BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F33 VRSF Charge Pipe Install.
proTUNING Freaks
      06-09-2017, 05:55 PM   #1
Spammer
Drives: 435ic
Did a lot of research but did not find my exact car/charge pipe install anywhere so i figured i would post mine here. Hopefully it helps someone the way all the other posts of installs helped me. (Cross posted from n54 forums. Figured it would help here too.
Rhino stands work well for this. I have plenty of clearance to work under the car. 39.99 on Amazon. I used a floor jack as a backup in case one failed.
My blown charge pipe. 36k miles and JB4 Stage 2 Map 5.
The TB disconnect was easy. Had to remove the whole sensor first as it was quite the maneuver remove the OEM CP and didn't want to damage the map sensor. There is under bracing near the lower CP that has to be overcome to remove it from the top. Take your time there is some plumbing underneath you don't want to damage by forcing it.
I used a flat head screw drive to 'pop' off the black tabs that hold the lower charge pipe clip in. Don't worry about hurting the black tab fitting when you pop it off, it is not reused.
VRSF CP finally came.
Packaged pretty well.
Use a little silicone grease on the sensor o-ring to get it in there. Its very snug but some grease it goes on easily with soft steady pressure.
I had to go under the car with a piece of wood and wedge it between an engine brace and the top CP to get leverage to push it on the TB nice and snug. I could not do it by hand.
The bottom was exceptionally easier. Snugged right up and clipped on tight.
Took my time tighting both t-bolt clamps. It was easier for me to put everything on loose get both upper and lower clips on first and then tighten the t-bolts on the silicone.
And the last part of course, installing the BMS Intake. Was very easy no need for a write up.
All and all i used the ER Charge pipe PDF as a guide. I did it my own way but for the most part followed the guide located in this thread.
http://f30.bimmerpost.com/forums/sho....php?t=1151005
Car sounds great, only on Map1 right now, might do map 5 auto learn later on once im confident its broken in.
The BMS intake, WOW what a difference in sound. You can hear the turbo spooling up great now and the DV now sounds almost like a BOV its so predominant.
As far as the VRSF CP its great, it gets the job done. It doesn't LOOK as nice as the ER does, but its also almost 200 cheaper. Its got it where it needs it though.
Good fitment, super snug on TB and IC, quality clamps and stock OEM black look.
Tiago at vrsf was a great help, got the pipe out to me in 4 days and i couldn't be happier.
I hope this helps someone as you've all helped me alot already.
Thanks!
bmbweber235.50
spuntyb4060.50
      06-12-2017, 02:12 PM   #2
ETexas335
Drives: 2007 335i Sedan
Did my CP over the weekend and had a similar experience. I still cant believe the crappy factory CP - mine blew out, totally stock at 54K miles. Car feels stronger than before, but I'm thinking I was starting to lose some boost before it blew so the gradual loss of power was probably masked somewhat.
      06-12-2017, 06:01 PM   #3
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Nice!
Thank you for the DIY guide
https://x-ph.com/sale/
Phone number 702-494-9435
      06-12-2017, 08:32 PM   #4
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Great to hear you're enjoying the chargepipe! I'm glad we could be part of your build!
      06-12-2017, 08:49 PM   #5
f32alex
Drives: 14' F32 435i
what are the symptoms of a blown charge pipe?
      06-12-2017, 09:45 PM   #6
mike@x-ph.com
Boost leak
      06-13-2017, 08:43 AM   #7
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
do they have one for the xdrive yet? there are very few options for us xdrive guys.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      06-13-2017, 08:45 AM   #8
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Our XI chargepipes should arrive and ship in the next couple days
      06-13-2017, 08:52 AM   #9
wdeerfield
A family of bimmers
im out of new vehicle warranty so its time to place a few orders. pairing your CP with your FMIC is step one for me.
      11-07-2018, 08:50 AM   #10
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Do the DP too while you're under there
      11-07-2018, 09:57 AM   #11
mike@x-ph.com
Very good start
+1
      11-08-2018, 01:56 PM   #12
wdeerfield
A family of bimmers
I'm in ny. Don't want to deal with figuring out how to pass emissions
      11-08-2018, 03:53 PM   #13
XxThe_RemedyXx
967
I am too
      11-09-2018, 04:27 PM   #14
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Returning to stock would be the easiest. Or $$$$ someone to look the other way
      11-09-2018, 04:38 PM   #15
wdeerfield
A family of bimmers
Doesn't work that way. Swap back on xdrive is too much of a hassle and you need readiness monitors to pass. Can't "look the other way" like we can for tint on inspections
Korvo368.00
      11-11-2018, 08:34 AM   #16
oma3710
oma3710's Avatar
195
Drives: ?
Did u have to remove the big triangular brace? Below is the pic.
SOLD! X5 35i sdrive- JB4
SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~
      11-11-2018, 04:28 PM   #17
oma3710
oma3710's Avatar
195
Drives: ?
Never mind. I got the chargepipe installed without taking the brace off. To install the intercooler you will have to take it off. Does anyone know the size of the torx that are on the front of the brace?
      02-05-2024, 07:28 AM   #18
heliskiier
Drives: 435i Vertible
Sorry to revive an old thread, but I have a convertible with that big brace. Is it just a matter of removing bolts to take it off? Just want to be sure before I get under the car and mess with those 20 screws to take off the bottom plate when I'm doing my intercooler. Also is it possible to work with only half the bottom pan down?
VRSF Charge/Boost
ARM Intercooler (working on it!)
ARM Catless DP (thinking on it)
BM3 Stage 2 E30
BM3 E30 Conversion Kit
      02-05-2024, 12:32 PM   #19
SJLenz1340
Drives: BMW 435i
I am too
If emissions is of concern, as it was for myself, buy Active Autowerks catted down pipe. It is the only one I know of that is EPA certified and it will not throw a CEL, more importantly all monitors show as ready. Just passed my test in the peoples republic of Illinois.
charge pipe, convertible, f30, f32, f33
