09-10-2015, 07:11 AM | #89 |
Rep 1,436
ah ok I will try my luck but what's weird I can't find it anymore on Horizon website. it's 6000k anyway so I might not like it's color vs. 5000k bulb I have.
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
09-10-2015, 07:12 AM | #90 | |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
09-10-2015, 07:33 AM | #91 | |
Rep 1,436
check these out http://www.ebay.com/itm/New-2-X-H11-...de2921&vxp=mtr http://www.ebay.com/itm/2X-H8-H9-H11...d20e3b&vxp=mtr http://www.ebay.com/itm/H8-H11-LED-T...662c4a&vxp=mtr
09-10-2015, 07:36 AM | #92 | ||
BMW Fanatic
331
Rep 1,076
09-10-2015, 07:47 AM | #93 |
Rep 1,436
ok you are awesome man. thanks a lot can't wait till they get shipped
09-11-2015, 02:49 PM | #94 |
Rep 226
Added the Horizon LED 50W brake lights.. pic shows the Horizon light on the left side, and the run of the mill ebay 1156 LED on the right. Huge difference and very happy.
09-11-2015, 04:00 PM | #95 |
BMW Fanatic
331
Rep 1,076
Congrats man, enjoy!
10-02-2015, 04:26 AM | #96 |
Rep 11
10-03-2015, 05:08 AM | #97 |
BMW Fanatic
331
Rep 1,076
From the hue of the tail light, I'd say red.
10-04-2015, 06:00 AM | #98 |
Rep 1,076
Has any one tried the curved Cone H8 fog lamps from horizon? http://www.horizonleds.co.uk/cree-le...e-cone-led-45w
10-04-2015, 07:01 AM | #99 | |
BMW Fanatic
331
Rep 1,076
10-05-2015, 05:29 AM | #100 |
BMW Fanatic
331
Rep 1,076
Update:
New fog light LEDs installed. Thread updated.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 Last edited by 963mw; 10-05-2015 at 05:48 AM.. |
10-05-2015, 07:42 AM | #101 | |
Rep 1,076
Just pulled the trigger for the same but from US as I can get it tomorrow. Did you need Load resistors for your install of these bulbs in the fogs? I am confused. Canbus connector and load resistor the same thing? Where did you get the Canbus connector for H8 from? Also when you install these do you remove the wheels or just turn it away to access the bulb housing? Your response and experience are appreciated. |
10-08-2015, 03:49 PM | #102 | |
BMW Fanatic
331
Rep 1,076
10-08-2015, 04:18 PM | #104 | |
BMW Fanatic
331
Rep 1,076
10-08-2015, 04:42 PM | #106 | |
BMW Fanatic
331
Rep 1,076
10-08-2015, 05:27 PM | #107 |
Rep 1,076
Yes they do have some glare but I don't drive with them on until I get to a countryside. The do come on when I turn as I have adaptive headlamps. I think I was expecting a huge improvement but I think I was wrong. LED in reflector lamps are not the best combination unless they come stock and the optics have been done right. Honestly there is no way of measuring the lumen output of what is claimed on the box of 3000 lumen.
I didn't need a resistor or Canbus for these leds though. Which is great! Only coding to enable LEDs. I am still going to see how it does over the week. If I am not happy guess I will go back to stock halogen as nothing can be done except go to OEM LCI LED fog lamps. |
10-11-2015, 01:00 AM | #108 | |
BMW Fanatic
331
Rep 1,076
Cheers
10-21-2015, 03:17 PM | #109 |
Rep 33
Hey Nick, really great post! Thanks for putting all this together. I've read through everything a few times but want to make sure I have this correct:
Option 1 = H8 CREE LED - 50W which is a straight swap of the bulbs and is about $35 for 2 bulbs. (Link: http://www.horizonleds.co.uk/h8-50w-...og-light-bulbs) Option 2 = H8 CREE XHP50 LED Headlight Kit - 3000 Lumens which are actually headlight bulbs, but work and give you more light output. These are $125 for 2 bulbs. (Link: http://www.horizonleds.co.uk/h7-cree...adlight-kit-g4) Option 3 = Replacing the halogen assembly with BMW LED Foglight Assembly. These are $350 for the 2 housings, but then I need to get LED bulbs? Is that right? (Link: https://www.ecstuning.com/ES2960697/...FVUWHwodK-sP1Q) Sounds like Option 3 is easily the best but it's substantially more expensive. And the difference between Option 1 and Option 2 is noted throughout the thread (light output, glare, etc). I'm leaning towards Option 1 since this is entirely an appearance upgrade for me. And each car is different, so it's impossible to know if I need the resistors or not? http://www.horizonleds.co.uk/h8-canb...ning-canceller Thanks man. |
10-21-2015, 03:22 PM | #110 | |
BMW Fanatic
331
Rep 1,076
If you can hold on for one day, I can confirm whether you need the CanBus connectors for the option 2 lights. Apparently this new bulb design doesn't require CanBus connectors, so tomorrow I will take my connectors off and let you know how that works. Option 1 is a good place to start IMO, if you find that you need more light, then simply move on to option 2. I personally need the strongest lights possible for my car given the amount of potholes here, however, your needs may be different, hence different light choices. I will upload some pictures right now of the fog lights in action. Hope that helps! Feel free to ask if you need more help.
