BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Projector Angel Eye Headlights!
proTUNING Freaks
      05-16-2018, 09:34 AM   #1783
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Originally Posted by ahsen94 View Post
Could we ask the master tech on his opinion on whether to go to 17 or 18?
I sent him the picture this morning. I want to say we should go 17 as it matches closely to the resistor of the low beam. He should be waking up soon and give an answer.
Originally Posted by gee38l View Post
So last night i noticed that the DRL's were flashing a little when turning the car on which it never did before not sure if thats related but it seems to be thoughts?. This morning both headlights turned on when i left for work so we will see how it goes.
In regards to the alignment yeah will give it another go i do understand what your saying and when you mentioned the dark areas can see them now especially when on a dark road.
Hmm. Flashing typically comes from the CANBUS pulses. I'm assuming you have a relay, which should take care of that. I need to look into if the DRL's only can have the bulb checks coded out, if they even have one.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      05-16-2018, 02:22 PM   #1784
ahsen94
Drives: 2017 320D
Right lets see what he says.
      06-10-2018, 10:42 AM   #1785
Gen2mike
Drives: 2013 328i xDrive, 2018 X3 M40i
I just installed these yesterday and I'm having the same issue. Drls are flickering and not just for a bulb check more like a constant affair.
      06-19-2018, 02:04 PM   #1786
andyt26
Drives: 2015 BMW 335i Msport
Anybody running LED bulbs in the lows instead of HID’s? How are they?
      06-20-2018, 11:52 AM   #1787
raccooniega
Drives: 2014 328i xDrive
PSA: USR Depo's are back in stock
Get em here.
https://www.uniquestyleracings.com/i...roduct_id=1023
      06-20-2018, 12:14 PM   #1788
andyt26
Don’t forget coupon code EGTDP2014. Can’t wait!!! Been waiting too long since I got the car in March!!
Side note, anybody in SoCal or San Diego specifically know where to bring them in to get installed? PM me if you do thanks
      06-20-2018, 01:42 PM   #1789
raccooniega
LED Bulbs for Depo's?
Side note, does anyone have a confirmed low beam LED bulb that will fit in the Depo housing with no modification? Having trouble finding one that is confirmed to work.
      06-20-2018, 08:46 PM   #1790
andyt26
I’m curious to see how they’d look in the projectors also
      06-27-2018, 03:30 PM   #1791
sbk444
Drives: bmw 328i
Hi guys! I'm new at the forum and i'm curious if anyone has similar problem that I do. I've bought DEPO headlights for my bmw f30 328i about 1,5 month ago and although I'm very happy the way they look , there are three major disadvantages. Since headlights replacement I've drove for about 3-4 times in serious rain and also I washed my car in touch-free carwash twice. Today I noticed some streaks/smudges in the interior part of both left and right shades. Here's the pictures :
Does anyone of you have the same problem?How to avoid it?How to clean it ? ( I suppose that there is no way to just pull off shades in easy way and wipe it out... )
The second problem is the error that popped out ( yellow triangle ) after replacement, that states there is malfunction of position of the lights and I can dazzle other drivers - how to fix it?
Third problem is the cutoff line ( sadly , I don't have any pictures ) - there is no straight line , I've got rather multiple steps in whole line - how to fix it/adjust it?
Thank you for your replies.
      06-27-2018, 04:09 PM   #1792
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Pics of your cutoff? Steps are normal in HID.
      06-27-2018, 11:08 PM   #1793
sbk444
Drives: bmw 328i
I don't have HID's - i've got standard H7 bulbs :-)
      07-01-2018, 01:05 PM   #1794
sbk444
Drives: bmw 328i
anyone can help me?
      07-02-2018, 08:45 AM   #1795
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Originally Posted by sbk444 View Post
anyone can help me?
Not sure why I typed HID. I meant steps are normal in projectors. They're required by law in order to keep you from blinding oncoming traffic. Best thing you can do is ensure bulbs are aligned well and then adjust the projectors so they are overlapped just right.
      07-02-2018, 05:03 PM   #1796
ikehigh05
Drives: 2011 328i xdrive
I ended up using LEDs that had a fanless design for my lows, as they were the only ones that fit without me modifying the dust cover or anything else. These type of LEDs have metal like ribbons/belts attached to them to dissipate the heat generated from the LEDs. I've had them installed for over a year with my depos with no issues whatsoever. Their light output on the road are not as bright as HIDs but they are good enough, especially if you install LEDs for the fog lights as well.
      07-02-2018, 05:07 PM   #1797
ikehigh05
After a year with the Depos, Ive had no problems with them at all. But Im curious about something. If the LEDs that light the rings go out, what are the options to fix them? Do we just install another LED driver into the housing, or do we need to reorder new Depo lights all together?
      07-07-2018, 10:34 AM   #1798
andyt26
Can you adjust the alignment of the beams from the hood like OEM?
      07-08-2018, 09:08 AM   #1799
AspireApex
Drives: 320i
How the heck do you change the bulbs on these DEPO headlights? Do you have to remove the wheel because it seems pretty difficult to pull out the old bulbs to put in the HIDs...
      07-09-2018, 08:50 AM   #1800
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Yup! There are two knobs per headlight to adjust. Just be sure when you do that you don't overscrew to one side. If the headlight knob gets tough and starts to "bump" like it's not going anywhere, stop and go back a little. Some have done otherwise and had the projector come off.
Nope. Just turn your wheels. Did my HID install after the headlights were in for a year and with the wheels on.
      07-10-2018, 02:51 AM   #1801
andyt26
Update: got these installed last Saturday and I swapped the halogen bulbs to DDM LED’s and they work pretty good. I noticed the LED bulbs in the old reflectors worked better than in the projectors, but it’s still much brighter than stock. I’ll probably go HID route later on once I get tired of the LED bulbs.
As far as beam pattern goes, I would have liked it more if the projectors made a straight line beam like most OEM projectors do. No matter how much I adjust the beams it seems like they have this weird Tetris looking pattern where it’s kinda blocky. I’ll try and get a pic when I get a chance.
Overall my initial impressions are positive with these lights. It sure feels a lot better knowing my car now has angel eyes compared to the ugly stock lights.
      07-11-2018, 09:11 AM   #1802
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Beam cutoff is normal as it's part of the Federal Motor Vehicle Safety Standard 108.
"S10.18.9.1 Vertical aim, lower beam. Each lower beam headlamp must have a cutoff in the beam pattern. "
      07-12-2018, 10:10 AM   #1803
USCbeachguy
Drives: F30
What led bulbs did you use? Also can you give a quick description of the coding needed? Thanks.
      07-12-2018, 07:26 PM   #1804
pdav
Drives: 2014 BMW 328ix
I installed mine over a week ago and no issues with errors or anything line that. I got my HID from the retrofitsource
Ballasts: Hylux 2A88 Canbus
Bulbs: H7: Morimoto XB HID 5500K + H7 HID Adapters
Was hoping to get a one step cutoff line but reading other posts here it doesn't look like its possible. Each headlight has a -\_/- thing going on. Anyone able to get a nice straight line? And not just when you are close to a wall/garage.
This might have already been covered but your lights should have a nice hot spot area. If they do not you have to angle the bulb till they do. This is from USR https://www.youtube.com/watch?v=6K4zdRp61gY
I was able to shim in some folded aluminum foil to tilt the tip of the bulb down and pretty happy with the results.
There was someone else asking about what if the LED's for the rings go out, how do we replace. According to USR you can replace with BMW LED modules that screw onto the bottom of the headlight unit (the heat-sink looking things)
