04-08-2015, 01:31 PM | #1 |
Rep 101
Changing Bolt Patterns
Hello,
I used to have an Acura TL and had ADV.1 wheels on them. The bolt pattern is 5x114.3 and I wanted to know if wobble bolts are the best option to switch the pattern or if there is another better way. Also I am not even sure if the wobble bolts are even an option or possible. Let me know your thoughts. Thank you. |
04-08-2015, 02:06 PM | #2 |
Rep 1,101
I would imagine you are better off to sell those wheels and get some new ones that are the correct offset and bolt pattern for your BMW. I have had some pretty good luck selling my used wheels. I assume since you want to keep them that they are in good shape. See how you can do selling them.
04-08-2015, 07:02 PM | #3 |
Rep 713
You won't be able to use wobble bolts for them. The distance between 114.3 and 120 is too large. Wobble bolts are good for 2-3mm at most.
You may be able to use wheel adapters depending on the wheel specs.
04-08-2015, 07:12 PM | #4 |
Rep 25,989
+ 1
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
