11-15-2015, 11:07 PM | #23 | |||
Rep 397
Now comes the decision for tires. I absolutely wants no rubbing so the proven set was: 225/40R19 for the front and 255/35R19 for the rear. Should I go for Michelin PSS or Conti DWS? There is barely any rain in Phoenix and it never snows in the city. Any recommendation on experience from both tires are welcome. I will keep you all posted once it is mounted and ready to go.
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i, F30 Liquid Blue Matallic 328i Current Garage Queen: Mineral White F83 M4 |
11-19-2015, 08:10 AM | #24 |
Rep 105
Looks awesome. What suspension setup are you running?
S14a 200SX / F31 335d
11-19-2015, 01:31 PM | #25 | |
Rep 397
Hopefully dropping with H&R coilover or KWv1 in the spring. These will be summer wheels no rush at this point.
11-25-2015, 02:37 AM | #26 |
Rep 11
I have a F31 328i M-Sport with DHP and currently have the 405M's as summer set under my car.
Since winter is coming, I'm searching for a winterset and have come across a 313M replica set made by TAM, with ET34 and 235/35/19 wheels all around. According to the seller, the wheels will fit my car without any problems. Since the wheels discussed here in this topic are all staggered, I was wondering if I can indeed put the set under my car with ET 34 in combination with 235 wheels all around. Anyone...? |
11-25-2015, 06:06 AM | #27 | |
Rep 335
11-25-2015, 07:13 AM | #28 | |
Rep 5,140
The tire size however is 2% shorter than OEM, just to let you know. A 35-profile 19" tire is not the best for winter usage, I would at least change the tire size to a 40-profile. Some alternatives: 225/40-19 OEM size for F31 235/40-19 1% tallar than OEM 245/40-19 2% tallar than OEM |
11-25-2015, 07:58 AM | #29 | |
Rep 11
Thanks for the replies!
I don't have much choice: it is a 2nd hand set, although they have hardly run more than 500km's. Given the price: €900, I am not complaining. (Another option is a replica set of the 193M, ET34 and 225/40/18 wheels all around, which is €200 cheaper) I assume the only downside is that the speedometer isn't accurate(?) Quote:
11-25-2015, 09:21 AM | #30 | |
Rep 5,140
- Increased wheel gap - Less protection against pothole damaging your wheels 225/40-18 is 3% shorter than OEM so that is not an ideal tire size either. |
11-25-2015, 09:26 AM | #31 | |
Rep 335
The front tires on the F30 x-drive in this thread are 235/35-19. In the second pic before the car was lowered, the tires look way too small IMO. http://f30.bimmerpost.com/forums/sho....php?t=1031765 |
11-25-2015, 02:55 PM | #32 |
Rep 11
Now I am doubting whether to buy the set or not...
I live in The Netherlands where fortunately the roads are good, but I rather stay as close to OEM as possible, be it wheels or tyres(-sizes). Perhaps wait till a better set comes along. |
03-02-2016, 03:39 PM | #33 | |
Mmmm... Bavarian
2129
Rep 1,690
Sorry for the revive on the thread. Read through it several times, and it is about the best one I can find for the discussion on these wheels. My F30 is a 2014 335 with MSport brakes. I did try a test fit with the 18" 313's off a 135is and the barrel of the wheel was too narrow to clear the calipers. I expect the 19 to clear that fine, but am confused by the repeated statement about "needing" 10mm spacers for the front. The offset and width on the 313's is identical to the factory wheels. If the spokes are set back in more I could see the need potentially, but that'd be unusual for BMW wheels. Additionally, the Z4 wheels do appear to be identical in every respect except the fronts are 10mm additional offset. So that's an "easy" solution. I plan to over tire the fronts most likely (245 or higher), so spacing will matter a bit for rubbing. Any other info or updates anyone can provide on fitting 313's? Thanks! Steve
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
04-07-2016, 04:41 PM | #34 |
Mmmm... Bavarian
2129
Rep 1,690
Hey Guys,
So I got the E92 Style 313's in on Tuesday. Did a test fit and the fronts do indeed have a small clearance issue. It's LESS than 5mm though. It just barely catches the caliper cover on the spokes at one of the radius's. Keep in mine I have the MSport brakes as well. I'd wager if you have non M-Sport you'd be fine, but certainly can't promise/guarantee that in any way. So the Z4 wheel offset for the fronts look like they'd work perfectly. I'm still sorting out a few things and may just swap to the Z4 wheels depending on what I decide. I'll try to get some pictures for you guys as well. Thanks! Steve
M2 CS
04-10-2016, 01:15 PM | #35 | |
Rep 3,622
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
04-10-2016, 01:19 PM | #36 | ||
Rep 397
04-14-2016, 12:20 PM | #37 |
Rep 1,649
can't comment on the process used to make the wheels, but Tischer has the Z4 fronts (36116787655) for $540 and rears (36116787656) for $580.
04-18-2016, 08:12 PM | #38 |
Mmmm... Bavarian
2129
Rep 1,690
Another piece of info for you guys. Turns out the rears don't clear the MSport calipers at all. Probably 10-15 mm interference. The Z4 wheels have the same rear offsets I believe, so no advantage/resolution there.
M2 CS
hanselfransel27.00 |
11-04-2016, 11:18 AM | #39 | |
Rep 84
Standard Factory Wheels Offsets:
1.) MMOTION mentioned that his 313 rims are just barely clearing his front calipers, even with 10mm spacers. This is surprising, because the offset of the factory 19" wheel is ET36, which is almost the same as the Style 313 (ET37). MMOTION, do you have the M-Sport Brakes on your car? 2.) Sometimes the Style 313 has the "M" badge, and other times is doesn't have the "M" badge but has the "BMW Performance" label. Does anyone know the difference? Thanks! |
11-04-2016, 12:02 PM | #40 | |
Rep 1,801
11-04-2016, 12:27 PM | #41 | |
Rep 84
Since I don't have M-Sport brakes, I'm hoping that the 19" Style 313 wheels will clear my front calipers without issue (even without spacers). Has anyone done this? |
11-11-2016, 06:42 PM | #42 |
Rep 1,801
Just wanted to update that the OEM M313 19x9 +39 rims WILL NOT clear MPERFORMANCE BBK on F30 335i/xi in the rear. You will need min. 3mm spacer to clear the rear caliper. Luckily I had a pair laying around, but I will be switching to a 5mm just to be on the safe side. I'm literally clearing it only by a fraction of 1-2mm.
Also, I am also using 12mm spacers in the front vs 10mm I was previously using last winter, just to give more clearance between the caliper and the rims. This is how the car looks with 12mm front and 3mm rear spacers. Last edited by MMOTION; 11-12-2016 at 11:14 PM.. |
11-29-2016, 07:48 PM | #43 |
Rep 84
Looks good MMotion!
Do you think it would be OK to mount the following tire sizes (Michelin PSS)? F: 245-35-19 R: 265-35-19 Does it matter that the circumference of the front is slightly different than the rear? Thanks! |
04-01-2017, 09:42 AM | #44 |
Rep 84
Hi MMotion,
Spring is here! I got my mechanic to test the fitment of the 19" 313M on the front of my car and it apparently needs a spacer to clear the caliper I don't have the M-Sport package, but he said the front caliper on my 2012 335i is identical to the M-Sport caliper, except that it's grey instead of painted blue. Based on your recommendation, I'm going to buy 12MM spacers for the fronts. Do you think that I also need 3MM spacers for the rears? Are you able to take a pic of your M-Sport rear calipers so that I can compare them to mine? I'm hoping that my rear calipers are smaller. Thanks! |
