05-01-2016, 06:03 AM | #23 | |
Rep 595
It all depends on how much you value certain traits and also what tire you replace the rfts with. That being said, I have removed the rfts from my, and my family members BMWs. I value the better ride more than the lost sharpness. At least I thought I did. I will definitely leave nonrfts on my mother's 5 series. The ride is smoother and she will NEVER notice the lost precision. But I just may go back to rfts on my own 5 series. Because I do miss that sharpness. I originally posted because it was said that go flats were superior in every way. Not true at all. The rfts have benefits as do the go flats. I LOVE the more civilized ride of the go flats. I love their ability to track/corner better on bumpy or rough pavement. I HATE the loss of steering precision that accompany the go flats though. Last edited by thakid22; 05-01-2016 at 06:08 AM.. |
05-01-2016, 06:41 AM | #24 | |
Rep 595
I fell into the same trap... I researched the rft non rft issue. A quick browse of the forums revealed post after post of people declaring that run flats ruin the car and swapping them out for regular tires was a win win situation. It was repeated on the forums so frequently that I just assumed it to be true. Even magazine "experts" said the same. Imagine my surprise when I made the actual switch and found out that it wasn't actually vice free! That is why I discuss this topic with such zeal. I don't want anyone to make the mistake I made... Thinking that rfts are all bad, and then lamenting the loss of precision after ditching them. I am not saying I like rfts. I think it was a horrible move by BMW to force these contraptions upon us. My current BMWs all have the rfts switched out with appropriate goflats. But there are specific changes BMW designed into the rft cars... RFT necessitate softer bushings, revised strut valving, and I think a slower steering ratio to prevent the car from being (relatively) darty. Now when all of those systems are designed for stiff (and quick/direct acting) tires, but then instead run on standard tires, there is a definite loss of sharpness. In the ride, the handling, and composure... I'm on my cell phone right now. Give me a minute to grap my laptop. I'll come back and repost real world experiences from experts and novices who noticed the steering change. You are right, most of us haven't heard of the downside of goflats on a rft car. That is a problem, because there definitely is a downside for those who value precision. Last edited by thakid22; 04-27-2018 at 12:38 AM.. |
05-01-2016, 07:04 AM | #25 | |
Rep 595
Here, TireRack tests the RE960AS Bridgestone RFT against its non runflat twin version of the same tire. An excerpt of what they had to say: "The handling of the Potenza RE960AS 3G RFT was actually a little crisper than the non-run-flat version, taking advantage of its inherently stiffer sidewalls to help the tire change direction more briskly. The conventional Potenza RE960 was close behind, also feeling nimble and responsive. The Turanza EL42 RFT trailed the two Ultra High Performance All-Season tires, feeling somewhat less responsive as you would expect from a Standard Touring All-Season tire." |
05-01-2016, 07:13 AM | #26 | |
Rep 595
http://www.bmwblog.com/2009/03/12/re...s-on-your-bmw/ This one is a quote from BMW, courtesy of the enthusiast group @ BMWBlog: "All of our vehicles that use Run-flat technology have their suspension and braking components set up to accommodate Run-flat tyres. Should you decide to change to non Run-flats, it may alter the driving and handling characteristics of your vehicle. It is for this reason that this modification is not recommended by BMW as a manufacturer." |
05-01-2016, 07:35 AM | #27 | |
Rep 595
Here is a quote from a fellow E90 driver who switched from the OEM Bridgestone Re050 RFT to Michelin PS2 non runflats... http://www.e90post.com/forums/showthread.php?t=345740 "Originally Posted by ni8shadow View Post So regular tires don't have a "performance" feel since they are "bouncy and soft?" The RFT's have stiffer sidewalls to support the weight of the car without air pressure. This contributes to excellent steering response because they hold their shape better (they don't deform as much) when you turn the car. It also contributes to a rough ride on rough roads (because they don't deform as much). And they are also heavier. My RFT's were 6 pounds heavier than the Michelin PS2's (per tire). When I first changed to the PS2's, I missed the excellent steering response the RFT's provided. Now that I've had the PS2's for a while, they seem fine. All new tires feel softer/mushier when they are new because they have more tread than the tires you are replacing and they need a break-in period. The bottom line is that you give up some steering response to get a tire that rides MUCH better. If I drove on roads like they have in Germany, I would have kept the RFT's, but given the horrible roads many of us drive in the US, the trade-off is a good one." |
05-01-2016, 07:47 AM | #28 | |
Rep 595
Heres an E61 (5-Series Wagon) Owner who noticed the increased body roll with non runflats: "OK i checked out all the posts on PH and it seems pretty much agreed that swapping the factory supplied runflats for non runflats is a perfectly OK thing to do. Potentially getting a smoother ride and saving about 30% on the cost of tyre replacements, so that's what i done.. However.... I have only swapped the rears (for a-symentrical Michelin Eagle F1's) with the fronts still being runflats (Michelin NCT 5's). At the same time I has the tracking fixed as it was way out on the rear and OK, but still out on the front. This also resulted in my off center steering wheel now being nicely centered. All was good off I drove into the sunset. The thing is now the car has significantly more body roll than before. The wife noticed it straight off and said it felt unsafe without me mentioning I had picked up on any change. Anyhow I am unsure where to go from here. Based on previous searched the concept of using non-runflats seems sound, but do I now have to swap the fronts as well? Should I get the tracking/pressures checked??? I've got 32psi rear and 30psi front. i'm thinking now though that those quoted pressures on the door shut are for RF's so maybe they need to be tweaked.. Any tips on suggested tyre pressures, or simply if it's a bad idea to mix the tyre types would be very much appreciated, Cheers smile" |
05-01-2016, 08:00 AM | #29 | |
Rep 595
On my E90, I went from the OEM semi worn 225/40/18 and 255/35/18 Potenza Re050 runflats to new Goodyear Eagle Sport non runflats. Only in that instance, the change (loss of precision) was more dramatic due to the fact I not only went from rft to non rft, but the Eagle Sport was an All Season tire too, not a summer like OEM. The OEM rft, had steering almost like a go cart. On the freeway, a sneeze (and corresponding twitch of the steering wheel) would make the car dart slightly in its lane. The non runflats relaxed the steering but made it less laser sharp there too. |
05-01-2016, 08:35 AM | #30 | |
Rep 595
You will easily find more on your own if so inclined. But EVERYTHING I have said is well documented by those who actually make the switch. As for rft vs non rft, you just have to know the right questions to ask. I (initially) did not. Most conversations revolve around ride quality and NVH. You'll also hear about how non rfts handle better. And they do! In certain situations. The extra compliance increases grip and stability greatly on less than perfect roads. But the down side is that the steering will be less direct, slower, and on center feel and effort ramp up can weaken. Think about it. For a moment, forget spring rate, shock valving, etc. Think of each corner as an assembly. Each corner has its own wheel rate, the rate at which the bushings/mounts/tires/springs/rim/shocks, etc all cumulatively operate. A rft can be up to 35 % stiffer than a conventional tire. Swapping it with a softer tire is somewhat similar to swapping in softer shocks/bushings/springs etc. The overall wheel rate drops. Lower wheel rate can produce a smoother and quiet ride, but can and will also reduce control and response. E90s were designed around early runflats that were stiffer than todays models. Adding non rfts to those cars evoked a night and day difference. They took on a smoother, more civilized, but almost underdamped demeanor on non rfts. Today's F-Series BMW makes less concessions owed to its new generation, softer (but still stiff) rfts. Again, I'm not advocating runflats. I wish BMW had left them off of the spec sheet. The rfts are now an integral part of the BMW chassis. Those rfts do impart a sense of sportiness. BMW knows they are stiff. Consequently, stiffness has been removed and added from/to various other chassis parts to accommodate that. Throw away the rft stiffness and the car is left without a bit of stiffness that it once used. The steering is a perfect example. With reduced sidewall flex it literally takes less steering angle (especially initially) to turn the car. Go flats increase flex and also the required steering angle for a given turn. It is very obvious when you are looking for it, especially if you can drive to cars back to back (rft vs nrft). All that being said, go flats are not gonna destroy the handling precision of these cars. They will dull it every so slightly. Some may never even notice. In the end it can argued that go flats give MORE in traction and nvh, than they take away from precision. I hope I have been able to help and perhaps save someone the shock I experienced. On another note, uh - I know I'm getting long winded, the current crop of RFT are much less of a NVH compromise than they used to be. The Michelin PS2 ZP runflat was nearly as civilized as the PSS nonrft I replaced them with. In fact, they felt like a sportier version of the same tire, around town. Quiet, firm, and responsive. I do feel that the PSS did have better ultimate grip though. Anyway, I've strayed from the original topic... |
05-01-2016, 08:59 AM | #31 | |
National Championship #17 and Counting!
793
Rep 1,508
Adjusting psi is important. From that quote, not sure I've ever run as low as 30psi on any set up.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
05-01-2016, 09:15 AM | #32 |
Rep 438
Drives: F30 335i M Sport
05-01-2016, 09:18 AM | #33 | |
Rep 595
I see you are running PSS (your sig). I found the PSS very happy at around 35psi too. BMW says runflat/nonflat configurations should use the same pressure. Seems weird to my mind. Typically though, I use the recommended psi as a starting point and adjust up or down as I deem necessary. 30psi seems low, but that's what some of those E60 called for. |
05-01-2016, 10:54 AM | #34 | |
Rep 503
I have been thinking of doing a 18x8.5 square setup with a 245/40 tire. Lucky enough Michelin does offer a few runflat options in that exact size. I may do the A/S version though since I do not want to have to swap summer tires out in the winter |
05-01-2016, 01:25 PM | #35 |
Rep 938
Another one here did the non-RFT swap.
I had a set of Goodyear Asymmetric 2's installed all round (at protest from the tyre dealer as they were marked "Recommended for Mercedes", which as you all know means sweet FA). The tyres are a marked improvement from the standard Goodyear EfficientGrip's that came standard on my 18" rims, but I will agree there's a bit of "wallow" on sharper corners. Much of this could probably be fixed with some suspension tuning but that's only if I really push it and I rarely do. Also, RFT's are notorious for damaging rims as they don't offer any give and won't distort on pot-holes. Anyway, the car is now much quieter and handles beautifully for most driving conditions. It's a shame however the tyre shop that installed the tyres scratched every rim, did not balance my tyres properly and mis-aligned my car and accused me of misinforming them of the model of my car. (The moron manager told me my car wasn't an F31, but an E91!!!). The consequence was a US$340 repair bill at my BMW dealer. I'm currently taking the tyre shop to the small claims court to re-coup the cost of these repairs as they only offered me $150 as a "good-will" gesture. I told them to stick their goodwill up their arse and enjoy a letter from my lawyer. Sadly however in Spain, lawyers take more coffee and shit breaks than any other profession I know so it'll be months before I get this money back.
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
05-02-2016, 11:50 AM | #36 |
Rep 473
Thanks for that well put analysis. I was beginning to feel as if I'm the only one that noticed that my RFTs handled better precision wise. I noticed this when I had my e90 on non RTFs. I was losing my mind trying to figure out why my BMW didn't feel as sharp. Don't get me wrong, I was happy with the other improvements, mainly comfort and less noise and weight. The Bridgestone Efficientgrip tires that came with my f30 are actually more on the comfortable side of RTFs to believe it or not so I'm not as in a rush to get rid of them.
Either way, your analysis is on point with my experiences between the two types.
I has no mods
05-02-2016, 03:48 PM | #37 |
Rep 603
When looking at a tire comparison like RFT/non-RFT it is also important realize that a tire is available with different load index.
The 225/45 19" 89Y can handle 580 Kilogramm per tire The 225/45 19" 93W can handle 650 Kilogramm per tire (mostly also marked with "XL" for extra load) XL normally has a stiffer sidewall and therefore a stiffer feeling. Any tire has to match the weight of the car. So normally for every car you have two tire variants available: Standard or XL I started to use XL on my non-RFT setups many years ago, because I like the less spongy feeling compared to the standard load index variant. (I use XL this for front and rear axle tires, on summer and winter tires) Steering response is also very depending on tire profile and the rubber compound used. That's why in tire tests-reviews tires get different rates for steering response, on the same kind of tires. So comparing RFT with non-RFT only gives a 1:1 result when looking at the same tire type/profile. When reading professional RFT non-RFT test reviews, the result is, that non-RFT are easier to control in under-/oversteering situations. Non-RFT have better lap time in wet conditions, but RFT have better lap time in dry conditions. Non-RFT have much shorter braking distance (60-0 mph almost 1 car length) Test was done with an E90 330i. So there is pro and cons for everything. And as technology improves also on RFT, I will review my non-RFT decision the next time I need new tires.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
05-03-2016, 07:52 PM | #38 | |
Rep 1,180
on order: 2024 i4 eDrive40 M Sport, Tanzanite metallic with all options
09-24-2016, 12:02 PM | #39 | |
Rep 34
09-24-2016, 05:55 PM | #40 |
Rep 38
I have a 340i with the track and handling package with the 18" non-runflat Pilot Super Sports.
In anticipation of winter's cold and wet, I bought a used set of 403M 19" wheels mounted with Pirelli summer run-flat tires. The 403M wheels will get snow tires in a couple months. This puts me a position to comment on the topic of the thread from first hand experience. Here are my thoughts. run flat 19" Pirellis summer tires:
Go flat 18" Pilot Super Sports:
09-25-2016, 07:41 PM | #41 | ||
Rep 10,351
People who go non-rft ignore the fact that the stock alignment for their vehicle was done with runflats in mind. For the record my wife has non-rft S001's on her vehicle and I really don't notice much of a difference when compared with my RF S001. I also second your comments about the trade-offs associated with going non-rft. People will look for any reason to justify their decision to stray from whatever the manufacture recommends.
"Drive more, worry less. "
10-17-2016, 03:43 PM | #42 |
Rep 3
Drives: F30 330i manual msport estoril
RE car geometry designed for run flats. When speccing my car there was and is currently an option for 18" V-spoke Orbit Grey Style 398 alloy wheels these do not have run flats or at least no all or them are run flats. That was the reason I was considering them. So maybe steering geometry is not just for run flats.
I decided against them as I didn't like the look of them on the configurator and couldn't see any in real life to know for sure. If I could have seen them for real and thought they didn't look awful I would have gone for them to avoid having run flats. Lower unsprung weight and softer side walls sound a good idea to me. However I chose the LA wheel, M double spoke 441 18" that come with Bridgestone Potenza run flats. They are very highly rated by testers but they are very sensitive to tyre pressures. At the lower end of recommended pressure for the tyre size the car was nervous in a straight line at moderately high speed, I would say verging on dangerous at properly high speed. Feels similar to driving with worn dampers very sensitive to side winds though changing the adaptive M sport damper setting to sport made no difference. Pressures at the very highest of recommendation (the five person pressure on the sticker) straight line stability is transformed and becomes very assured. Car remains supremely comfortable. I definitely wouldn't recommend any one running these at anything less than the highest recommended setting. It seems very high if I remember correctly its something like 42 and 48psi. Beemer back at the dealers at the mo so cant take a look at the sticker. Some here are saying run flats have ruined the ride handling mix of the 3 series. Very tidy handling and comfort were 2 number 1 priorities for me in my choice of car. The BMW stood out as being supremely comfortable. I have not driven a more comfortable car. I have driven many current models. The seats with adjustable lumbar play they're part and also best in the business just takes some time to find the perfect setting with so many adjustments. I chose M Sport adaptive suspension despite warnings that this may detract for the comfort I raved about in the test car but the suspension choice was a good one. I don't see how anyone can claim that RunFlats have destroyed Comfort. Handling wise the car could be more communicative. Certainly 2 seater sports cars from Mercedes Audi or Porsche are much more communicative than the Beemer though perhaps thats an unfair comparison. More comparable the Quattro Audis certainly give the beemer a run for its money in terms of handling but none of those can match the comfort of the beemer. If run flats compromise the handling and comfort mix then its handling and specifically feel that is compromised not comfort. Last edited by lesBray; 10-17-2016 at 03:52 PM.. |
10-20-2016, 12:58 AM | #43 |
Rep 195
I agree with some of the sentiments of this thread. Regular tires on my bmw do seem like the turning feel is amiss. the runflats provided more stiffer feedback when turning from slow moving and mild speeds. although, i am losing the feel, or maybe the wear in of the tire is helping.
10-20-2016, 03:05 AM | #44 |
Infidel
122
Rep 1,102
Going from RFT to non-RFT it is recommended you choose an XL version (You can even see the XL-variant on the recommended tyre pressure chart on the door sill).
Found this picture and basically on XL tires #4, which is the carcass, is reinforced to take up to 4 times higher than normal load. Ditching the RFT´s was the best thing I did on the E90 and it has also been on this one. How many of you that have commented here have chosen XL-tires when replacing the RFT´s?
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
