11-24-2022, 05:40 AM | #529 |
713
Rep 755
Never heard of such a case, but we have a hard time believing a transfer box that creates noise with an open clutch is able to function normally when operating.
I guess you are hearing a grinding noise from something in the rest of the drivetrain. Maybe a worn bearing or something touching because of a worn bushing. So something that gets amplified in RWD mode, but is already there anyway. This needs to be checked by mechanic directly at car. |
11-25-2022, 10:43 AM | #530 | |
Rep 5
Finding a good mechanic is a bit tricky here (I'm near Padova in Italy). Official dealer will just suggest to replace everything, as they always do. I'm thinking to look for a good BMW specific workshop in Austria or even in Munich. Any suggestions welcomed. There is another noise, high tone, coming only in AWD mode, at speed between 120-160km/h and with throttle on. This seems to be front diff. But this is not linked to xDelete anyway. |
11-29-2022, 02:57 PM | #533 |
Rep 2,815
Drives: F33 430 and F39 M35i
I had no issues or noise when using xdelete. It actually came in handy one morning. I got a flat on one of my 17” snow tires. Had my daughter bring me two of my 18” all seasons. Threw them on the back and the car was making weird noises while exiting the freeway. Remembered I had xdelete and turned off xdrive and no more noise the rest of the way home. Patched the flat and went back to awd for the winter.
NewEngland-650i0.00 |
12-04-2022, 02:21 PM | #534 |
Rep 5
12-06-2022, 03:21 AM | #536 | |
Rep 5
I'm thinking to change the transfer box oil (not sure yet if I take the box out or do several 1/2 volume changes). What I'm not getting - why the noise is coming from the transfer box only in RWD mode and only when throttle is over 50% and for just few seconds. My guess is that at this moment, when torque is coming up, the car would normally engage the clutch to connect front wheels. But xDelete prevents it from doing so. Could the clutch actuator still be moving, but not full way? |
01-12-2024, 03:36 PM | #539 |
Rep 3,905
There is always a norm! Especially in Germany! There is even a norm for how a norm should be defined.
01-17-2024, 05:00 AM | #540 |
Rep 3,905
It has been discussed that the driveshaft of 340i/440i xDrive is the same as the RWD versions.... which is good. However, I just learned that the rear differential is different! The one in the xDrive versions is used also on 330i/430i RWD.... suggesting it is not as strong as the one used in 340i/440i RWD cars, which is only used on those engines (with RWD).
Hence xDelete is putting quite some extra stress on the rear differential... which is NOT identical with the rear differential on RWD cars!
02-17-2024, 12:55 PM | #541 |
Rep 2
Hi,
Does anyone else have problems with dtc working too sensitively when xdelete is active? On a dry paved road, the dtc flashes and cuts off engine power even during normal slow acceleration. It doesn't matter if I drive 10 km/h or 130 km/h, I can't accelerate even at half power without the dtc starting to limit the power. When xdelete is disabled, dtc works normally on both grippy and slippery surfaces. I increased the pressure of the rear tires by about 0.3 bar (the rear already had more pressure than the front) which helped a little, but not much. Does anyone have any tips on what could be causing this/what I could try to fix it? |
04-12-2024, 12:54 PM | #542 | |
Rep 333
llebnave6.50 mobbinthesteez22.50 |
