12-01-2014, 08:32 PM | #1 |
it can never be too clean...
163
Rep 1,100
19" wheels question for the F31 wagon m sport...
i'm adding the F10 5 series 19" staggered (8.5 & 9") 351m wheels to my F31 wagon... (retain the same overall look but with an upsize)
~ what tire size will be need to retain the same overall diameter of the factory 18" x 8" 400m (225/45/18) wheels currently on my car? 235/40/19 (8.5") front & 265/35/19 (9") rear? note: i'm not looking for a fluffy tire nor a banana peal (thoughts)? i also understand i may need a 10 mm spacer for the rear 351m wheels (offset) to make things flush. i'm also installing kw1 coil overs (a bit more wheel well height) than as the current h&r sports shown in the pics below. thanks again for any insight.
'14 328xi wagon / m sport / white / red leather kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar / sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra Last edited by andrew 330i; 12-01-2014 at 08:44 PM.. |
12-02-2014, 02:15 AM | #2 | |
Rep 5,140
I copy my answer from another thread:
Test fit the new wheels and tires first and then make decision regarding spacers. |
12-02-2014, 05:34 AM | #3 |
163
Rep 1,100
~ thanks for your quick reply!
another question: ~ which tire sizes that you posted will provide the shorter side wall? guessing these: F: 8.5x19 ET33, 225/40-19 (same diameter) R: 9x19" ET44, 255/35-19 (same diameter) i also don't want the tires to look stretched on an over sized rim, any additional thoughts?
'14 328xi wagon / m sport / white / red leather kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar / sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra |
12-02-2014, 07:39 AM | #4 |
Rep 5,140
Since you don't want stretched tires, you shouldn't choose 225/255. A 225 front tire will look stretched on 8.5" wide wheels.
I would then recommend your own suggestion in the first post, slightly wider tires with slightly higher side walls: F: 8.5x19" ET33, 235/40-19 (1% taller than stock) R: 9x19" ET 44, 265/35-19 (1% taller than stock) One more alternative, but not if your car is xDrive (since the front and rear rolling circumference isn't matched): F: 8.5x19" ET33, 245/35-19 (1% shorter than stock) R: 9x19" ET 44, 255/35-19 (stock diameter) The advantage with this combination is that the width difference for the tires and the wheels is both 1/2", i.e. the tires will fit very similiar on the front and rear wheels. Approximate side wall heights: 245/35 275/30 - 85mm 225/40 255/35 - 90mm 235/40 265/35 - 94mm Easy to calculate, follow this exampel for 225/40-19. 225 is tire width in mm and 40 is side wall height in percentage of the width. The side wall height is calculated as 225 x 0.4 = 90mm. |
12-03-2014, 08:27 AM | #5 |
163
Rep 1,100
~ my car is an xDrive.
so this is the consensus to accomplish the look i'm trying to achieve while keeping the overall circumference nearly the same? F: 8.5x19" ET33, 235/40-19 (1% taller than stock) R: 9x19" ET 44, 265/35-19 (1% taller than stock) your input is greatly appreciated!
12-03-2014, 10:49 AM | #6 |
Rep 5,140
12-03-2014, 11:35 AM | #7 |
Rep 942
Given that its xDrive, you should be very careful mixing tyre sizes. The OE sizes for the F31 with the 19" wheel option are the 225/40R19 and 255/35R19, as you have mentioned above. I would stick with these to be honest.
My Dad's F10 with 245 front tyres used to tramline terribly, given that the F31 is a lighter car, I wouldn't be wanting to increase the width of the front tyres without good reason. 225 tyre should be absolutely fine on an 8.5J rim.
2016 F80 M3
12-03-2014, 04:45 PM | #8 | |
Rep 1,649
F: 8.5x19" ET33, 235/40-19 (1% taller than stock) R: 9x19" ET 44, 265/35-19 (1% taller than stock) |
12-04-2014, 02:25 AM | #9 |
Rep 5,140
12-04-2014, 10:43 AM | #10 |
Rep 1,649
12-05-2014, 07:49 PM | #11 | |
163
Rep 1,100
