03-11-2014, 08:14 AM | #5963 |
Rep 40,762
He did, and like you, still no Internet / WiFi.
03-11-2014, 09:10 AM | #5964 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Shawn, I learned your method with Combox and fake VIN.
Am I right the trick is substitute VIN without BMWAssist to Combox? In my case I have a donor's NBT with VIN with BMWAssist. And I use the CAN-filter. The Internet browser was working at 49.x version and wasn't working at 51.x and 52.x versions. As NBT have a imbedded Combox I can't use your method of coding. So if I try to change the donor's VIN in the NBT to magic fake VIN it will be a chance to get working Internet? |
03-11-2014, 11:53 AM | #5966 | |
Rep 40,762
I think you should try it though. My understanding is that even though NBT does not have FDL TELEMATIK_VIN, as does the standalone CMB_MEDIA Combox ECU, VO Coding NBT with Fake VIN in FA still does the same thing.
03-11-2014, 12:01 PM | #5967 |
Rep 40,762
No. There is no known way to Code Internet in Motion.
03-11-2014, 12:02 PM | #5968 | |
Rep 122
That's right for the TV in motion as well. |
03-11-2014, 12:05 PM | #5969 |
Rep 40,762
With Emulator / CAN-Filter, it works because when enabling the hardware "DVD-In-Motion" the car is fooled into thinking it is stationary, so any other Speed Locked function such as Internet will also work in motion.
I have read of related issues from multiple users though with the Emulator where it causes some sort of issue with GPS and the car's position.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 03-11-2014 at 12:12 PM.. |
03-11-2014, 12:08 PM | #5970 | |
Rep 33
My internet browser got to work only when I upgraded with the last upd5021, BT went to 37. So I have, 49.x and BT 37, browser working via BT on iphone 5s. |
03-11-2014, 12:17 PM | #5971 | |
Rep 122
I don't understand where VO coding insert Fake VIN? Maybe to the CAF signature? Do you know what kind of info the CAF signature contains? |
03-11-2014, 12:21 PM | #5972 | |
Rep 40,762
I believe the CAF Signature contains information from the .EST Token to sign the FDL change. This though is pure speculation.
03-11-2014, 12:25 PM | #5973 | |
Rep 122
Thank you! |
03-11-2014, 01:27 PM | #5975 |
Rep 122
You can get the music and video from PC or phone with running DLNA/UPnP server via WiFi. There is no essential advantage of WiFi over BT in case of current versions of NBT's software.
03-11-2014, 07:17 PM | #5977 |
Rep 24
Hi Shawn
Can you please PM me info/link for software that will work with ISTA/P 2.51.3 F020-13-11-504? Damn dealer upgraded my firmware today when I was in for a recall Thank you! |
03-12-2014, 01:23 AM | #5978 |
Rep 40,762
PM sent.
03-12-2014, 08:00 AM | #5979 |
Rep 55
03-12-2014, 08:34 AM | #5980 |
Rep 122
You can try to set off KOMBI>3000>CC_TEMPERATURWARNUNG and tell us if it works.
03-12-2014, 09:55 AM | #5981 |
Rep 40,762
The Frost Warning I think it is enabled via S842A Cold-climate version Option Code and can be disabled by FDL Coding Kombi => CC_TEMPERATUR WARNUNG = nicht aktiv.
I believe though this will only disable the warning at vehicle startup if outside temperature is below 37° F. If car is started already and the outside temp falls from above down to 37° F, I think it will still give you the warning.
03-13-2014, 03:09 AM | #5983 | |
Rep 122
The TAL was interrupted with error. The NBT doesn't reboot and stuck on black screen. After manual reboot NBT works. But still there is no Internet item in menu after services update. How can I check that NBT "ate" fake VIN? How can I VO code NBT with fake FA without error? I have 3.24.2 Esys and 52.1 data. I have the retrofited NBT with donor's VIN. I remove the emulator when I'm coding. Should I check or uncheck the items "Update VCM..." and "update MSM..." in program settings. Last edited by avgor123; 03-13-2014 at 04:06 AM.. |
03-13-2014, 03:40 AM | #5984 | |
Rep 55
Any help? |
