BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 62K miles F30, BMW dealer says no need for transmission fluid replacement
      03-27-2024, 05:44 PM   #23
eff32fl
eff32fl's Avatar
1052
Drives: 2019 440i M Sport THP MPPSK
Originally Posted by sspade View Post
Directly from ZF:
Lifetime in most cases (maintenance free) but a good idea to change at 90k miles under harsh conditions or unknown history of use.
Read it and weep!
That's not what it says. It says they recommend an oil change at 90k miles. In more extreme cases with high heat or load doing it sooner is a good idea.
      03-27-2024, 06:10 PM   #24
Livetodrive
Drives: 2016 340i X Drive
My BMW service advisor stuck by the BMW policy that a transmission fluid change is not recommended and declined to do it. I then hung around until I found a more mechanically knowledgeable advisor. He agreed it should be done at my car’s mileage of 61,000 miles and agreed to do it.
To make a long story short, I ended up having the transmission fluid changed last week at a local indie BMW shop by an ex-BMW tech. He indicated that before draining the fluid they would take a sample and inspect it. If it was too contaminated they would not replace it. Mine looked good so they went ahead with it. The transmission felt the same afterwards with no issues. I had bought the transmission kit from FCP Euro beforehand and handed it to them. I also had the mechatronics connected sleeve seal replaced.
My take on all this is that “lifetime” fluid means about 100,000 miles. I bought my car new and want to keep it, so I had it done.
During the same appointment I also had the coolant, front and rear differential and transfer case fluids replaced. The brake fluid has been replaced every two years, per BMW recommendations.
danb19791897.00
      03-27-2024, 06:21 PM   #25
MidtownMike
Drives: BMW F30 LCI 320i M-Sport Shado
https://aftermarket.zf.com/us/afterm...assenger-cars/
      03-27-2024, 06:28 PM   #26
im_an_alien
im_an_alien's Avatar
1129
Drives: 2016 340i
Originally Posted by MidtownMike View Post
Nowhere do they mention the ZF8 nor do they clearly state that's it's necessary and at what mileage. Like I said, clear as mud.
ZF says it's recommended. So do it if you want, don't do it if you don't want to.
Tommo355.00
      03-28-2024, 02:31 AM   #27
monster6a2
monster6a2's Avatar
Drives: f30 335i xdrive
I've had ZF boxes in my E39s serviced with zero issues afterwards; ones currently on 176k miles now (I had the fluid changes when I owned it at 130k miles); the 2nd one was changed when I owned it at 80k miles, it's now on c150k IIRC
My 2002 Jap import E39 touring was serviced at 82k miles, I sold it at 99k miles and its on 120k miles now, zero issues and my last E39, another Jap import E39 540i Sport saloon was serviced at 52k miles and 21 years old; the oil was a mess. The box was very much better after the service and its still smooth as silk now
I've also had the ZF6 boxes serviced in an E65 and F01 and both are still doing very well now and do a lot of miles from what I know
My current F31 is on 100k miles and I'll be getting in to be serviced when I've got 5mins to think...
ZF would not recommend the service of their boxes if they were to have issues; neither would someone like Grant at Automatic Transmissions, Preston, who as Ive said, has been around since the dark ages...
I'll go with what those folk say rather then Jim-Bob on the forums 'cos Daddy says so'...
Seems like I got a lot of people backing ‘what Daddy says’, including ZF for that matter. Maybe Jim-Bob might be right on this one.
In all seriousness though, this topic is heavily disputed in the auto industry as people practice what has worked for them in the past, like in your case. I was never saying you or your hometown specialist were wrong, because you weren’t. In a lot of cases, servicing transmissions is not at all a bad idea
For other applications however, it could be. There really isn’t a right or wrong answer because every application and situation is different.
I would however recommend that if your transmission has not had the fluid changed and there are a lot of miles on it, it is probably a better idea to not touch it
As ZF says, it’s maintenance free.
      03-28-2024, 03:09 AM   #28
eff32fl
eff32fl's Avatar
1052
The link does specify the 8HP transmission.
      03-28-2024, 08:05 AM   #29
im_an_alien
1129
Drives: 2016 340i
It does way down in the instructions (for those who decide to do it) but not in the general comments preceding. In other words the link is not ZF8 specific and does nothing to clear the muck.
      03-28-2024, 08:10 AM   #30
charlie fairmont
Drives: His & hers, GC & X5
He's referring to the link in his post, post #6. I'll attach the PDF here, too.
      03-28-2024, 08:21 AM   #31
im_an_alien
1129
Drives: 2016 340i
I was originally replying to midtownmike's link in post #25, otherwise my reply won't make sense lol
Maybe f32fl will tell us which one😁
This thread got hot fast, OP should tell us whether he's gonna do it or not...
      03-28-2024, 08:36 AM   #32
charlie fairmont
...This thread got hot fast...
Never met a fluid viscosity or interval discussion on the internet that didn't
      03-29-2024, 08:14 AM   #33
Fliplegend
Fliplegend's Avatar
Drives: 2015 435ix F33
So why are there so many threads about the transmission whining after a fluid change?
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line
      03-29-2024, 08:40 AM   #34
MidtownMike
The transmission also whines a bit if the fluid has never been changed, especially when cold. Could just be that people pay more attention and listen more closely when the fluid has been changed.
The procedure to refresh is quite specific and a bit complex (cycle through specific temperatures and specific gears). Don't know about the Hamburger States of Freedom, but here in Europe ZF has appointed and trained specialist workshops listed on their website, who follow the process exactly. Could it be that the "horror stories" are from people who had it refreshed at a local workshop with little knowledge about European cars and ZF transmissions?
      03-29-2024, 01:55 PM   #35
eff32fl
eff32fl's Avatar
1052
Mmmm hamburgers!
Yes it's anecdotal but someone was commenting on here recently that their tranny fluid got refreshed and it whined after. The mechanic swore up and down they did it right. The mechanic looked at it again and found it was a bit low on fluid and topped it off and no more whine.
      03-30-2024, 10:01 PM   #36
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by micharlie View Post
Is that true?
He said I quote
“We do not change/flush transmission fluid unless doing a transmission repair - the fluid is lifetime”
It is true. However, ZF had a severe service interval of 55k-75k miles which they've sorta back tracked on over the last couple of years.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      03-30-2024, 11:17 PM   #37
amancuso
amancuso's Avatar
726
Drives: 330it, 428ix, 430i
BMW is heavily dependent on the lease market (at least here in Europe). To keep the lease "affordable" and competitive, the maintenance cost needs to remain low. That is why the prescribed oil change intervals are ridiculously long and no transmission oil change factored in (blatantly ignoring the transmission manufacturer's recommendation).
By the time the negative effects start to show and shit breaks down, the car is out of warranty, so not BMW's problem.
The crazy thing about that is that the transmission maintenance should be under $500.00 every 60k or 5 yrs, even if you want to use the new numbers 100k or 10yrs or whatever. If you haven't looked up the procedure, it's more or the less the same method as it has been since the e36. The fluid/filter kit is about $230 +/- from FCP or similar, and the it shouldn't take a trained shop more than 2 hours to do, and that's being generous. Also most leases are 2-4 yrs, which would be outside the scope of a 60k maintenance.
2016 428ix, r, 2018 430iC, 2018 330it
      04-03-2024, 05:48 PM   #38
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Really? It doesnt say that their gearbox is maintenance free under normal use cases? Where did you learn to read?!
      04-03-2024, 05:52 PM   #39
sspade
sspade's Avatar
Drives: F30
Reminder on Blackstone's stance:
      04-03-2024, 06:02 PM   #40
rlesko
Drives: F30 335i
2012 335i  [0.00]
I changed my transmission fluid around 110k miles and it was one of the best decisions I made. I did follow the guidelines about letting the transmission warm up and cycle through the gears, FCP has a great video on it. I filled it with the exact amount of fluid that was drained. It was a bit annoying to read the transmission fluid temp, as its a bit buried in ISTA.
The car's performance was immediately improved, with the shifts being much quicker and smoother. To anyone reading this- if your car has around 100-110k miles on it, its not too late. Change the fluid, you won't regret it (or pay someone who can do it properly).
I think you 'ought to be north of 150k miles to really think about not doing it for fear of disrupting something.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
