BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > ???235/35 R19 on the fronts
      08-23-2012, 04:35 PM   #1
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
Question ???235/35 R19 on the fronts
guys, any thoughts on running this set up.. of course we are talking about m5 reps 35et on the front and 38 on the rears.
so for clarity:
235/35 front vs 225/40
255/35 rear
the only thing in this world that gives orders is balls. You got that? Balls.
      08-23-2012, 06:41 PM   #2
onehungevo
Drives:
I have 235/35/19 in front on M5 reps
      08-24-2012, 12:06 AM   #3
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
yea but with 255 on the rears... I know u have 265/30 and supersports but I was thinking 235/35 255/35..
thnks for ur input anything helps
      08-26-2012, 10:34 PM   #4
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
need more input as far as looks wise..
235/35 r19 fronts 35Et
255/35 r19 rears 38Et
      08-27-2012, 03:30 PM   #5
cardnation
Güten Täg
cardnation's Avatar
Drives: 91 E30 & 13 F30
245/35 (25.8") and 255/35 (26.0") are closer in size than a 235/35 (25.5").
245/35 and 255/35 are my choice, closest to stock height (25.9") I've found.
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone
      08-27-2012, 05:27 PM   #6
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
Exclamation Updated Pics!
nice write up! thanks for the input. heres what im about to run:
235/35, 255/35
      08-27-2012, 05:44 PM   #7
cardnation
Güten Täg
cardnation's Avatar
Sure thing. The tool below is a great link for comparing sizes.
http://www.rimsntires.com/specs.jsp
Don't get me wrong I really like the look of the 235/35, but 1/2" is a BIG difference.
      08-29-2012, 03:38 PM   #8
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
thats what i thought too.. too bad i pulled the trigger on the 235's..at the time it was between 225 and 235..
sneak peak top view
      08-29-2012, 03:48 PM   #9
DominNYF30
DominNYF30's Avatar
Drives: 2013 335i F30 Sport Line
Can you upload more photos how the car look.. Im getting the same rims on the same car and color..
      08-29-2012, 04:18 PM   #10
Fugly M3
Fugly M3's Avatar
5068
Drives: 2023 M3CX
why not 235/40 fr and 265/35 rr?
      08-29-2012, 04:33 PM   #11
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
yea i got more pics im uploading now bare with me, theyre not so much of the whole car
      08-29-2012, 05:11 PM   #12
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
i held back on the 40 profile JUST to be even with the rears and less squared look.. 35 front and back thought it would look better on the rim itself too imo.
i could have ran 265/35 on the rears but i was trying to keep the tire width within close range. 225/40, 255/35 OEM specs>theres about 1 3/16 inch difference.. width on the rim setup has inch apart 8.5-9.5 clearly. so i just wanted to match those figures as well. correct me if im wrong, 235/255 matches that inch difference and i was happy with the comparison of the tires (off the car-top to bottom view) as you can see here. OVERALL, it was personal preference.. although 245/265 dnt sound bad either..
      08-29-2012, 05:43 PM   #13
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
Smile 235/35 f 255/35 r
the tires are great and the setup i went with as i have explained earlier is my preference. Need lowering asap! . pardon my flipflop and the stray pup
      08-29-2012, 06:02 PM   #14
justinnum1
Drives: 2018 330i Msport 6mt
^needs a drop
F30 330i Alpine white/Coral red Msport 6MT
      08-29-2012, 07:51 PM   #15
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
fronts
more pics
      08-29-2012, 07:55 PM   #16
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
side view
      08-29-2012, 08:39 PM   #17
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Really? Flip-Flops w/ socks?? lol ... major camel toe!
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      08-29-2012, 09:50 PM   #18
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
haha
      08-30-2012, 01:13 AM   #19
awhk
Drives: 2023 iX M60 SBM
so for clarity:
235/35 front vs the 225/40
255/35 rear
What's the advantage of running the undersized/wider front instead of factory's recommended 225/40?
      08-30-2012, 01:46 AM   #20
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
what do you think unless you really dont know ill answer
      08-30-2012, 02:01 AM   #21
awhk
Just wondering as I've seen few F30'ers on this forum using the same size for the fronts already.
      08-30-2012, 04:16 AM   #22
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
well in general running a thinner tire gives you less tire sway when cornering and improves handling overall. wider tires will cover more ground when cornering or take off for the rear, which grip the road better and also improve handling.
soo the advantage is better handling.
