me
'06 325Xi - Jet Black - SOLD, '08 328Xi - Jet Black, Coral, 6spd - SOLD, '07 328Xi - Jet Black, SOLD, '11 328Xi, Deep Sea Blue, Oyster/Black - SOLD
'14 428XI, Alpine White, Coral, MSport, Auto, Premium, Tech, Heated Seats/Steering, Drivers Ass, Drivers+ - On Order for ED |
03-16-2014, 04:35 PM | #28 | |
Rep 15,858
The important thing is it dries off after a short time. HighlandPete |
03-17-2014, 08:49 AM | #29 |
Rep 1,728
I had the same problem when I first picked up my 435. I havent seen it recently though. Once the humidity levels dropped I stopped seeing the issue so much.
It is true though, with the LED headlights it seems not as much heat is generated and condensation will take longer to burn off. Regardless, it can be an eye sore at times and there should be a solution. As it stands right now... I love the LED headlights anyway.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
03-17-2014, 11:54 AM | #30 |
Rep 609
I have seen this on other BMW's I've owned, specifically my 2008 E92, they verified it and replaced a headlight assembly.
I can't blame the dealer for not taking action solely from a customer provided picture. That's asking for a little much in my opinion. Does the condensation cause any problems? does it affect the light output or damage the electronic circuitry? Or is it purely a cosmetic issue
2019 Z4 sDrive 30i Msport,
Previously owned BMWs, 2014 428i Msport, 2008 335i Coupe, 2007 328xi sedan, 2002 325i sedan 1996 318ti (loved this little car) |
03-17-2014, 03:50 PM | #31 | |
Rep 557
03-19-2014, 01:51 PM | #32 | ||
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
03-19-2014, 02:40 PM | #33 |
Rep 386
This is normal...for a 20 year old Pontiac Grand Am or Toyota Camry. I've never seen condensation in the headlights of any late-model car, and I would be appalled if I came out to my car one day and the headlights were fogged up. For what it's worth, I'm in the SF Bay Area which has well above average humidity, too.
03-19-2014, 02:43 PM | #34 | |
Rep 2,266
01-06-2016, 03:27 AM | #35 |
Rep 2,444
Drives: 2018 630iGT sport
Mine do the same, and I agree, not the kind of aesthetics you want on a £50k car, regardless of what the handbook says.
I tried removing the bulb covers and blasting a hairdrier at the lens for a while to evaporate the condensation - then left the bulb covers off overnight (with the bonnet closed, obviously). That didn't work, despite it being the usual route to solve this on previous BMWs. What I have found helped (to the point there was no condensation in my headlights this morning after driving to work), was to use some silica gel. You know if your missus buys a new handbag or something, you get those little paper sachets of silca gel. I carefully placed them inside each headlight and put the bulb covers back on. Left it for a day or 2 (didn't need to use the car), then took them out. Seems to have worked....for the time being, at least. |
01-06-2016, 06:33 AM | #36 |
Pace Car Driver
1548
Rep 3,164
Dafuq people.
It's normal. Says so in the owners manual. Headlights can't be completely sealed. The little bit of heat the LED / Xenon create needs to go somewhere. That little bit of heat will also take care of the condensation. I've seen the M3/4 guys crying about the headlights not melting snow and ice too. |
01-06-2016, 06:53 AM | #37 |
Rep 938
Also happened to me. My BMW dealership told me it was not normal and they required replacing. However my warranty wouldn't cover that area so I left it.
It eventually went away but still....very annoying. |
01-06-2016, 10:05 AM | #38 |
Rep 105
My dealership replaced my headlight when it was getting condensation under warranty. If it impedes the function of your headlights, which IS a safety hazard, they should be replaced.
01-06-2016, 02:42 PM | #39 |
Rep 3,622
Same thing on my mom's M4. The lights will be replaced at the 1200 mile service.
BMW CCA Member #516012
01-06-2016, 04:07 PM | #40 |
Rep 4,323
well all lights are "vented" so that might be part of the issue...since LEDs run a lot warmer than Xenons, maybe that's why we're seeing this more?
01-06-2016, 05:38 PM | #41 | |
Pace Car Driver
1548
Rep 3,164
LEDs in snow storm: http://f80.bimmerpost.com/forums/sho....php?t=1206896 Last edited by G30 B58; 01-06-2016 at 06:45 PM.. |
