BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Update NBT EVO Q to X or newer
proTUNING Freaks
      07-17-2022, 04:36 PM   #1
smojo
Drives: 2018 340i GT xDrive
I'm looking to update my firmware from Q to X or newer, but I'm not finding any info on where to find the update files and software or any guides. Is it possible to do this myself with an enet obd cable and laptop?
      07-17-2022, 11:22 PM   #2
TheNine90
Drives: bmw
Yes,just search on how to flash using esys. It's possible to use enet cable. Just use latest psdzdata, not sure which latest version it will be but psdzdata 4.35 was Nbtevo_Y
      07-18-2022, 12:23 AM   #3
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
You can try this guide and instead of KOMBI, HU_CIC, just carry out the steps for HU_NBT2.
https://www.coursehero.com/file/4946...Guide-v101pdf/
Not sure how adept you are in E-sys but I wouldn't recommend this for beginners. Given that you have a 2018 model already, it should be on N or higher so you can just use Feature Installer to enable Fullscreen CarPlay without the need to flash the head unit.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      07-18-2022, 02:31 AM   #4
dangerus_car
Drives: F30
how do I check my NBT EVO version? what's the feature difference between different NBT EVO Q to X or newer software version?
      07-18-2022, 03:42 AM   #5
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
none, there is no reason for you to take that risk.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
      07-18-2022, 09:10 AM   #6
steve@codemybimmer
Hong Kong
665
There's really no difference feature wise, just some bug fixes and minor run time enhancements.
To check the version, press MAP -> OPTION -> then go to position and version and see what letter comes after NBTevo.
If it's N or above, it's much easier just to pay a nominal fee to a vendor to have it enabled through feature installer as opposed to flashing your head unit.
There's always that 1% chance of a failure due to faulty components that age over time so even the dealer will not do it unless there is something that calls for the firmware update.
      07-18-2022, 10:04 AM   #7
dangerus_car
Drives: F30
N18092I or N18092l
not sure if the last digit a capital I or a lower L because it will look the same
so I guess I am ok?
      07-18-2022, 10:16 AM   #8
RuleNormaliai
235
N18092I or N18092l
so I guess I am ok?
yes, you're OK, you don't need any updates, it is not worth the risk, your software already support everything you may want to enable.
      07-18-2022, 10:18 AM   #9
steve@codemybimmer
Hong Kong
665
N18092I or N18092l
so I guess I am ok?
Yep, that firmware supports Fullscreen via Feature Installer or USB. I'd recommend going with Feature Installer as it works 100% of the time.
      07-18-2022, 06:02 PM   #10
kubax86
kubax86's Avatar
Drives: M2
N18092I or N18092l
so I guess I am ok?
Yes, you're good to go. No need to update firmware like others said
      07-18-2022, 09:15 PM   #11
dangerus_car
Drives: F30
another question, lets say in iOS 16, Apple updates their CarPlay. Will the Carplay in the EVO unit get updated as well to the latest version from Apple? Or it's just stuck to whatever version it has now with no way to update it.
thanks.
      07-18-2022, 11:15 PM   #12
steve@codemybimmer
Hong Kong
665
thanks.
Any updates on iOS will propagate to the car automatically since CarPlay is merely a mirror of your iPhone.
      07-19-2022, 02:42 PM   #13
cooombs
Drives: 2018 440i xDrive
Is feature installer a third party application or from BMW directly? What is your and the various other vendors who offer the codes for this application’s affiliation? Do codes from one vendor to the next offer different features?
      07-20-2022, 12:58 PM   #14
kubax86
kubax86's Avatar
Drives: M2
Feature Installer is a third party app.
Codes are all the same, what matters and varies is support/price.
cooombs24.00
      12-12-2022, 11:11 AM   #15
icarcamo
icarcamo's Avatar
Drives: F30 335i & F80 M3
NBT EVO-R
Quick update to this and a question, I used Bimmercode to try and code "fullscreen Carplay" and Bimmercode gives you the disclosure message that says that ONLY EVO-X and EVO-Y will activate fullscreen. I tried any way on EVO-R and it didnt work, only shows blank screen on right side and cant turn off or on "split screen" so I guess that anything earlier than X/Y, will not activate fullscreen Carplay. If i missed something let me know and i can try again.
      12-12-2022, 12:30 PM   #16
TheNine90
Drives: bmw
Coding Apple CarPlay fullscreen is available on NBTevo Version X or above. Below NBTevo_X use feature installer to activate fullscreen.
      12-12-2022, 02:46 PM   #17
kubax86
kubax86's Avatar
Drives: M2
PM sent
      12-12-2022, 04:16 PM   #18
icarcamo
icarcamo's Avatar
Feature Installer like BimmerCode? Doesn't work, what other feature installer can be used?
      12-13-2022, 10:03 AM   #19
kubax86
kubax86's Avatar
Drives: M2
Doesn’t like it.
Need restore to oem before using bimmercode
      12-13-2022, 01:22 PM   #20
SimonBMW1
Drives: BMW 4 Series
I have the pstzs data. I just want to update the headunit on a f20.
My laptop doesnt have enough space. Is their a certain folder i should just extract or do i need it all
      12-14-2022, 12:03 AM   #21
TheNine90
Drives: bmw
Calculate the tal and see what swe are missing. Copy the missing swe to your psdzdata
      12-15-2022, 03:59 AM   #22
SimonBMW1
Im guessing i just need the SWE folder then
