10-22-2014, 03:27 PM | #23 |
Rep 401
[IMG]F30 by googone20, on Flickr[/IMG]
[IMG]F30 by googone20, on Flickr[/IMG] [IMG]F30 by googone20, on Flickr[/IMG] [IMG]F30 by googone20, on Flickr[/IMG] [IMG]F30 by googone20, on Flickr[/IMG] Last edited by Googone20; 10-22-2014 at 03:42 PM.. |
10-22-2014, 06:11 PM | #24 |
Rep 83
Drives: SG e90 M3
specs?
10-22-2014, 06:55 PM | #25 | |
Rep 1,035
In either case, seems like whether OP goes conservative with +45 (then adding spacers) or aggressive, straight to +33, it will work fine and still look great! Last edited by squidlyboy; 10-22-2014 at 07:11 PM.. |
10-22-2014, 10:10 PM | #26 | |
e92 - 335i
179
Rep 743
10-23-2014, 06:38 AM | #27 |
Rep 401
I am actually running BMW's spec of rear wheels and tires for many of their cars. My car has X-Drive, so I wanted to go with a tire that was exactly the same outside diameter as OEM spec. I am running 255/35/19 Michelin PSS square on square 19x9.5 ET33. My goal was to be able to properly rotate the tires, and not effect the X-Drive.
10-24-2014, 12:53 AM | #28 |
Rep 83
Drives: SG e90 M3
I just picked up the wheels, now the question is ... I'm wondering whether I should go with F: 245/35/19 R:265/35/19 orrrr F:235/35/19 and R:265/30/198
10-24-2014, 01:11 AM | #29 | |
Rep 1,035
The 2nd set is a little more sexier (lower profile), but you might not be able to tell the difference. Its like trying to decide between new york strip or rib eye I swing a little more towards the 'form' crowd than 'function' but thats just me |
10-24-2014, 06:49 PM | #30 |
e92 - 335i
179
Rep 743
What ^^^ he said.
Keep in mind that different mfg's will give you a slightly different look than others. The 245 might look the same as a 235 from a different mfg. Some have more of a round or square side wall. |
05-31-2019, 05:53 PM | #32 | |
Rep 4,318
before you buy vmr v801 read this thread so you know what you might be getting...https://f30.bimmerpost.com/forums/sh....php?t=1619788 Last edited by alohasurftoad; 06-02-2019 at 08:55 AM.. |
Mkswoosh92.50 |
05-31-2019, 07:55 PM | #33 | |
Rep 385
