BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Best Launcher
      01-13-2022, 02:05 AM   #1
Merlino31
Merlino31's Avatar
Italy
Drives: BMW f31 320 modern
Best Launcher
Hello forum,
since Tokenmaster is not updating more his launcher and I need a option for use last version of Esys also with Gxx series I'm looking for a new solution.
I found EsysX and Esys Plus 4.0
Can someone tell me what are the differences and the best option?
BMW f31 320d Modern 6MT
      01-13-2022, 02:46 AM   #2
Siki78
Siki78's Avatar
136
Drives: F30,G30
Esysx doesn‘t sell anymore fdl coding solution at least not for now then stay just esys plus 4.0
      01-13-2022, 02:49 AM   #3
Merlino31
Merlino31's Avatar
Italy
Esysx doesn't sell anymore fdl coding solution at least not for now then stay just esys plus 4.0
Okay, I'll buy it! Is it a problem use Esys Plus 4.0 with last Esys and full Pzdata on older car like f3x pre LCI?
Have you a link to download last version of esys and Pzdata full?
      01-13-2022, 05:44 AM   #4
Siki78
Siki78's Avatar
136
Drives: F30,G30
No you can use it on all cars with esys 3.36.2 and last psdzdata
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      01-13-2022, 05:45 AM   #5
Merlino31
Merlino31's Avatar
Italy
Where can I download Esys e Pzdata?
      01-13-2022, 08:17 AM   #6
Siki78
Siki78's Avatar
136
Drives: F30,G30
You have PM
      01-13-2022, 04:09 PM   #7
Merlino31
Merlino31's Avatar
Italy
You have PM
Just seen, thank you so much!
      01-30-2022, 04:30 PM   #8
Ahmaddoski
Drives: 2020 bmw 330i Us spec
I want same solution can you provide me with it too
      07-16-2023, 01:40 PM   #9
MAMJAZZ E60F30
Drives: E60 F30
ESYS 3036 & Full data for BMW F series
can you please share the download link you got from him;
I am in a bind and my BMW F30 coding was erased with no prior back up so I am trying to Inject default coding
Thanks
      07-16-2023, 01:48 PM   #10
MAMJAZZ E60F30
Drives: E60 F30
You have PM
ESYS 3.36 + Database to wake up my BMW who is in a Coma state because someone erased the coding and eeprom data when trying to program a key. He did not save coding so CAFD IS 000.0000.0000; I am not completely sure but I think I must start by:
1- Injecting the default coding
2- reprogram the keys
Please, feel free to assist if you have any idea or rough guidelines
Thanks in advance
      03-25-2024, 09:23 AM   #11
yupetc
Drives: 2015 X535i
You have PM
Any luck for me to also get the 3.40 and the launcher? Much thanks!
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP
2017 540i - MHD2+, VRSF DP, TU Pump
      03-25-2024, 10:57 AM   #12
Siki78
Siki78's Avatar
136
Drives: F30,G30
To use newer esys like 3.40 or higher you will need to buy bimmerutillity or esysultra.
