02-27-2012, 11:17 PM | #1 |
Rep 362
N20B Engine - 320i vs 328i (Same?)
Hey, just wanted to ask if anyone knows the difference between the N20B 320i and the 328i. I've went to the dealership and was told that it was diffrent but they could not explain to me how it differs.
So I've done some research just looking up at the BMWparts and it shows me the following ; Both 320i and 328i engine code is N20B2000 Both Compression Ratio, Bore Stoke is the same. Both items are sharing the same part number Engine Block SAME Intake Manifolds are the SAME Exhaust Manifold (Turbo) SAME Cylinder Head SAME VANOS Valve SAME Vacumn Control + Pump SAME Throttle Body SAME Intake Airbox SAME As you can see, Kelleners has already made a tune specifically for the 320i and 328i respectively. But what I do not understand is how come BMW and Kelleners actually made 2 different tunes if the foundation(components) of the vehicle is the same. I can't wait till other tuners are able to find more information to unlock the potential of the N20B. Would you now consider to buy a 320i or a 328i if both models are available in your country? |
02-28-2012, 01:10 AM | #2 |
Rep 141
I am waiting for more info on this as well. Do they have the same turbo physically?
If the 320i can be chip tuned to 280+hp, I would serious consider it over the 335i. A well equipped 320i is about $42,000 in Canada, but cannot be ordered with leather, sports seat, lumbar support, or Harmon Kardon sound. A 328i and 335i with these extra options will cost around 52k and 58k respectively. For now, I am going 335i xDrive. But if I can saving $20,000 and have just as much fun with a manual RWD BMW, I don't see why not. This is assuming that the 320i can be tuned to around 280hp. |
02-28-2012, 04:16 AM | #3 |
Rep 1,544
Not all are the same. Before Nov 2011 it had a different block & turbo. After that it seems the same, but it may change later again.
Compression ratio is different (10:1 for 28i & 11:1 for 20i) for F10 & F30, but same for both models of x1. What maybe happening is BMW is doing some sort of binning with these engines (i.e. if output is above official figures then it'll be a 28i, otherwise it'll be a 20i), after that they'll lock the power down for the 20i. For me I'll not bother with the 320i as there's vitually no price difference between the 2 if u spec them the same, plus it comes with smaller brakes than the 328i. |
02-28-2012, 04:27 AM | #4 |
Rep 1,879
Drives: 2012 F30 328i
For these alone I would choose the 328i over the 320i if these were the only differences.
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
02-28-2012, 04:52 AM | #5 |
Rep 10,185
Has been discussed here before
There are 2 different 320i N20 engines Different regions will get different ones. The "low compression" version is very similar to the 328i except for the Turbos The standard version has a different head for higher compression and different turbos. Most regions with proper fuel will get the standard version with higher compression
02-28-2012, 04:54 AM | #6 | |
Rep 10,185
02-28-2012, 05:39 AM | #7 |
Rep 1,544
02-28-2012, 05:43 AM | #8 |
Rep 1,544
02-28-2012, 05:54 AM | #9 |
Rep 913
The important thing is not the engine in isolation... what are the tranny specs? I bet the 320i has a lower spec tranny with lower torque capacity??
. ..sweet torquin' diesel! |
02-28-2012, 06:23 AM | #10 | |
Rep 10,185
different diff and different Gearbox to 328i Also 28mm drive shafts against 35mm 328i shafts Brakes are smaller too
02-28-2012, 06:24 AM | #11 |
Rep 10,185
Sorry, forgot that was with you
02-28-2012, 06:32 AM | #12 |
Rep 913
Thought so, so there lies the primary issue - yes the 320i may be able to be tuned to give same output as 328i... but you will likely stuff the tranny and TC in no time.
02-28-2012, 09:40 AM | #13 |
Rep 1,544
02-28-2012, 09:50 AM | #14 | |
Rep 10,185
But some markets get them for the 320i or 320d
02-28-2012, 10:10 AM | #15 |
Rep 1,544
03-04-2012, 10:30 PM | #16 | ||
Rep 362
I know there are probably also some differences in terms of brakes, and interior. Quote:
Thanks for the much appreciated info everyone! This thread has given alot more information then what those "BMW salesman" has told me. |
03-05-2012, 01:08 AM | #17 | |
Rep 10,185
Some countries get larger brakes on the 528i, but not all. Yes, the 320i and 328i have different gearboxes and driveshafts. The 520i and N20 528i use teh same gearbox and driveshafts.
03-05-2012, 01:14 AM | #18 |
Rep 10,185
Yes, the Euro 320i discs are smaller, but the Canadian 320i uses the same discs as the US-spec 328i and Euro 320d.
03-05-2012, 03:59 AM | #20 | |
Rep 10,185
Thats a option where each country can choose which brakes certain models get depending on local requirements. Its not a customer selectible option.
07-18-2012, 04:53 AM | #22 | |
Rep 10
Hi Bro,
Have you found any difference between 320i/328i engine except the exhaust? I tried to search a lot but came out the result that they're the same except the exhaust. Do you think a Tuned 320i = Tuned 328i? Quote:
Tags |
n20b engine, n20b motor |
