04-26-2023, 04:56 PM | #89 | |
Rep 4
05-05-2023, 04:12 AM | #90 | |
Rep 10
Revisituing old post ATZEBMW or Kiwkdecal please
Hopefully either of you Atzebmw or Kiwidecal would read this. Or if anyone can help provide detail instruction on how to change VO / FA country and language from Japan to NZ please? New learner to e-sys and wanting to change Jap import to NZ navigation. I am able to read FSC from nbt of my car but not sure how or where / what value to change VO/FA to.. helpe anyone ? THANKS in advance |
05-05-2023, 01:54 PM | #91 |
Rep 2,047
Delete these from fa
807 National version japan 852 Language version Japanese and add these to FA. 810 National version Australia 853 Language version English For editing FA look at the link below. https://www.bimmerfest.com/threads/c...sheets.983245/ If you have NBT then you can just code and map FSC will change to ECE. After that extract the FSC and generate code for maps you want to install If you hhave NBTEvo you will have to do region change using feature installer. You will receive FSC files. Copy fsc to usb with maps and maps should start updating. |
hawk1880.00 |
05-06-2023, 01:22 AM | #94 | |
Rep 10
Nav change from Jap to NZ
Have a great day !! |
05-06-2023, 07:49 PM | #95 | |
Rep 10
A little follow up help please
I need some help please next on "If you have NBT then you can just code and map FSC will change to ECE. After that extract the FSC and generate code for maps you want to install" Can you please tell me what value/where to code sir ? sorry to trouble you... i'm ok with changing values in FDL coding if thats where I'll be changing.. just need to know what vlaue to change to >.. thanking you in advance... |
05-07-2023, 01:56 AM | #96 |
Rep 2,047
If you coded using fa then you are good to go. No need to do any fdl coding.
Now check if you have 00A0 FSC accepted. After that you need to extract DE FSC and generate map code. Pm me i can help you with extracting the fsc and getting map codes. |
05-07-2023, 05:30 AM | #97 |
Rep 10
Thank you sire. So I have done all the above successfully.. and got the map updated to Aust/NZ NEXT 2022.. done the fsc extraction and generated code..etc.etc.. all good
BUT now the Navigation option is grayed out. The 00A0 FSC reads "Rejected" and more reading says its a Region Unlock code I need. ( different than the FSC generated code ), Hope you can help me as I felt i was so close .... Thank you once again Captain. |
05-08-2023, 01:20 AM | #99 |
Rep 10
Thank you .. I am downloading the full pszdata as i understand flashing the ECU (NBT ) will require the full database. Will give the flashing a go - my last option i guess.. thank you again for your time Captain TheNine90 !
05-11-2023, 06:57 AM | #100 | |
Rep 9
FSCSCertStatus accepted FSCStatus rejected AppNr./UpgrIdx 160(0xA0)/1(0x01) SWTType SWTclassic full What should I do? Thanks in advance. |
05-15-2023, 05:40 AM | #102 |
Rep 10
@stjackBMW - I haven't got around to flashing my ECU and will share with you when I do either way ( success of fail ) ......please share if you have managed to flash your ECU ..... cheers
05-17-2023, 03:58 PM | #103 |
Rep 3,056
Just need to load appropriate FSCs to solve this
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-03-2023, 03:19 AM | #105 |
Rep 60
Hi Stack, did you get this sorted? im in the same boat and wondering if a eu map and the correct keycode will bring it back to life. thanks
08-06-2023, 08:49 PM | #106 |
Rep 36
Hi man i am also in nz did you work it out on esys? is that possible i can learn from you please?
08-12-2023, 10:53 AM | #108 |
Rep 1
Hi Fellas,
I have the same problem. I got an NBT, car (JP import) is programmed to EU/Germany and we installed EU maps but the car will not accept the FSC. I understood that when you copy the FSC to the USB with the map data you should place it into a folder named "FSC" in the main root but I have not tried that. Any other tips I could try? |
08-12-2023, 11:17 AM | #109 | |
Rep 40,779
08-22-2023, 02:38 AM | #110 |
Rep 60
hi i have changed FA, coded nbt, (f10), finally managed to flash nbt but the fsc status is STILL AppID 160(0xA0)
UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted it has taken me weeks to even flash the nbt, finally got it to work with 3.27 using tal from 3.4 after failing after the bootloader as many have found, at that was AFTER setting up dhcpserver.de on the computer..... all files in nbt are black when looking to update except 2 ENTD_00001A07_006_016_002 and NAVD_000014B7_255_001_103 can anyone please help. thank you |
