02-26-2013, 09:48 PM | #2817 |
Rep 40,650
PM sent, assuming it is for F10 M5.
02-27-2013, 06:22 AM | #2818 |
Rep 67
Hi Shawn - pardon my ignorance - why do I need a VIN with 614 and 615 - cant I just copy all the options mentioned in your post and VO code it to make it work.
02-27-2013, 06:24 AM | #2819 | |
Rep 40,650
You can try it though, and see if it works.
02-27-2013, 06:56 AM | #2820 |
Rep 70
2.48.1 and f020-11-504 worked for me :-)
2013 MG 335i
02-27-2013, 07:16 AM | #2821 | |
Rep 67
I have 6NH and Prof Navigation. To add BmW Live and Internet, do I need to do the following :- VO code 614, 615, 6AL and then VO code hu_cic and cmb_media in the same way we code from 6NK to 6NK? Anything else I need to do? Regards, Rajesh |
02-27-2013, 07:42 AM | #2822 | |
Rep 490
BTW, after you complete your coding, it is NORMAL to see the option in your idrive and it won't work... something along the line "homepage not available". Leave the car alone overnight or a couple of hours and try again. This is normal behaviour for ALL CARS that i've activated bmw live so far. But immediately after coding you should see the option appearing under BMW Services. |
02-27-2013, 08:28 AM | #2823 |
Rep 40,650
Yes, it may or may not work. It all depends on the car's options and ECU CAFD's and if it needs one from the newer version or not. 48.2 is the safe bet, and 48.1 is a crap shoot.
02-27-2013, 12:12 PM | #2824 | |
Rep 67
02-27-2013, 03:08 PM | #2826 |
Rep 17
Hi all:
I'm new to this forum, I got my cable today, already installed e-sys 3.22.5 on my macbook and copy the psdzdata 48.3 files; my 2013 328i Xdrive will be delivered tomorrow. What else I need to start coding? Thanks |
02-27-2013, 03:34 PM | #2827 | |
Rep 1,044
I would strongly recommend that you learn what the car does and gain experience with it in its factory state before you start coding.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
02-27-2013, 09:05 PM | #2828 | ||
Rep 17
02-28-2013, 10:07 AM | #2829 |
Rep 234
Me too, though I only coded the temp/pressures displayed in the tpms screen.
From my coding notes: F020-12-11-504 - ISTA/P version 2.45.1 PSdZDa: 48.1 Not sure what other coding options would be 'enabled' going from 48.1 to 48.2. |
02-28-2013, 08:00 PM | #2830 |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
in case anyone is interested you can make the LED lights on the mirrors be part of the welcome lights.
Fembody 3062 mapping_blinken_z_L_part of WL Fembody 3062 mapping_blinken_z_R_part of WL Turn both to "hard on" since they are LED's |
02-28-2013, 10:42 PM | #2831 |
Rep 664
Drives: 2013 BMW 335i
How do i code it so that my car doesn't check for error in the reverse lights? I put in error free LED reverse light but it flickers when i turn on car and randomly while driving.
Another member told me its the car constantly checking bulbs so it flicks when it check. Said it's possible to code it so it doesn't check. Is there an option to just code the reverse check only or if code the check off then its for all lights in car? |
03-01-2013, 05:57 PM | #2832 |
Rep 52
03-02-2013, 12:06 PM | #2833 | |
Rep 67
BMW Live is not working. It says internal error. Any suggestions/solutions. I VO coded 614 and 6AL. Regards, Rajesh |
03-02-2013, 01:11 PM | #2834 |
Rep 745
Same problem here, it used to work. I'm wondering if BMW are doing some server-side checks to see if your car can use BMW Live/Online. Mine worked for the first couple of weeks then stopped.
BMW iX M60, Storm Bay with XPEL Stealth PPF, Exterior Line Titan Bronze, 1EW 22" 1023 Wheels, Amido Leather, Comfort Package, Interior Camera, Clear&Bold, Sun Protection Glazing, B&W Diamond Sound, Folding Towbar, Rear Axle Steering.
03-02-2013, 07:06 PM | #2835 |
Rep 57
I have the software, a cable from One-Stop, and two computers (I first tried with Win8 using Ethernet via a USB dongle and then with Win7 with a built-in Ethernet jack). Neither computer seems to get a connection to my F30 (built in mid-January). ZGW_Search finds nothing and E-Sys won't enable the VIN connection option. The computers both appear to self-assign IP addresses in the 169 space.
Does anyone have any ideas to help get me started? |
03-02-2013, 07:41 PM | #2836 | |
Rep 1,044
Do you have all other adapters (WiFi, for example) turned off on the machine?
MY18 X3 30i:
03-03-2013, 12:11 AM | #2837 | ||
Rep 46
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
03-03-2013, 02:05 AM | #2838 |
Rep 67
All the effort to code 6AL and it does ot work. Is the service down? Any workaround?
