08-07-2018, 07:08 AM | #1 |
Rep 3
F31 Code For Close Trunk/Boot with Key Fob and Driver Side Button
Hi Guys
I am new to bimmerpost and pretty new to coding for which i have only coded my f31 for bluetooth audio which I was so please with as I know if I would have taken this to BMW they would have probably charged me about £300! At the moment i can only open my boot with my key fob and the button inside the drivers side. But I have read the F31 can be programmed to also close the boot/tailgate with these same buttons. I think I have found what i need from a cheat sheet on here to enable this within E-SYS: HKFM 3010 SCH_FBD aktiv nicht_aktiv Button on key fob will be enabled to CLOSE the trunk HKFM 3010 SCH_TOEHKI aktiv nicht_aktiv Button on driver-side will be enabled to CLOSE the trunk But I'm not really too familiar with this path within E-SYS as I have only done the Bluetooth and pretty much found step by step instructions Would anyone be able to advise on just where to click etc once I have made my connections with E-SYS?? Many Thanks Dave |
08-08-2018, 03:16 AM | #2 |
Rep 603
You need to code also TASTER_FDB.
I did it on my F31. Works like a charm! Unfortunatelly I can't advice you with the E-SYS. Just too long ago when I did it. However I followed the enclosed PDF instructions (especially with the Backup of the original files. And Backup again befor every coding. And putting this in a safe place) No big deal then if you follow these instructions. Otherwise just search for local coder, or ask your BMW Partner if they would do it. Here is what I coded: HKFM 3010 SCH_FBD aktiv Button on key fob will be enabled to CLOSE the trunk HKFM 3010 SCH_TOEHKI aktiv Button on driver-side will be enabled to CLOSE the trunk HKFM 3010 TASTER_FBD aktiv Required for SCH_FBD and SCH_TOEHKI to work.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
08-09-2018, 06:42 AM | #3 |
Rep 3
Ah thanks for that the other thread i found with the cheat sheet didnt mention HKFM 3010 TASTER_FBD aktiv Required for SCH_FBD and SCH_TOEHKI
I will probably give it a try maybe this weekend and just poke around see if I can see anything Will have to do my research as I am still getting used to E-Sys! Many Thanks Dave |
08-13-2022, 06:30 AM | #4 | |
Rep 79
+1 |
02-03-2024, 12:05 PM | #6 |
Rep 16,083
If you have ESys everything you need to know has been posted. If not I recommend you get Bimmercode. This is probably a one click job with it, but if not the coding posted can be done in expert mode.
automatic, boot, close, code, f31, f31 3 series, f31 3 series forum, f31 3 series touring, fob, tailgate |
