BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Decoupling steering weight from suspension stiffness
Studio RSR
      01-12-2019, 11:30 PM   #1
pkiledj
Drives: '15 335i 6MT xDrive M-Adaptive
Does anyone know how to decouple the steering weight from the suspension stiffness and throttle response in Sport Mode? I want: stiff suspension, responsive throttle, and light steering. My car has adaptive suspension.
I am in the Los Angeles area. Any recommendation for a shop that can properly code for this would be greatly appreciated.
      01-12-2019, 11:35 PM   #2
jh_f30
jh_f30's Avatar
1307
Drives: 2013 335i Sportline Auto RWD
AFAIK, it's not possible to accomplish what you're looking to do with basic coding. There is a coding option to allow for Configuration of Sport mode, wherein, you can select either the drivetrain (throttle response) or chassis (steering & suspension) to be in sport or normal mode when Sport is activated. However, I don't think there's a way to code the Chassis configuration to make steering and suspension separate.
I don't have adaptive suspension, so it doesn't really apply to me, but this is based on what I've read thus far in the forums.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      01-13-2019, 12:11 AM   #3
pkiledj
I know Dinan Shockware moves the stock sport suspension setting to Comfort mode, so you get stiff suspension and light steering, but not responsive throttle. I called Dinan to ask if they had a solution for this but no luck. I'm sure someone on this forum knows how to accomplish this.
      01-13-2019, 12:54 AM   #4
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3045
Drives: 340 6MT, 50e, others
Nope
      01-13-2019, 02:19 AM   #5
about94ninjas
about94ninjas's Avatar
Drives: ‘18 340i
If you're considering the Dinan shockware anyways, what you MIGHT be able to do is configure sport mode to have sport drivetrain but comfort chassis. That way you'll have the sport throttle response, the light steering, but "comfort" suspension, which is now essentially the sport suspension.
      01-13-2019, 05:33 AM   #6
bimmer456
Drives: 340i
I prefer the heavier steering in the canyons. The lighter steering has less on center feel but is better at low speeds less than 10mph.
      01-13-2019, 09:30 AM   #7
pkiledj
That's a great idea! I had not thought of this. Can someone who has Shockware installed confirm whether you can still configure Sport Mode after installing Shockware? In other words, in Sport Mode, are these options still available and functional?
      01-13-2019, 11:04 AM   #8
about94ninjas
Drives: ‘18 340i
You should be able to. All the shockware does is change a few values in the suspension ECU.
      01-14-2019, 07:25 AM   #9
ipilcher
ipilcher's Avatar
436
Drives: 2024 M3 Compensation
Confirmed.
pkiledj46.00
adaptive, button, coding, mode, sport, steering, suspension
