03-04-2013, 02:13 PM | #47 | |
Rep 336
Drives: 2012 328i
03-04-2013, 02:19 PM | #48 |
Rep 176
Probably for some sort of Cali emissions they don't have 93 octane, see what octane booster they have.
2019 Ibis White/Red S4
1997 Nissan Skyline GTR V-SPEC Last edited by Turboedv6; 03-04-2013 at 03:43 PM.. |
03-07-2013, 12:48 AM | #49 |
Rep 886
I literally can't waittt to get the stage 2 on my car, I have an e85 station about 3 min from my house!!!
What excites me the most is potentially having 325whp/390wtq on tap with a turbo back exhaust!! Having (approx.) +90whp/+135wtq over stock is just nuts
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs Last edited by RSXDC5; 03-07-2013 at 12:55 AM.. |
03-07-2013, 01:47 AM | #50 | |
Rep 7,298
03-07-2013, 10:57 AM | #52 |
NFS
88
Rep 167
But I have read and asked terry if you are able to use 91 for the stage 2 tune, he said yes you can. In fact he mentioned on another thread that you can use 91, you may not get as much power with 85, but the power will still definitely be higher than stage 1! They will bring out the dyno results using 91 and 93 pretty soon from what i read. It should be very interesting.
03-07-2013, 11:13 AM | #53 |
208
Rep 1,161
I'm eagerly awaiting 93 octane results, if possible with knock sensor monitoring. We do have 93 octane, a 328i and a dyno if any help is needed. Thanks for isolating the air filter on the dyno. You've saved a lot of people a lot of money. Did you isolate the filter at 23 pounds of boost or at the lower stage one level?
03-07-2013, 11:13 AM | #54 |
Rep 1,997
Just lurking, nice numbers. My concern is the fact that the cars aren't designed for E85 and what effect does it have? Warranty issues? Premature wear? Anything else?
I know cars that can run E85 like to advertise it prominently. Not sure what changes need to be done to safely support it, but just has me wondering as it's a huge increase in power coupled with decrease in fuel efficiency. |
03-09-2013, 07:56 PM | #55 |
Rep 1,022
when i had my evo, E85 was also widely used.. only couple parts that req. were larger injectors & high capacity fuel pump. There were no signs of premature wear on fuel lines etc etc.. it's clean fuel.. I'm asuming as long as tuning is within range of our stock fuel supply system, there wouldn't be any contraindications.. i'm def. waiting until they introduce this stg 2 tuning ..
03-09-2013, 10:14 PM | #56 |
Rep 7,047
The concern with E85 isn't that it's not "clean", it's the alcohol/ethanol used to formulate E85.
But, seems tuners have and are using it with no ill effects. Still, BMW recommends using no more than 10% ethanol mixed fuel. E85 is 85% ethanol and 15% gasoline. Time and mileage will tell if the alcohol has any damaging effects. Alcohol has a greater cooling effect in the combustion chamber and that results in a higher octane rating. But, it also has a less thermal energy, which will lower MPG. Initial cost per gallon may be less, but overall you'll spend more by needing more E85 to cover the same mileage as regular gasoline. Here is a good article/experiment showing the MPG differences and costs associated with using E85. The power/accel tests in this article don't really translate directly, but I post this article for the MPG question not power performance comparison. http://www.edmunds.com/fuel-economy/...ison-test.html Some people will say there is not point to E85 as it costs more to operate and doesn't save much on emissions. BUT, the biggest thing to remember about E85 is that it is a RENEWABLE fuel resource, meaning, we have ways to produce more over the long haul compared to the limited amount of oil available. Once we run out of oil we're out of gasoline too. At that point E85 will look real good, unless we're mostly in electric cars by then. Last edited by RPM90; 03-09-2013 at 10:44 PM.. |
03-10-2013, 04:26 PM | #58 |
Rep 3,780
I will dyno both ways. I bet 30-35whp from 93, 22-27whp on 91 on a Dynojet. That's my guess.
03-10-2013, 04:45 PM | #59 | |
Rep 3,566
Maybe try dynos at 3 & 4. Cheers
03-10-2013, 06:49 PM | #60 | |
Rep 3,780
I am not in a rush as I am still on snow tires, so it just means more wheelspin. Dyno'ing at 3 and 4psi is what I meant when I said the two power guesstimates.
03-10-2013, 09:38 PM | #61 | |
Rep 3,566
Yes, as you certainly would have read, I asked Mike what the second field was about, but so far no answer. Got it about your weather conditions. And on our side of the planet, we are experiencing the hottest weather run since records were started in 1856. Cheers
03-11-2013, 06:25 AM | #62 | |
Rep 115,955
For the +4psi setting only the 'boost over stock' field is changed. Mike |
03-11-2013, 09:27 AM | #63 | |
Rep 3,780
Do you have a direct link to the N55 software I need to download to tinker with the boost?
03-13-2013, 02:33 AM | #64 |
Rep 336
Drives: 2012 328i
So when you pump 85 do you pump a few gallons or fill up the tank? Does it cause your engine light to go on?
03-14-2013, 04:29 AM | #66 |
NFS
88
Rep 167
