09-18-2019, 09:23 PM | #89 | |
Rep 147
This is a bad idea |
floridaorange10202.50 |
09-20-2019, 08:31 PM | #90 | ||
Rep 354
09-21-2019, 05:59 PM | #91 | ||
Rep 14
10-12-2019, 09:28 AM | #92 | ||
Rep 118
10-12-2019, 03:16 PM | #93 | |||
Rep 118
10-12-2019, 07:52 PM | #94 |
Rep 8
Unfortunately, these parameters are not found in FRM.
----------------------------------------------------------- REAR LIGHT BARS REMAPPED FOR TURN SIGNALS MAPPING_TAGFAHRL_H2_L_OUTPUT > sl_2_l MAPPING_TAGFAHRL_H2_L_FUNCTION > werte 06 MAPPING_TAGFAHRL_H2_L_PRIORITY > Priority 1 MAPPING_TAGFAHRL_H2_R_OUTPUT > sl_2_r MAPPING_TAGFAHRL_H2_R_FUNCTION > werte 07 MAPPING_TAGFAHRL_H2_R_PRIORITY > Priority 1 -- MAPPING_TAGFAHRL_H_L_OUTPUT > sl_l MAPPING_TAGFAHRL_H_L_FUNCTION > werte 06 MAPPING_TAGFAHRL_H_L_PRIORITY > Priority 1 MAPPING_TAGFAHRL_H_R_OUTPUT > sl-r MAPPING_TAGFAHRL_H_R_FUNCTION > werte 07 MAPPING_TAGFAHRL_H_R_PRIORITY > Priority 1 -- MAPPING_STANDL_H1_L_PRIORITY > Priority 3 MAPPING_STANDL_H1_R_PRIORITY > Priority 3 -- MAPPING_STANDL_H2_L_PRIORITY > Priority 4 MAPPING_STANDL_H2_R_PRIORITY > Priority 4 -- Turn off L/R Rear Orange Turn signal MAPPING_BLINKER_H_L_PWM_LEVEL_1 > 00 MAPPING_BLINKER_H_R_PWM_LEVEL_1 > 00 ----------------------------------------------------------- Can only FRM F10 have an opportunity to achieve it? Thank you |
10-16-2019, 10:26 AM | #95 |
Rep 118
heres a tutorial https://m.youtube.com/watch?feature=...;v=bpPu2_DjQTs
12-29-2019, 08:01 PM | #96 | |
Rep 3
“_H_R_” instead of “_H_L_” and “LEVEL_1” instead of “LEVEL_r” |
01-10-2020, 10:44 AM | #97 | |
Rep 741
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
04-27-2020, 01:01 PM | #98 | |
Rep 16
can we do it for angel eyes? |
06-22-2020, 09:08 AM | #99 |
Rep 5
Hello,
I have a Mini but I and browsing the internet to find experts in coding tail lights and came across this thread. I am wondering if you are able to help me. My project is to convert basic bulb tail lights in m MINI F56 to expanded pre_LCi version with LED ring. I am trying to figure out what is the best way to do it. In the current lamp i have 5 wires: ground, reverse bulb, direction indicator bulb and two wires that go to two bulbs that are regular lights and braking lights as well. They are both powered with 6V and voltage rises to 12V when brake pedal is hit. The LED lamp has the same bulb pattern and additional LED ring. The ring is currently not working as there is no wire to it and an empty spare slot in the plug. My first thought was that I should code the car with the LED light option (S5A4) and add extra wire from BDC to LED ring in the lamp, but i still have front halogen lights so I am affraid that this will cause a lot of faults to come up. I also found another car that has halogen front lights and LED rear lights and decoded its VIN - there was no LED option on the list. So, the second option would be to plug one of the existing wires with to LED ring and split the other to both bulb to work only as braking light. But then I would need to code the car to power LED wire with a constant current and the other wire (the splitted one) to supply 12V power only when braking. In this option I am also affraid if it is safe to split the cable to operate with two bulbs. Third option and I think this is the best one would be leaving wires as is but to code tail light bulbs only to work when braking so eliminating the double function of regular light. I would need to add an extra wire and program it to work with LED ring. If this is doable i need your guidance how to remap tail lights. What would be your recommendation? Thank you! Last edited by Enemy75; 06-23-2020 at 01:51 AM.. |
02-08-2021, 10:24 PM | #100 |
Rep 1,758
Answer to an old post. The reason it doesn't work is because NA/US spec tails do not have the LEDs in the assembly for the rear fog lamp.
2016 428ix, r, 2018 430iC, 2018 330it
04-18-2021, 02:05 PM | #101 | |
Rep 9
04-18-2021, 02:12 PM | #102 |
Rep 9
12-27-2021, 04:19 AM | #104 |
Rep 10
Does it applicable for E90 lci tails ?
01-15-2022, 09:14 AM | #105 | |
Rep 225
When it's really bright out you can barely see the bars blinking. My buddy who's was driving behind me warned me that he couldn't see my signal most of the time. If you are still interested here's a link |
03-04-2022, 12:55 AM | #107 | |
Rep 280
Anyone figure how to do this belly dance
2015 435i xDrive Gran Coupe - Black Sapphire, M Sport, MPPK, MPE RIP; 2015 C63 AMG Coupe - Obsidian Black, 507 Edition RIP; 2009 335i Sedan - Titanium Silver, Sport pkg, Premium pkg, FBO |
